Originally posted by Matos de Matos
F.M.Chalkalis gravity system a donation!
I really don't know what to say other than to try it. I don't have any materials or equipment to work with, so you're on your own. The only thing else I can suggest is possibly the inclusion of a centrifugal governor consisting of springs pushing the weights closer to the axle as the arms slow. That may or may not be a good idea.
Originally posted by Dingus View PostI really don't know what to say other than to try it. I don't have any materials or equipment to work with, so you're on your own. The only thing else I can suggest is possibly the inclusion of a centrifugal governor consisting of springs pushing the weights closer to the axle as the arms slow. That may or may not be a good idea.
HiOriginally posted by Ted Ewert View PostOpen letter to Mr Chalkalis...
Our discussion here has revealed a few serious problems which call into question your claims.
1. The most glaring is the most obvious: If your device actually gained energy, why is it not self rotating? Where does all that extra energy go when the power is removed? There can't be that much bearing friction and wind resistance to overcome.
2. You suggest that the power be taken off the main shaft. Why haven't you simply attached a cheap alternator to the shaft and measured it's output? You have a pulley right on the shaft! Use a 24 volt model and you could run your drive motor and measure how much extra you have left over.
3. Your math proves nothing. Do you know the difference between torque and horsepower? You calculate torque based on a no load situation, then compare it to input power. Apples and oranges my friend.
If you can't manage a generator, it's very simple to construct a Prony break which will give you a fairly accurate measurement of your actual power out.
After working on this concept for 28 years, it's hard to believe you built that whole device and didn't take some simple output power measurements. I see a pulley right on your main shaft for Pete's sake! Why are you withholding this information?
You immediately start whining about people pointing out legitimate errors in your statements, and asking perfectly reasonable questions (red flag). Yet, without answering anything you still want us to go to all the expense and trouble of building a replica just based on your opinion? I don't think so.
None of this adds up Chalkalis, and you know it. We are more than willing to extend the benefit of the doubt, and I think we have here, but we don't appreciate being played for fools.
What is your real reason for doing all of this?
Ted Ewert
Well said, I remember one of these claims that fooled us around was Mylow's Magnet Motor. Of course this is not meant to be a discouragement.
This device seems like a normal pendulum rotating, nothing more, I think that if Mr Chalkalis wants to get more acceptance, he must at least explain what inspired him to build such a device, and why he thought it will work, if he is not willing to demonstrate a closed loop device.
I am 100% sure that gravity is a main source of energy, but has Mr Chalkalis really unlocked the way to extract energy from gravity? I think not.
In my opinion, and according to the work of Victor Schuaberger, flowing water creating a vortex unlocks the energy of Gravity in a type of vortex structure.
Elias
HiOriginally posted by W32 View PostAfter finding that right after a few turns, the force required to complete the rotation is less and as speed increases it gets even lower and also that during the fall between 0 and 180 degrees, in my opinion, there is a surplus of energy,
There is a difference between force and energy, and power.
Power equals Force * Velocity
P = F.V
So if Mr Chalkalis needs to apply less force to complete the rotation as speed increases, it is because the velocity has increased and we need to apply less force to apply the same Power input to the system to keep it rotating. This doesn't mean that the system is extracting energy from gravity or anything else.
And also as Ted pointed out if the system is generating anything useful from gravity, it should run indefinitely.
Elias
My 2 cents worth
I have been following this thread since it was created. I understand how many of you think that this can not work. You may be right but you may be wrong and until you actually build a replica, you will never find out. You may think you know what is going on in this device but remember you are basing your thoughts on conventional science and like i said, this may be correct and the unit does nothing but waste energy. If there was something special to it, do you think it would be in plain sight? Would many of us not have discovered this already? I myself am going to try and build a small scale replica even though i have my doubts.
That great. My delima is a replica of scale will cost some money. Primarly in the base. Concrete, which is the only means to hold that thing place, is expensive. Between the metal lumber and concrete a scale model will cost about $900.Originally posted by Zooty View PostI have been following this thread since it was created. I understand how many of you think that this can not work. You may be right but you may be wrong and until you actually build a replica, you will never find out. You may think you know what is going on in this device but remember you are basing your thoughts on conventional science and like i said, this may be correct and the unit does nothing but waste energy. If there was something special to it, do you think it would be in plain sight? Would many of us not have discovered this already? I myself am going to try and build a small scale replica even though i have my doubts.
I also am trying to get a smaller version built. But smaller does not often tell the whole story.
It would be a dream if it was that simple.
Matt
A 1/10th scale may produce the same results and it would be much cheaper to build. Just divide most of the values by 10 and away you go. Yes, i understand it MAY not tell the whole story but somebody has to try this just so that it can be debunked.
