gravity waves found
  • I agree but why not try...
    Originally posted by sucahyo View Post
    Ok. Look forward for the test. Mine around that size too and the effect of a single rock is much greater that the effect from anyone PMH. But there is someone else that have nothing with quartz around the same size. If you have nothing then your rock is dead.
    Plant may get influenced. But since the effect looks weak, we should not expect significant change. If you intent to try it with plant, notice which side that produce / void of bubble that you will be using.
    I would assume that the bio connection is a strong reaction not weak to this field. Much like the water is a strong indication when it freezes to what is going on inside of it. But I want to also say that it might not change the whole plants, meaning that you would be hard pressed to see the deviations because the plants grow on the whole aspect. I suggest they would conduct more of this natural field and channel that through it's whole structure raising it's potential. We need to have a control aspect also. A second batch of bio material well outside the field but in simular conditions down to even the amount of water should be measured and the dirt should come from the same bag but equally put into the two containers.
    • Has anyone seen those copper colored staples that are really big. You could use it to hold large wire in wood. They have a shape similar to the ford magnets. They are not pure copper as once you cut them you see different materials on the inside.
      Staples | Electrical Materials Company
      I wonder if these could be used as prebuilt pieces. They are not tall, but would be easy to assemble.
      • Has anyone thought of spot welding the pipe pieces together? That way you get good electrical conduction. Or does this mess something else up? A good welder with tips made to fit in the slots could tack these together well solidly.
        • hi everyone...
          just a little thought....my oxide core devices radiate an energy....so inside, from what i know about wave theory, there should be a standing wave......just a thought...david
          • Originally posted by david lambright View Post
            A potential or a wave? What kind of wave? If it was magnetic the compass would oscillate. Is there a way to detect a gravity wave?
            • Originally posted by Jbignes5 View Post
              I am saying that PMH effect on water is much weaker than a single rock. So we should expect that it would have weaker effect on water based living things too.
              Leedskalnin put very big rock on his PMH. Anyone want to ice test the Leedskalnin granite?
              • hi all
                aside of my going on icing pmh testing
                i made some very interesting test to SEE what is going on here
                please enjoy this basic video on human aura power
                comments are of course apreciated
                good luck at all
                Laurent
                YouTube - human hand power 1
                • Originally posted by woopy View Post
                  hi all
                  good luck at all
                  Laurent
                  Hi woopy,
                  Good example of what is called a mind motor.
                  Some are able to move it with their thought/intention.
                  Now place a glass jar over it and see if you can duplicate the movement.
                  IndianaBoys
                  • an email from tom 7/14/10
                    2 attachments (total 3.8 MB) http://www.energeticforum.com/newatt...5d443553d6c94#
                    DownloadDownload
                    View slide show (2)|Download all
                    Check out the attached pictures and feel free to share them with anyone you want to
                    Im not going to post them because some blog basher would start asking me questions about something i know very little about ( I feel for you dave ) Don,t let them bring you down
                    Now that this device has been charged for a few weeks the waves seem more visible
                    Its kinda like if I try to look to close I cant see it as much. I think the brain tricks itself because it knows its not normal, kind of like when you look at spinning spiral video and everything is wavy after but in reverse
                    Im still looking for something good to mount it on and give it a spin
                    Anyway Ill let you know if I find anything interesting
                    Tom
                    ...i do not know how to post pix, i could email them......david
                    • Hi David
                      i do not see the attachements in your post.
                      Hi Indiana
                      i checked with a plastic and a glass jar over the device and it seems there is no chance to work.
                      But in open contact it works and it works also with my right hand after holding for a long time my big icing experiment.
                      So, this device is so easy and fast to replicate that i will wait untill somebody else did try it before going on any discussion .
                      Good luck at all
                      Laurent
                      • Re Woopys last video & "Mind motor"
                        I hate to burst your bubble folks....but its not the mind making that paper move or any other weird supernatural force...
                        its a well known effect....called convection. the heat from the hand makes it spin
                        sorry.
                        • Hi Rave
                          Thank's for comment
                          As i said in my previous post, i will not discuss this thema with people who do not replicate the device and correctly test it.
                          I say this because i was very surprised when i first made the experiment.
                          I also immediately think it was a air convection effect. But the question is how it really works. And i tried a lot of different config and i did not grasp what is exactly going on with this device.
                          For instance :
                          Why , in the same condition, does it work very well with the right hand and almost nothing with the left ?
                          How can it be a convection when my hands are almost frozen ? In this case the cold air should go down to the table and the device should not spin or spin the other direction ? But it spins the same direction and as fast as with ambient temperature.
                          Why sometime it begin to spin immediately and sometimes it does not spin at all ? Or better sometime it spins well during some turns and than stops, while sometimes it spin long time continuesly, without any movement of the hands.
                          So i do not say or speak of any surnatural force here, but an interesting experience perhaps not so "well known".
                          And anyway i repeat , it is so easy to replicate, that it is well worth to try perhaps only for fun.
                          And in this topic "gravity wave found ?" we are all looking for something very unusual but surely not magic but natural .
                          Ok i hope somebody will take the five minutes work and perhaps we can begin a discussion, here or on another thread.
                          Good luck at all
                          Laurent
                          • hi everyone...
                            woopy...the attachments are photos of toms replication...i do not know how to post pix but i could email them to you... my email is david.lambright@hotmail.com....if you are interested....david
                            • hi everyone....
                              please re-watch my videos in 240p mode.... please try this...david
                                I am afraid that if you video a still black surface, and play it at 240pix, it will turn all psychedelic. Downside of video data compression.
                                I've seen the Lambright Effect at various video qualities I think, once you know what and how to see, it's obvious. Just very suptle.
