Originally posted by Farmhand
Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY
I think what he is trying to say is that a resonant structure excited by a pulse will resonate at harmonics from its fundamental till the highest harmonic which is not shorter than the initiating pulse. Each harmonic excited will have differing intensity levels based on its relation to the fundamental.
Working Kapagen Replication
Looked at:
which shows a link toCode:http://www.youtube.com/watch?v=nIfl55Vd-sI
Source: безтопливный генератор Романова.mp4 - YouTube
Found very interesting.Code:http://www.youtube.com/watch?v=ET7CrFDs6fY
Berg
A definitive test to determine if in fact 1500 watts (or any actual surplus) are realized from 180 would be to set up a large bank of batteries connected to an inverter which supplies at least 180watt 200v ac. Power a single bulb, and also a D.C. charging circuit back to the battery bank. It would be trivial to determine if the bank was discharging with a simple volt meter. Keep it simple!
Radiation vs. Radioactive rays
If the analysis is correct the Kapagen emits radiation. The analysis seems to be saying the radiation is uniform in all directions. It would not be emitting a directed "beam" or "ray" as in a "ray gun". The analysis, if correct, indicates that the correctly designed and functioning device would definitely and without doubt generate and emit radiation of the beta and possibly gamma types. The part that is not explained is the actual nuclear reactions that would come into play. Also, it is not explained how nuclear magnetic resonance triggers or causes transmutation of copper, zinc or iron. It simply assumes the reader understands that this happens and is possible. I don't know enough to rule it out, but I am only saying it is not within my knowledge and I don't regard it as "accepted truth". If Rossi is correct, then why not Kapanadze? I think this does serve as a warning. I would want to be prepared to measure radiation, esp. Beta radiation and stand well back from the device while testing. Bone up on your physics if you don't want radiation poisoning.Originally posted by Guruji View PostGSM and Dave Interesting info. Is this true that this can emit radioactive rays?!!!!
ThanksThere is a reason why science has been successful and technology is widespread. Don't be afraid to do the math and apply the laws of physics.
In that sense every electrical device emits radiation the big question how much. Yes it would be wise to measure but we should be sure that this is dangerous before saying that it is.Originally posted by wayne.ct View PostIf the analysis is correct the Kapagen emits radiation. The analysis seems to be saying the radiation is uniform in all directions. It would not be emitting a directed "beam" or "ray" as in a "ray gun". The analysis, if correct, indicates that the correctly designed and functioning device would definitely and without doubt generate and emit radiation of the beta and possibly gamma types. The part that is not explained is the actual nuclear reactions that would come into play. Also, it is not explained how nuclear magnetic resonance triggers or causes transmutation of copper, zinc or iron. It simply assumes the reader understands that this happens and is possible. I don't know enough to rule it out, but I am only saying it is not within my knowledge and I don't regard it as "accepted truth". If Rossi is correct, then why not Kapanadze? I think this does serve as a warning. I would want to be prepared to measure radiation, esp. Beta radiation and stand well back from the device while testing. Bone up on your physics if you don't want radiation poisoning.
Solidstate Kapagen
Here's an interesting web site on a solidstate Kapagen.
Free Energy: Kapagen Generator
Russian Home-built Kapanadze Unit Started with Hand-cranked Generator
This experimenter cranks the handle of a small generator to charge a capacitor bank, using a voltmeter to check the voltage. When the capacitor bank is fully charged, he flips a switch and a few seconds later three large lamp bulbs light up.
The amount of light output by the lamps is impressive.
The experimenter is able to hold up the unit.
1 KW FREE ENERGY 2013.01.06.flv - YouTube
Download video in MP4 Format
There is a link at the video for more information on it, but it's in Russian.
ANONIMUS 2013.01.28
Of course, I included a translation link for it.
Google Translate
In reviewing that site, I found the following link on it:
ANONIMUS FREE ENERGY / FreeEnergyLT / FreeEnergyLT
Good hunting.
Kapagen with Handcranked Start Generator
I'm trying to figure out the parts of this device.
Any suggestions appreciated.Code:A. Possibly, bifilar pancake coils. B. Capacitor bank. C. Switch or switches. D. Toroid coil. E. Plug and electrical outlet. F. Handcranked generator. G. HV module. H. Flyback transformer. I. Most probably, HV transformer driver. [I]Courtesy, Guruji[/I] J. Output transformer.
CheersLast edited by Berg; 02-25-2013, 04:46 PM.
Wesley's Thoughts on Kapanadze-type Devices
9/11 part#2 OU NO NEED of BATTERY .avi - YouTube
Interesting video by Wesley (stivep1) discussing some of the circuitry of device posted in a video by FreeEnergyLT and Kapanadze's device.
DALY FREE ENERGY NO BATERY !!!!! 2012.09.11. - YouTube
DALY FREE ENERGY NO BATERY !!!!! 2012.09.10. - YouTube
Cheer
2 different devices
Hello
IMHO there are 2 different devices existing using both ferrites.
The one introduced by berg the length of the windings are chosen according to the wavelength. This will only work , if wound very accurate.
And the other one used / introduced by sr193 , tiger , and lately by Fabrice Andre (Refuge de Sarenne) .
This type is shown in the attachments.
The 50 / 60 Hz Input / Output windings have nothing to do with wavelength .
There is unipolar force applied by a spark gap between the inner copper rod and the thin winding / layer on the outside diameter of the rings.
On top of this thin winding / layer the Input / Output windings are wound.
Thats all.
Now I think the ferrites do the job and the material composition is crucial.
Because I replicated a so called 'eternal light' yoke device shown by tiger,
nothing fancy, only a joule thief with a output winding with center tab rectified an fed back to the input. Small needle pulses , a very low power consumption (3mA) but their input amplitude decayed, when operated in loop mode. Since I replicated this with the only difference that I used a pnp transistor , not an npn , I am convinced that the material of the yoke is crucial for function.
Daly Schematic
Daly Device in Operation
Daly Device Schematic
Really, combination schematic and block diagram.
An English translation would be nice.
Daly Schematic (Full Size Image)
Original Source:
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Images of how the coil was wound:
