HEllo quantum these might be those with high Rds on resistance so they are more stable. I also tested those from the flyback set and saw they are more stable but wast more energy.
Exciters = OU from Mass = semiconductors
I'm fine man, how about you? What have you being doing? I hope for you great too. I'm around here constructing my prototypes and making time pass, i'm also studying, to get into the physics university for the next year.
lot of work to do
Best Regards
After reading this thread, I'm still at a loss to find anyone actually contributing to it, as Goldfinder asked for.
We have Doc Stiffler and conradphd who appear to still be way too paranoid and are probably sitting on some bits of information that should be shared.
Then the rest are just paddling their own theories based on hear-say, regurgitation of what's already been said, or pure conjecture.
It should also be noted that these theories come in waves and one can observe patterns of appearances (and repetition), as threads take over various discussion forums, then dwindle for a while and disappear.
I know this post was not a contribution to the thread, but frankly, if I was a mod I'd delete all of your posts...Are the ravings of a lunatic signs of a genius?
It appears you are referring to my posts. The theories I posted are not taken out of thin air. They are based on the work of many others in this field, like Tom Bearden, Eric Dollard, Prof. Klaus Turtur, Prof. Constantin Meyl and Dr. Charles Kenneth Thornhill, to name a few. I read quite a lot of theories and papers and connected the dots between those and combined them with what I already knew from my education. FYI: I do hold a masters degree in Electrical Engineering.Originally posted by amigo View PostThen the rest are just paddling their own theories based on hear-say, regurgitation of what's already been said, or pure conjecture.
So, the theories I present are based on a solid foundation. It's just that main stream sciences has chosen to neglect to a large degree the fact that the electric field is not a static force field, but a propagating wave, something that has been known for a very long time.
Another major problem with the main stream science is the errors that have been made in the Maxwell equations, because at some point it was postulated that the electro-magnetic field is caused by charge carriers, while we know from quantum mechanics that it is the other way around. The fields cause the matter and therefore the Maxwell equations do not describe the physical situation for the full 100%. And it is exactly this error that has lead to Einstein's general relativity theory, which is a piece of junk. In essence, it is based on the assumption that the fields are caused by matter, which is proven to be incorrect by quantum mechanics. Tesla had it right all along, there is a real ether and at some point Einstein's general relativity has to go where it belongs: in the trash can.
Thornhill has some very good papers on how and where Einstein went wrong:
Dr Charles Kenneth Thornhill
Your kidding Right.Originally posted by amigo View PostAfter reading this thread, I'm still at a loss to find anyone actually contributing to it, as Goldfinder asked for.
To have any hope of answering this question we must first try to understand the theory.So how does the tap work?
Can you understand this statement. I posted. from the document I posted.
If so, would you like to elaborate. Because it is very relevent even though it may have went largely ignored." All mass is formed by a contraction of the electric poles of the generative cones of energy to the point of north of it's gravicative center and by an expansion of the contours of the radiative cones untill they disapear in the plane of the equator."
We are not trying to build sand castles here. It is complicated and difficult to comprehend.
Would you like to tell us how the tap works? What are you doing to help?
What is your theory ?
I only see one real question in the Original post.
I guess we could do without Mods like you then. Yes there is paranoia people will share when they are ready. We will have to get around that.Stifflers exciter is creating a disturbance in the aether and then taps this disturbance. So how does the tap work?
I did replicate Stiffler's circuit some time ago, which is capable of lighting a 4 W TL from something like 100 mA at 12V.
I think I have a pretty good understanding of what goes on in resonating systems and how these are able to tap the energy from the vacuum, trough the electric field. I think I understand the principles. However, building practical devices is quite complicated, because you have to somehow separate the part of the system that uses the electric field from the part that creates it (or better: creates the dipole that gives you energy in the shape of an electric field). One way to do that, in principle, is to use higher harmonic oscillations, which is what I recognize in the systems I have analysed (Gray, Meyer, Puharich, Stiffler, Kapanadze - Kapagen., Tesa coil).
It would be very nice to build something, but I have very little time and budget. I hope to have some time in december to build something. I posted four variations on exciter circuits that I think are interesting to experiment with:
The first one is basically a combination of an exciter circuit with the Kapagen device, the second one is inspired on the Kapagen way of winding coils which suggests it is possible to have a pure electric oscillation in a two-layer coil, where one layer is wound clockwise and the other counter clockwise, so the magnetic fields cancel each other out.
If I understand this stuff right, these circuits should produce interesting results. If they do what I think they will do, that is.
Some time before these, I posted these:
The first one is an idea how to oscillate two identical (air core) transformers using an exciter circuit, and the second one is an idea how to combine Puharich's circuit with an exciter. Also very interesting and promising idea's, but we won't know if they actually work before someone builds them and tries it.
All of these could be important steps forward. But they could also be miserable failures, that's how these things go. The devil is in the details and it is hard to predict whether or not you forgot some detail that destroys the whole idea, like what happened with my idea of driving transformers trough AV plugs (half bridge rectifier). These short out your transformer in the second half of the oscillation....
