gravity waves found
  • Originally posted by david lambright View Post
    hi everyone..where i see it is 10 and 11 B,C,D,E...the quarried stone i refer to is behind the tripod... 8 and 9 E thru I..you can tell it came from the pit....what is holding it up?...it is under that stone where i believe i see distortion.....david...edit..can this image be enhanced to show distance to objects, the wall in the far background, tripod etc.?...thanks ...david
    Cant see anything at all personally. But it's only because of my eyesight. I believe there's some computer programme that can 'fill in' on missing pixels, It's some kind of intelligent software that works on probability? Probably? LOL. Anyway I think that's what's needed. Or better eyesight than I've got. Until this morning I could not make out what was standing on the tripod. I thought at first it was a variation of Leedskalnin's PMH.
    • On the tripod shown in operation, seemingly as a regular crane with pulleys etc. Which seems to make little sence when you're moving rocks at will, with anti-gravity.
      A- The tripod may be just something for the people peeking over the wall. It attracts interest, and for many inquiring minds, will offer a conforting answer as to how heavy rocks were moved. Everyone gets a crane with pulleys.
      B- Farther fetched. Anti-gravity (waves, streams) is harvested from a rock being lifted by means of mechanical leverage (tripod). Anti-gravity potential is transferred to another rock, to the point of it floating just over the surface. The "radio" on top of the tripod might have a role here.
      • Hi Cloxxki. Here's that picture I promised. But it's way off true. I took a shot straight off the computer screen Hope it's clear enough
        I also think that the tripod number was to keep the public happy. Had no idea there was a radio on top of it. Is this fact?
        • Thanks for the picture witsend. I'm amazed it all ends up as squares and triangle. I would have expected chaos.
          The mysterious box on top of the tripod, I think was referred to as some sort of possible "radio".
          Ed did nothing without reason, but he worked in mysterious ways...
          Now omagine a bunch of pipes being stacked as in the 4-level picture you just posted. Some spacers might be needed between level 2 and 3, otherwise it's rock solid. Could it be persuaded to lock together mechanically? I am visualizing the current to run for instance counter-clockwise in all squares and triangles.
          • David- Ive coloured/colored in the parts and corresponding shade of the parts, to try workout this picture. At first i was adament that the rock (orange) you suspect as floating was/is on the ground and the darkness under it was rubble or foliage infront of it that the camera picked up as too dark to give detail.
            The area at the bottom of the left most pole is very dark and uneven ground. So the shadow of the pole looks to bend. Maybe the camera had a few issues with this area or there may have been smudges on the lense at time of it taken and maybe why it looks a little blurry.
            I have a few issues with this picture now that ive done this coloring.
            1. The white coloring i cant understand what shadow/shade its come from.
            2. the poles of the tripod dont meet up. This is either the shading where they stop is a larger area than it looks, or its a pit/hole, or this image has been editted before we got to it. For which purpose we can only speculate. But youd expect that the centre poles shadow which is furthest to the right would cast on the rock (orange). because of this i beleive the rock to be much further than it appears or again its an editted picture.
            Ive tried changing the brightness, contrast, etc but the picture isnt of good quality to make any progress in better detail.
            Adie
            Always thinking outside the box!
            ASUS M4A87TD motherboard
            AMD Phenom II x6 Turbo Core 2.8/3.3 Ghz Overclocked to 3.5 Ghz CPU
            RIPJAW 4GB 1600Mhz DDR3 Memory
            Gforce 9800GT 1GB Graphics
            Windows7 64bit OS
            20" LG LCD 1680x1050 Monitor
            • I can't see the edited image (at work). However, looking at the original, the shadow Dave indicated might be Ed's own.
              the log behind the tripod is either pretty far away, indeed further than I initially though, or it's actually hoovering right beind the tripod, within the confinements of the poles' shadows, not such a big rock in that case.
              The tripod looks heavy and immovable. Not useful for loading a truck at least. Would Ed move it for every next block to take from the ground?
              • Originally posted by Cloxxki View Post
                My guess is that the Lambright Glimmer is from the 'inner closed circle' so to speak. Those pockets. I think this field would be shielded from our earth's fields by the 'outer legs'.
                But I don't think that the 'field' effect on those circles is localised into the squares and triangles. I think the 'circles' point to the justification of the fields. Cloxxki I need number symmetries to 'grow' what I call energy levels. 2 dimensional fields. But that's to do with the atomic structure. What the thesis proposes is that some 1 dimensional 'binding' fields hold all those atoms and molecules together in bound amalgams - bricks, televisions - name it. The proposal is that if these are responsible for the casimir effect (proved and required in physics) and if they're also these 1 dimensional magnetic fields - then these are the 'thing's that vary how matter is formed - arrranged - crystalised or not. The puzzle is how these 'fields' are transferred through space - when they're not 'hot' - as in flame? I can see it in an electric current flow. I can't see it away from this. But I know from work done in these and other forums that it can, indeed, be transferred through space without a direct path. I am reasonably satisfied that Dave is accessing these hidden conjoining fields - this 'glue' in the Lambright Effect. But still lots of questions.
                • Adie - blown away by those details on your photos. I tried that upload and failed. I'll see if I can get one of my friends to do this for me - in due course.
                  • Spock narrates Coral Castle
                    Found this interesting..
