I initially made reference to this device in the F.M. Chalkalis thread in the following three posts:
I see that David (Matos de Matos) has started a thread (http://www.energeticforum.com/103878-post1.htmlYouTube - Dennis Barber Swinging Gyms Hanbury Steam Rally Stoke Prior Fair 19th September 2009
The object, of course, is to swing the cage back and forth until it finally goes "over the top," and continues rotating. It can easily sap all your strength to reach the top, even if you understand how to get it there (which the fellows in the video obviously don't), but once over the top it takes relatively little effort to keep the rotation going, and not much more than that to accelerate it.
As you can see, the human occupant, or occupants, enter a cage at ground level that is suspended in such a way as to always keep the cage in a vertical position, and this is unlike any other gravity wheel design I have seen, where routinely the suspended item or items either swing freely or become inverted at some point in the rotation. I believe this is one key factor that makes rotation with the Swinging Gym possible. Another factor is the positioning of the six suspension arms and counterweights. This becomes evident in the two photos shown below. The first photo shows the Swinging Gym about half way between the bottom and the top of a cycle, while the second shows the unit closer to the ground.
Upon examining the two photos, one can see that each side of the cage is suspended from 3 pivot points (one at the top of the support frame, and two further down, to form a triangle pattern. The two lower support arms are attached one at the front, and one at the rear, of the cage side at the bottom. The upper support arm is attached to the centerline of the cage side somewhere near shoulder height of the occupants (depending on their actual height of course), and I believe this height of attachment is also a factor that contributes to success. The final contributing factor of the build is the positioning and weight values of the six diamond-shaped counterweights seen at the ends of the support arms. Without the counterweights, it would probably be impossible to ever get over the top and rotate. Now of course there must be a"perfect" setting to counter the weight of the cage and its occupants that would allow for best performance, so in a scaled build of this device it would be best to allow a method of sliding the counterweights and locking them in place. I can attest to the fact that I had much better luck operating the device when I was 13 years of age than when I was in my early 30's, even though at the later date I was far more stronger and had more weight for weight shifting purposes. Because of my additional 35 pounds or so, the stationary counterweights were inadequate in weight. It should be noted that the full amount of the counterweights is less than the weight of the cage alone, and that, for this reason, the cage will always seek ground level if left alone. Therefore, there is an initial imbalance, which becomes an even more pronounced imbalance when weight is added to the cage. The imbalance factor is important to retain to some extent, as it enhances the inertial thrust at the rotational arc perimeter.
A human can rotate this device, either alone or with a companion, through use of cleverly and properly timed weight shifting within the cage, so the question becomes whether or not the correct and necessary human weight shifting movements can be simulated by other means that would allow for continuus rotation. Such other means might include mechanical, magnetic, electromagnetic, hydraulic, gravity, or inertial actuated means, or a combination of these, or possibly other, methods. If anyone reading this has the opportunity to use one of these Swinging Gyms, and to take video of one rotating successfully this summer at an amusement park or carnival, please do so and post links here so that we can study the required weight shifting movements in detail. I can tell you that the trick is to always maintain a position within the cage that is closely adjacent to to the outer perimeter of the rotating arc, as this develops the greatest inertial thrust both going down and going up. The operator's position within the cage must begin to shift from one side to the other close to the top, and again near the bottom, of the rotation, in order to keep weight distribution close to the arc perimeter. Also, the operator needs to bend their knees to keep their weight low as they near the bottom, and then extend the body mass to a full height while going up. You can see that either side of the cage has bars that the operator can hold onto. If going down, you are holding the bar at one side, and if going up you are holding the bar on the opposite side. When shifting weight from one side to the other, you hold onto the side you are on with one hand as you step to the middle and reach out to grasp the opposite handlebar. At this point, which should be within 10 degrees or so of the top or bottom of a cycle, you should be holding both bars, and should then continue deliberately leaning and moving quickly to the side you are aiming for. In your arms and hands, it feels like you are actually "pulling" the cage lower as you approach the bottom, and then "lifting" it higher, as you begin to move upward. This cannot be so, of course, but it does give you the feeling that this is what you are doing when you move correctly. And believe me, even when you know the right way to move, this activity can quickly leave you feeling totally exhausted, and will greatly increase your heart rate. My second trial, in my early thirties, left me feeling like I was going to have a heart attack. I was in great physical shape at that time, and a non-smoker. I gave it all I had, which was a bit too much, and had to lie down for about an hour afterwards to recuperate. So let that be a warning. You are much better off to take along a strong young teenage boy of about 100 to 120 pounds, to whom you have thoroughly explained how to achieve rotation, and to videotape his attempt, than to try this out yourself if you are over thirty years of age, over 150 pounds of weight, or not in great physical shape. It is hard to find these machines nowadays, because many states outlawed them after some serious accidents occurred. These were caused by inexperienced users who failed to keep a firm hand hold, and who lost their balance and were buffeted around inside the cage. One can fall against the cage side or bottom with enough force to receive a serious concussion if balance is lost and a firm grasp is not maintained by at least one hand at all times.
Let me know if any of you are interested in building a scaled down replica that could be used as a test prototype. If so, the first step would be to approximate the measurements of the full size version shown in the video, so as to show the scaling dimensions of the build parameters in diagrams. The next step would be to produce an animated demonstration showing the unit in rotation, and then to show the movements that are required by a human operator to achieve rotation. All of this must be defined clearly before anyone can start thinking about possible methods of achieving continuous rotation through other than human powered methods.
I'm already stretched quite thin between my Pipe Dream project and summer rehab projects at my home and cottage (the summer season is short here in Maine), but will attempt to answer any questions, and help to steer others in the right direction. I will also help to approximate dimensions using my own recollections, as well as the video and still pictures, and will try to give a basic starting reference for that in my next post.
Best to all, Rick
Best to all, Rick