I try to share as much as I can and explain how I think the stuff I see works. Whenever I find something new, I post it, so everyone can do with it what he/she likes and give comments, so we can all move forward. I think that way, we will get where we want to be. The more people that give a helping hand, the faster we can go forward. On the practical side, I hope to be able to build (one of) the Kapagen inspired circuits, because I think these are the most promising.
And indeed, when we just continue to move one step forward at a time, we will somehow get the information we need to take the next step. I have no doubt we will be successfull eventually:
Success is the ability to go from one failure to another with no loss of enthusiasm.Sir Winston ChurchillLast edited by lamare; 11-07-2010, 10:33 PM.
I am so frustrated that I don't have the resouces or time to try some of your circuits lamare there are a couple I am particularly interested in, though I have no formal training in anything much, I see some circuits that make complete sense to me even though I can't undestand exactly your explainations. I try to look at them all for a while.
I have a theory of things in this area, maybe a way out of the shackles, but not with need to break them but dissolve the shackles of oppression, the people who seek to controll everything have very slowly bound us to thier ways by slithering into almost every aspect of our live's. I think we should do the same in reverse, by quietly putting the many and varied efficient and OU devices we discover into everyday living for all to see and use, it will be difficult however and attention should not be sought for ego boosting.
If we do this right it would of course end in some kind of confrontaion, between control and freedom. I'm ready for the end game when it comes, but are we all?
I thought I would edit with an example, if you have made a very efficient or interesting device, make it pretty or usefull and give to somebody, who could use it, as a gift, include a drawing, if it works very well word will get around you can count on that. The person you give it too may want to become involved in the movement because they can see the value of it right in front of them and use it.
I hope that makes sense, maybe i'm a dreamer.
Some on and some peddling
Wow,
I guess I stirred up the hornet nest of various theories.
Amigo hit it on the head - most just peddling their own theories and didn't bother to look at the initial question.
Sebasfato and Quantumuppercut - moving in the direction that I envisioned.
Namely - that semiconductors do appear (I think they do but I am open to other suggestions) to trap energy out of the aether. AND if they do - then how can we move to a real simple energy device that converts the energy in the aether in usable electric energy.
And charge is NOT fundamental - and particles are not some resonant thingy - they are vortexes in the aether. Again I say - look up Lucas and Bergman, and Paul Stowe and you would realize that. Stowe is the closest. Electrons and Protons do have charge but why do they have "charge" and what is charge?
And the aether is NOT fundamental but getting closer.
And yes, I do know that QED and Einstein stuff should have been circular field long ago. Lets not go there. That has been beaten to death by many and it doesn't solve the problem. Telling what is wrong does not tell us what is right.
So if we can drop our various views of how this or that works lets get back to the original question regarding - Semiconductor materials.
I do appreciate all the inputs. I learn lots but it was not where I had tried to go.
Goldinder
Yes I do appologise but can you more clearly define the meaning of the two words in bold so we can stay on topic? It may be open to interperetation.So if we can drop our various views of how this or that works lets get back to the original question regarding - Semiconductor materials.
A list ?
Anything with silicon in it good enough?
I posted a definition from a document I found that proposes what matter actually is. If it is correct, in my opinion it is relevent, but that's just my opinion.
I respect the content of your thead though. I think we can all asume semiconductors are a factor.
You said
If you look at this diagram it supports what you say. In my opinion anyway.The proton and electron are resonant structures and tuned into the standing scalar waves as well as an infinitude of others. See Global Scaling. These structures of mass are already sustained and supported by the gravitational/scalar standing waves that run the universe. They are tapping the aether directly.
If you want to tap the eather directly then why not use a doped Plate "p". in a capacitive arrangement.
CheersLast edited by Farmhand; 11-21-2010, 06:20 AM.
I think this part in bold is important, ever heard of a north pole motor and wondered, why not south pole? There are obviously people who already know and use these principals." All mass is formed by a contraction of the electric poles of the generative cones of energy to the point of north of it's gravicative center and by an expansion of the contours of the radiative cones untill they disapear in the plane of the equator."
The application of these principals reaches way beyond being able to turn on a light for free.
In my opinion the Van DeGraff machine uses a continuous doping technique to attract and repel the charges.
Aluminium or other metals can be "Amalgamated" with silicon and other materials. Could an "Amalgamated" and maybe "laminated" ( NPN, PNP ) metal plate be considered a semiconductor? It could be made very big!
If a semiconductor is in resonance with its host circuit. Would it's "grasp on the Eather" be confined to the area of the active region of it's junction ? And its Eatheric flow or current capabilities relaltive to that ?
Heavily doped semiconductors work different to one's that aren't. The flow it just starts ?
I have no idea how you would dope the big plate. Wouldn't have a clue unfortunately. The circuit may not work either.
RegardsLast edited by Farmhand; 11-21-2010, 06:22 AM.