The problem with this device is not whether it can work or not, but how it was presented. Chalkalis makes this big show about giving away to the world the result of his life's work. He makes a web page and a video attesting to his great invention. Naturally, we take him at his word and assume he's telling the truth. We then spend a lot of time and energy analyzing his device in hopes of discovering why it's so special. In the end we find that it is nothing more than a spinning pendulum.Originally posted by Zooty View PostI have been following this thread since it was created. I understand how many of you think that this can not work. You may be right but you may be wrong and until you actually build a replica, you will never find out. You may think you know what is going on in this device but remember you are basing your thoughts on conventional science and like i said, this may be correct and the unit does nothing but waste energy. If there was something special to it, do you think it would be in plain sight? Would many of us not have discovered this already? I myself am going to try and build a small scale replica even though i have my doubts.
Chalkalis never gave us one solid reason why he thought his device could multiply energy. He only gave us faulty math and convoluted reasoning along with his dog and pony show. We filled in the rest of the details with our imaginations.
If his device actually produced extra energy he would have told us right off the bat exactly how it worked. Instead he's been evasive when questioned and defensive about his motives.
At best Chalkalis is confused and mistaken, but more than likely he knows exactly what he's doing. Why do we allow ourselves to get sucked into crap like this?
This is a good drill in gullibility awareness. Don't believe it just because someone says so, demand proof. The truth will always stand up to rigorous scrutiny.
Cheers,
Ted
I think that Mr Chalkalis should be more honest and tell us if he is not sure there is something new here.Originally posted by Zooty View PostA 1/10th scale may produce the same results and it would be much cheaper to build. Just divide most of the values by 10 and away you go. Yes, i understand it MAY not tell the whole story but somebody has to try this just so that it can be debunked.
Actually I had a device resembling a 3-4kg pendulum (approximately 1/10th the actual Chalkalis Pendulum), I gave it a spin. Yes Chalkalis is right, when it gains speed less force is needed to be added to it to keep it spinning. It is because as the pendulum gains speed the effect of gravity becomes less and less to it, and it seems that it spins easier. And of course applying the same force with more speed means more power. So obviously less force must be exerted to maintain the same power level.
Mr Chalkalis is yet to explain why a 60 degree angle between two masses on the pendulum? why a smaller mass at the outer edge, what is its purpose?
Unless I know these things, I will not waste my time on this spinning pendulum anymore, better devices are out there.
You're more outspoken that me in this case Ted, but I can't disagree with a word you say.Originally posted by Ted Ewert View PostThe problem with this device is not whether it can work or not, but how it was presented. Chalkalis makes this big show about giving away to the world the result of his life's work. He makes a web page and a video attesting to his great invention. Naturally, we take him at his word and assume he's telling the truth. We then spend a lot of time and energy analyzing his device in hopes of discovering why it's so special. In the end we find that it is nothing more than a spinning pendulum.
Cheers,
Ted
The build is of high quality IMO, yet the explanation could not have been worse, more mysterious, or more open to suggestion. How can such a skilled builder not explain a random stray dog why this device is OU?
Usually I believe in the good of man, especially if they're prepared to show their name and face. I hope Chalkalis soon steps forward with tangible input. Until then I'll find new reason to not take enough sleep. In my vision, this device just doesn't work.
At least the Abeling wheel had the claim of working asymmetrically and without a motor. Nice website, well spoken inventor with green future prospects, but not the good stuff.
If we'd find out a difference between the 3 (one on the rim) and just one central one, we'd have the equasion for OU. Big IF, is that there first needs to be a difference.Originally posted by Dingus View PostThere is one aspect of the design I don't quite understand, and I assume the only reason it's in his design pictures is to stay as true to what he physically constructed as possible, but why were two weights & arms used as opposed to one?
and this
(long time ago i had the idea to do something like this in the video)
YouTube - magnet motor FREE POWER PERENDEV NO GASOLINE
But you need to see this one!!!
YouTube - LEGO perpetual motion
Others are smarter than I, but I tried to find info on how this is supposed to work, and never could find more than seemingly deceptive technical prova. WHERE does the gravitational energy energy the system, and what does it not hold it back on the way up, doesn't the system lose potential energy of the same magnitude?Originally posted by sebosfato View PostI would like that you check this: YouTube - ltseung888's Channel
What do you think about?
I'm a practical and visionary type of guy. If someone manages to explain to me HOW a sytem works, I feel confident I can improve it, and scale it. Never seen OU so far, or been too stupid when I came across it, to understand.
