other reactor idea..
You can found more patents for treatment of waste plastic but all patents work using simple heat without apply nothing of new. Normal method require some kW of energy, I think your object is creation of fuel for personal usage only, in that way you don't need to process more waste plastic. My idea is use electric heat (gas after) + HV without catalyst.
You need to heat slowly plastic for not burn that and reach gradually high temp inside reactor. I attach here my diagram because one image is better than 1000 words. Working principle is simple. The electric heating element (resistor) is used only as starter for heating special ollare stone (italian), that absorb heat and released that gradually on waste plastic. Laterally are present two electrodes that radiate waste plastic with high voltage/high frequency. When an alternating current is subjected to a dielectric material, the molecules try to align themselves to the alternating field, rubbing themselves together with each cycle, or reversal of polarity, an a pronounced molecular friction is set up. When the alternating field is reversed several million times a considerable amount of heat is naturally created because of the molecular friction that takes place. This, briefly, is the principle involved in dielectric heating. Waste plastic in that scenario is stressed molecularly trought HF (5-15MHz) and heated at the same time electrically (starter), at these conditions you obtain an summ of temps vaporizing the waste plastic. Probably you can use same RF circuit made from Mike when him finished that.
Idea is create an reactor for process an low amount of waste plastic and start process quickly for obtain gas output (and others) ; think how work an wood pellet stove.
Need to be tested but Im sure that method have high efficency respect to old. Here italian informations on ollare stone translated in english .. Google Traduttore
That is an simple diagram but I think is possible created an little all-in-one waste reactor and obtain on output directly the gas needed for process maybe using waste plastic pellet. Regards
