Originally posted by Slovenia
Don't Kill Dipole
photoshopped pics in pdf file
Hi Jbignes5,
Yes, I can do that. I just hadn't got around to doing that yet. Originally I just made them for myself so I could try to see what every thing was and hadn't thought about others not having the same capability. I'll load them into a pdf for everyone to see. I have run out of storage space on Energetic, so I might have to have you upload it under your name since mine is maxed out already. Thanks!!
Best Regards,
Slovenia
Originally posted by Jbignes5 View PostCan't you put them in a pdf?
I Misqued
Hi Guys,
I screwed up. I don't know how I did it, but I did it. Anyway, Rebus57 set me straight on it. I, Slovenia, stated that Rebus57 had a working device and he said this was not so. I got this messed up somehow and I apologize for that big time. Rebus57 said that his circuit only tested the function of the Gray tube theory and got a baseline for his tube designs also tested to see if 12vdc+ could be used to both build his high voltage and oppose it to produce flow in the circuit all tested positive results (to his surprise) so, he moved to come up with the proper device in the spirit of Tesla using the cosmic signal for input. Anyway, I stand corrected and I will hopefully read my e-mails a little more carefully from now on. Thanks Rebus57!!
Best Regards,
Slovenia
If you use the "best of the batch" you can email them to me directly. I don't have much space left on the forum either.
I've been going over and over trying to understand the method of altering the potential between the two lines. I believe I have it figured out at least partially. It's easier to see the change with the rotating offset variable capactor.
________
Anal BeadsLast edited by dragon; 05-11-2011, 10:55 AM.
Enhanced Pics
Hi Dragon,
I was having a hard time reading all the words on the dark background, so I did my enhancements a lot different than most people. I made them really big, so I divided each pic into about 7 to 9 individual large sectional pics. This way, I was able to see all the details and read most of the words. There are a few words I'll have to run by Rebus57 because I was unable to make them out, but most of the words are very legible now. I was trying to change the background to white, but was unable to do that for some reason. But, they are fairly legible now.
I am in the process of putting together my pdf file now. It's nothing fancy though.
Best Regards,
Slovenia
Originally posted by dragon View PostIf you use the "best of the batch" you can email them to me directly. I don't have much space left on the forum either.
Sorry for the crude drawings
Tesla would not be happy with me for posting such crude drawing's. Sorry about that. First these are my personal notes, the sketch on the napkin if you will, never intended for public viewing but life is never what you expect. Second they are not complete or do not reflect recent changes which I have tried to relay to you best I remember. Third no access to scanner, my friend took the pic's for me with dig cam. Fourth in 5 yr's of explaining this to many people any who understood what I was doing and could have helped said "good luck with that" over their shoulder as they were RUNNING away, I did not believe anyone would ever listen, thank's for at least having a go at it. It's been on the back burner for a while I've been looking for something to hunt for a strong frequency down low so I can proceed with further design and construction, would be nice to have a target frequency to design towards. Finally before you jump to many conclusions and begin asking too many question's spend a lot of time reading theory and comparing to schematic. It read's in order (top to bottom) to follow schematic and sleep on it for a while it will come to you don't try to rush it let it flow "don't kill dipole"! Because this is so different you must clear your mind of all modern theory and listen to this theory and schematic. Let it soak. By the way a diode seems at first glance the perfect thing to use until you realize several things, when using positive against positive a diode will not function, also I don't want half wave going to CCTube we want a polyphase effect between anode's so we have two opposing force's to interact to cause the "breakdown" I'm after. Also this is a very delicate signal we will be dealing with so we must treat it with "kid gloves" in the beginning we can't use a "hard circuit" we must allow "soft flow" circuit design no hard parts, I believe Tesla used resistors as diode's. Finally what might help on understanding the CC and Output tubes operation, they behave like a "leaky capacitor" the CC Tube really is, during operation it is contionusly being fed by crystal device through ferrite's and will be in a constant state of breakdown or leaking this feeds our CC Rod, this constant inflow should maintain the pressure to fill depleting charge on conductors due to breakdown. Thats all for now ya'll behave. Rebus57
Thanks Rebus57
Hi Rebus57,
Don't worry about the crude drawing. I wondered what kind of material you were writing on. It's been fun trying to ascertain what some of the words are on that strange background. Anyway, I think you did a good job of drawing that freehand and I for one and very very happy to be able to have met you and had a look at your drawings and looked at your other information. Thanks so much!!!
You are quite a character too, I like that.
Best Regards,
Slovenia
Originally posted by Rebus57 View PostTesla would not be happy with me for posting such crude drawing's. Sorry about that. Thats all for now ya'll behave. Rebus57
Can you post the original jpg ? I think gif format damage it.Originally posted by Rebus57 View PostThird no access to scanner, my friend took the pic's for me with dig cam.
