Plasma propulsion / Lifter / EM Antigravity Mini AirCraft
I am not sure. I would try 100K across the multiplier output. Then measure the voltage across the resistor. The problem is that if you do not have it hooked up correctly you may put too much currrent through the diodes and blow them up.Originally posted by TanTric View Postwhere do i put it, and what value do you advice?
i guess my levels of luck are at the bottom... any sugestion to try other connections on the stud/cables of tripler?
im connecting the 12V transformer AC on the brown cable (T) and stud of tripler, then stud to earthground, the G2 (red) is disconnected, im trying ro read some values between HV out and common earth ground... sometimes it shows 0.01V? weird, the transformer is working ok, so maybe damaged tripler, or bad connections? the doubt remains..
EDIT: and how about if the stud is the AC IN? and the brown is the ground? its possible? or can i try to connect between G2 and stud (to ground)?
please advice, dont wanted to BOOM this!
I just had a good close look at the circuit board pics.Originally posted by TanTric View Postso glad you like it harvey!!!
really exited!!
im not lucky with the tripler...
eheh
These are Flyback Transformers:
Flyback Transformer - Google Search
These are CRT Neckboards:
CRT Neckboard - Google Search
What you have there is a CRT Neckboard.
How exactly was the focus pack soldered in there?
I can GUESS that G2 (RED) was soldered at the R2 - C2 pad. But it would seem that the 'T' (Brown) wire was soldered at the Ground pad between R3 and TP3 ???
If so, then that means my earlier GUESS was wrong. So we then need to ID where that STUD was connected and it would be a good thing to know what was on the end of that Blue Wire. If that didn't have the HV Anode Cup (suction cup looking thing) then what you have there may be nothing more than a High Voltage Variable Resistor. Looking at the Neck-board, I can see the F terminal is routed through that ribbon cable, so there is another system for providing the Focus which is separate from your LF0058.
There may be a service manual online for your make and model set that gives the exact wiring diagram and voltages for your specific set.
Cheers,
harvey you were right, i opened the stuff to take my doubts, and is only a strange circuit board with regulators, not any caps or diodes...
will try to get a tripler tomorrow, that was the ideal, if i cannot get one, i will try to input at least 50V at my system, have to get a transformer, or maybe use my 110vac output with some voltage regulator, not shore, naudin have a config that dont use the tripler... just the dc flyback alone...
thank you everyone!!
thank so much harvey and xee for all your efforts, you are so kind person!! thank you from the heart really
Light, I Am!
my lifter
Finnaly my lifter! is nothing special, but it was a very fun project to me...
this one goes specially to jeanna, harvey, jonnydavro, xee, cosmicgnarler, seth, and all the rest!!
wait for 3min to see full power!
Enjoy! YouTube - jujusalva's Channel
Good Stuff Juju!
Interesting corona discharge there (purple) - must be a few sharp edges it looks like. I wonder how it would be if the foil was shaped as a torus, nice round surface
It does a pretty kewl dance there too
hii xee
i just took the aluminium cover of a candle like this one:
i was powering it with a 30V power source (26V onload) wall adaptor, feeding a flyback transformer!!
hugs
Originally posted by xee2 View PostI like your lifter design. It looks very sturdy. What were you using to power it?Light, I Am!
as a torus? sorry dont understanded, can you explain better?
yeap is a pretty good dancer lifter! eheh
Light, I Am!
Yeh, you got your flyback working. Were you using the 2 resistor driver circuit. If so what value resistors did you use.Originally posted by TanTric View Posti was powering it with a 30V power source (26V onload) wall adaptor, feeding a flyback transformer!!
I think you were having trouble with your lifter because it is much heavier than what most people build.
That candle holder is surely a few grams at least....i was using 30KV and a lifter that weighed half a gram.Originally posted by xee2 View PostYeh, you got your flyback working. Were you using the 2 resistor driver circuit. If so what value resistors did you use.
How much does the lifter weigh juju?