                    Coral Castle - Spock and In Search Of... tackle its secrets • videosift.com
                    TheTruthBeKnown
                    Dr. Hazel Yacty
                    • Originally posted by witsend View Post
                      Thanks, but it wasnt that hard to do
                      Thanks Catlady, ive seen this one before :P
                      Windows7 64bit OS
                      • If you have not already watched this, then please watch the youtube videos from this guy:
                        YouTube - JONDEPEW's Channel
                        Looks that he has cracked the code, but is not giving anything away, just hints. But maybe someone here will get something out of this based on the knowledge gathered in this thread.
                        Hope this helps.
                        • Hi David,
                          I'm still interested if the device you constructed and it's effects has anything to to with any specific location similar to what I have already done for you and Jetijs with your close proximity to the areas of possible negative flux lines.
                          I see the thread is getting very long now which can be troublesome for members and guests to wade through some of the totally off topic postings so I propose this.
                          Anyone doing a replication that wants to participate and have their location plotted to see if replication devices are location dependent they can PM me or e-mail me at FuzzyTomCat@yahoo.com with the city where the replication is, and I will send them back a image of the closest location of the proposed flux lines to them.
                          This way if the evidence is there it could be posted if felt it's relevant to the thread and this could help keep the thread "on topic" or limit the postings for this.
                          It's good to see so many people actually making a replication or "COPY" of your device to try to see the effects, don't be disappointed though with the "mavericks" making devices not even close to what you have made ..... a replication is just that ..... a "COPY" ..... they'll figure it out .....
                          We'll have to set up a time when I can come down to Salem and observe what you have ..... maybe even a "LIVE" broadcast !!
                          Best Regards,
                          Glen
                          Open Source Experimentalist
                            Hope this helps.
                            Golly Jet. This is intriguing. I can't make out the magnets but think they're floating over an inverted glass dish. Is this right? Then the magnets themselves seem to be constructed in layers - somehow. I wonder if the glass is standing on a metal surface of sorts and that's some kind of path for current conduction that's dispersed across that surface. Strange in itself if this is the case. If so then it seems that the glass material does something to the field to concentrate it. I think it's clear that the experiment is run at room temperature - because I think that's a typical room there.
                            Very puzzling. Also puzzling are those bands separating the magnets - again if that's what it is. It's irritating that these guys don't let on what they're doing. Why all the secrets. Unless he sees a way to capitalise on this. I went to his website and got further irritated because I couldn't adjust the sound. And then I saw the inevitable appeal for donations. I wonder if people pay him to find out? That would also annoy me. But the use of all that glass brings me back to Leedskalnin's coil around a bottle number. Maybe there's something in that silicone mix that's required. SO MANY QUESTIONS. Look forward to hearing some results from your tests there. How are they coming on?
                            • Hi witsend
                              My tests are going slow. I was visiting some sensitives and dowsers today and many of them confirm, that the device is emitting standing waves around it no matter what direction it is rotating. Only as it changes the direction, there is a wide beam like energy flow upwards for a while and then it is all standing waves around again, I guess it needs some time to set the surrounding aether in motion or something. My current setup seems to be stronger than previous devices, but the strength manifests itself as a bigger field, not a stronger field in the same area. Now the field can be sensed in about 5m radius from the device. Will get some dowser info soon about the material of the wheel and if tool steel would be a better choice, but so far it seems that it is, because tool steel can be magnetized to remain a strong magnetic pole and Leedskalnin had some decent poles on his wheel, I think that these permanent poles in combination with the magnetic lock could give interesting results. To verify this I tried to attach magnets to the poles in my current wheel in NS config and the energy flow was getting stronger according to the sensitives, also it was observed that a hand could be moved upwards easier than downwards in the field of the wheel, so something interesting in that config. I guess neo magnets in my current setup are too strong and I am not certain on how they affect the magnetic lock, might be that the too strong magnets are preventing the lock from happening. I don't know. But if tool steel is used with its own permanent magnetic poles then those poles shouldn't work against the magnetic lock, but instead the combination of the magnetic lock and the permanent poles might do something interesting.
                              Tool steel is rather expensive, If I can get the laser cutting for free, then the material is gonna cost me, about 200$ for three 10mm thick and 200mm diameter wheels. I will wait for the dowser info on the material and then decide if I want to spend money on the material. Also I still have to put the three wheel setup on the rotating platform and give it a real spin up to some 3000RPM
                              Jetijs
                                Hi witsend
                                This has been mentioned before. I think it was Bruce. Am open to correction. He and his friend saw clear evidence of a light beam emitted.
                                WOW
                                I can't quite understand this. Are you changing the direction of those magnets or are they still like the earlier drawing? Is there still a nn/ss number there?
                                I'm inclined to agree with this. I'm sure Leedskalnin managed to get a strong field there.
                                WOW. That's some speed. That really would be interesting.
                                Dear Jet. I cannot tell you how privileged I feel and I'm sure that we all feel when associating with this level of expertise. Truly a remarkable experimentalist. I get it that there are the inevitable disappointments. But it seems that you're equal to this. Many, many thanks for your input. I am entirely engrossed in this phenomenon - on so many levels. The route of dowsing is such a sensible choice - dealing as we are with such subtle effects. What intrigues me - endlessly - is that curious magnetic property that the rig seems to illicit from such a wide variety of materials. It's unmistakable. And that's even with my own variation which is clearly inefficient on every other level. And nor does it need to spin. But I agree that Leedskalnins number definitely spun - somehow. Otherwise why all that need for all that cement. If that's what it is. LOL. Again. Endless puzzles.
                                Hopefully we'll hear more from Dave. Between the two of you I'm satisfied these questions may yet be cracked.