You didn't compare the output with diode version at the load part only, maybe AV Plug?Originally posted by Rebus57 View PostBy the way a diode seems at first glance the perfect thing to use until you realize several things, when using positive against positive a diode will not function, also I don't want half wave going to CCTube we want a polyphase effect between anode's so we have two opposing force's to interact to cause the "breakdown" I'm after. Also this is a very delicate signal we will be dealing with so we must treat it with "kid gloves" in the beginning we can't use a "hard circuit" we must allow "soft flow" circuit design no hard parts, I believe Tesla used resistors as diode's.
We can not use it to charge battery then?
By delicate do you mean you are using a very sensitive frequency adjustment tuning?
P.I.E. for all !!!
P.I.E., E.I.R. this is the first thing most people are taught in basic electronic's. Now let's have some fun. I needed to decide on size ,(electrically), so I ran a few number's and came up with, if it operate's at 4000 v and tube's and conductor's are sized for 30 amps, 4000X30=120,000 watt's, now this wattage can be used to figure final output amps at final output volt's 120,000w/120v=1000 amps. I figure Tesla's at 50,000w was also 120v this is 416+ amps, 50000w/746w(or 1 hp)=67hp. For his high voltage end I figure 2000v @ 25 amps because the insulation at the time topped out about that also current was managable. Now if we try to up our output voltage say to 277v (1 leg of 480 3 ph) we get 120000w/277v=433 amps WOW looks like mine will be 120v output. Why do you need to charge a battery ? With 1000a @ 120v available from a briefcase size device I don't see the need. Of course an isolation transformer can be used on output and device connected where your electric meter used to be, they most likley will try to stop us with "jammers" so don't be suprised by that, I expect it. also this could be built into every appliance so no cord is needed. Now for frequency. When Tesla first began experimenting with transmission he had real problems, seems the signal would not leave the tower (he was using lower freq) even raising the voltage only made it worse, all it would do is build up and back up into his equipment starting as he put it "numurous fires". This he could not explain. Undeterred he continued on gradually raising frequencies (and putting out fires) until finally he was at a high enough frequency that the effect was not very bad almost none. At this point is where he thought he won against nature and could use this range to transmit his power. In step's the controlling powers and he is shut out and down. Now Moray and friends have found some of Tesla's stuff talking about the harder he pushed on the atmosphere the harder it pushed back, I believe this is where this all started, of course the Moray device was primarily designed as a medical device so it used the beneficial freq. but they were too high and the counter emf from an inductive load would shut the device down, also I don't think his device had a trigger cir. it ran at the freq. of the headwaters. I read where Tesla visited Moray's lab and looked at and discussed the device before he made his. I believe Tesla used lower frequency's because when you push just a little they push back a lot. Tesla's was also a variable freq. output for motor speed control. The signal they were picking up was most likley found during Tesla's Colorado Spring's quest. Speaking of signal NO the tuning cir is not sensitive the signal itself might be kind of weak so we don't want to upset it or make it mad at us. Did someone say seperation? Yes you are right the CC Rod must be a distance from the headwaters to prevent the rod's field from blocking signal to headwaters. This is why the "two meter farily thick rod" was on the back of the car and not on the box. This could have been part of the problem with Moray's all the pics of his device show a long wire being used instead of a rod. P.S. Working on a new plan for schematics thank's for your patience, Rebus57
Good to hear I'm being missed.Originally posted by Slovenia View PostThis thread is a continuation of Lamare's thread, "The Ultimate Secret of Free Energy". The main difference with this thread is that we are not limiting ourselves to either of the three devices such as that of Stanley Meyer, Gray, and/or Puharich. We are looking for simplification of the concept in this thread and want to build something easy to start with and then go from there. We are in the process of trying to come up with circuits that will give us a free energy device. So, feel free to jump in and help us here. This thread is all about building devices to help get us off-grid so that we won't have to pay for our electrical power ever again.
Lamare, we miss you!! We were not trying to steal your thunder with this thread.
Just for all clarity: I don't feel like anyone is stealing anything from me. We are all working for the single goal of providing mankind with the technology that has been stolen from us, because Tesla had all this stuff figured out years ago. So, all I try to do is share what I know or think to know, so everyone that feels like it can work further on it any way he or she may like. Do whatever you like, I have released all my stuff as open source exactly because I want people to be able to do with my stuff whatever they like.
And then some day, some one will come up with something working. When that happens, it would be my greatest pleasure if my article would turn out to be correct and/or would help to convince scientists there really is something to this stuff, so they can no longer pull the "perpetuum mobile" card to ridicule serious inventors.
The reason I have not been here for a while is because I tend to attach too much to a certain subject and then forget about everything else, which means that other things I have to do have not been done yet. So, when I thought I was at a point the principles were more or less clear, I decided it was time for a break. That's all. Looks like there are some interesting posts here I will check out, but I don't want to get drawn into this too much at the moment.
So, just continue doing what you like and make sure to have some fun! We'll get there when the time is right..
PDF File of Rebus57 Pics
I made a pdf file for you all, but I can't get the Energetic Forum to upload the file for me. I tried three times yesterday and already once today. I don't know what gives with that. I cleared out some of my previous uploads so I could upload that. So, sorry about not being able to provide it for you.
