Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY
yellow
hi guys,
just want to share the new video of mopozco, measurements on the kapagen, he tested ground also!
with or without coil, the values are exactly the same!
Input: 112VAC X 20A = 2240W for
Output: 1100VAC X 1A = 1100W ,
about 49% efficient.
he also use a light dimmer to reduce the consumption!
quote from mopozco "Better a bitter truth than a sweet lie"...
YouTube - SGG - "tests"
also user vince from OU Forum when testing his 3/4Horse power motor on the kapagen load, and it barely turns!
cheersLight, I Am!
My Kapagen
The best (lowest input power) I could get was 707 Watts lighting 18 x 100 watt light bulbs without using a variac. Not bad but far from romerouk and Naudin.
I measured my power usage with a Kill-O-Meter connect to Mains over 30 feet away from my device.
When I first turned my Kapagen on it used over 1100 watts and the lights were approximately 50-60% bright. After playing with this for a week I got the power usage down to 707 Watts and the lights were at least 90% bright. I did this comparison by having one 100 watt light bulb connected to Mains sitting next to one of my light bulbs from my Kapagen. I agree it's not scientific but it was good enough for me to tell the difference.
I did find that dimmer switches and amp restrictors used more power then they were worth so I removed my amp restrictor.
But the most important thing I found was that the ground rods/connections/Earth was the biggest factor in lowering my power usage. I replaced my copper tube with construction grade grounding rods, applied water to the ground around my ground rods. In my area there is 6-12" of top soil and then under that it's all sand. Sand doesn't hold water very well.
Using Carbon rod and Copper for the spark gap lowered my input power usage by 55 watts.
Here are some pictures:
Kapagen
DonLDon
This is all great info! Keep in mind that Naudin notes that Halogen lamps gave an improvement. It could be that a Halogen lamp will shne brighter with this pulsed high frequency current. Also, Naudin shows us measurements after his variac, not direct from the mains. Also, with the 120 vs. 230 volt lamps the equivilent loop resistance of the lamp string may also be a factor. Did you try to swap carbon / copper polarity? It may work better one way over the other (anode cathode). Much to ponder yet.Originally posted by dllabarre View PostThe best (lowest input power) I could get was 707 Watts lighting 18 x 100 watt light bulbs without using a variac. Not bad but far from romerouk and Naudin.
Kapagen
DonL
RD
I agree the resistance of my 120 volt bulb is a factor and being they are "cheap inexpensive" bulbs it's probably a bigger factor. I'd like to try 9 x 150 Watt bulbs but they are expensive. I kept the carbon/copper spark gap electrodes in the same direction as JLN. Carbon from the MOT and Copper to the Coil. I'll try swapping them the next time along with all the other things I want to test.Originally posted by retrod View PostAlso, Naudin shows us measurements after his variac, not direct from the mains. Also, with the 120 vs. 230 volt lamps the equivilent loop resistance of the lamp string may also be a factor. Did you try to swap carbon / copper polarity? It may work better one way over the other (anode cathode). Much to ponder yet.
RDLast edited by dllabarre; 07-03-2010, 03:50 AM.Don
New Video by J. L. Naudin, dated July 2, 2010 - New Power Measurements
See J. L. Naudin's updated page, entitled, KAPAGEN INPUT and OUTPUT Power
See J. L. Naudin's new YouTube video, entitled, Accurate power INPUT measurements of the Kapagen v3.3
YouTube Video Description: "The purpose of this test is to measure with more accuracy the electrical power INPUT of the Kapagen v3.3. To measure the electrical INPUT POWER, I have used the high end energy meter Voltcraft Energy Logger 4000F connected at the output of the variac. There are 14 x 150 W halogen lamps connected in serie at the output of the Kapagen. I have used a Voltcraft LX-1108 Luxmeter to measure the light intensity of one of these lamps. The total OUPUT power for the 14 halogen lamps is calculated with the calibration sheet."
Eff(%) = 96%
Good Job! Well done!
VIDBID
I also use the cheap 120v lamps (four for $1, lol!) They are good heat producers, some lamps measured 70-100 degrees (F) warmer surface temperature then the control lamp, although they appear dimmer. I look forward to seeing your SG test results.Originally posted by dllabarre View PostI agree the resistance of my 120 volt bulb is a factor and being they are "cheap inexpensive" bulbs it's probably a bigger factor. I'd like to try 9 x 150 Watt bulbs but they are expensive. I kept the carbon/copper spark gap electrodes in the same direction as JLN. Carbon from the MOT and Copper to the SG. I'll try swapping them the next time along with all the other things I want to test.
RD
SR 193 SR193 : New Information
See next three posts for English translation.Originally posted by luno
VIDBID
Kapagen Correct Measuraments
Upgraded power meter on the input now shows no OU... Just a 96% eff...
feel very sad now because i have been correct all the time! it was to good to be truth, or maybe not..
hugsLight, I Am!
The Bedini Free Energy Generator
Energy Transformer W2008103130A1 by Tariel Kapanadze August 28, 2008
Has anyone noticed page 11/12?
Documents considered to be relevant
Bedini J C EDLast edited by chasson321; 07-04-2010, 12:41 AM.
I insist in DC measure
The only way to measure correctly is putting a big battery with analog DC Amp-meter. The inductive dischargers with spark gap create errors beacause one part of the energy try to go back to the source this type of sources are designed to measure consumption output not input.
My critics about this Naundin's test are:
1. This gadget consumes more energy after the variac than before the VARIAC?
ERRATA: ERROR OF MY MISUNDERSTANDING THE NAUDIN'S OUTPUT METHOD:
2. The output measuring method is only for light visible the usefull power without looses only is for demonstrate the total output usefull energy in light form. Lux measure the light but Naudins is not measuring the heat..
3. Halogen lamps are not 100% efficient, the waste in heat form is TREMENDOUS.
Sorry @everybody please skip this comments
4. On this forum like researchers test and experiments clearly shows that heat & light are very differents forms of radiation on different lenght waves and 100% of light is visible?. No; we can create light using the Imhotep method and coil car for example, this light don't produce heat at all. Naudins method produces light and very so much heat, this shows OU clearly.
If somebody knows how contact directly to Naudins to measure the heat output on the bulbs would be awesome.
Additionally:
We can look on Newman motors this motors spin and produce mechanical energy one part of the energy is usefull for recharge batteries but other part of this energy go back to the source.
Another way to measure consumption on Kapagen can be hooking on the cap a oscilloscope but is needed a good protection for the equipment and clips 100x is recommended then we can measure the frequency on the cap and voltage change so J=VxVx(Cx0.5) In the worst cases cap 2100VAC x 1uf
J=2100x2100x(0.0000005)
J=2.205 watts
If the frequency is adjusted on 50hz :
W=2.205 x 50
W= 110
This can be the real input in the worst case because the cap is not totally discharged and not totally charged, frequency can be changed using the sparkgap. it's very possible eliminate the VARIAC changing the gap larger gap = higher voltage. 10 mm - 1000 volts aprox.
Regards.
Carlos.Last edited by patmac; 07-05-2010, 07:47 PM.Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
Steve Jobs. Apple CEO
i think i can make the test of "real" readings with a 12V battery and my 12DC-220VAC inverter powering the MOT 20Meters away from my DMM and inverter...
then the real consumption should be the TOTAL less the power the inverter needs to work without load!
but is it worth it? this device dont inspire me anymore, dont smell OU to me!
Light, I Am!
