  • #76
    @Inquorate.
    Originally posted by Inquorate View Post
    @ jonny - that inductor on receiving coil is vibrating in resonance with the peak RF being broadcast by the transmitting coil. If you had 2 different uh value coils in transmitter and receiver, it should be less bright. Try seeing if 2 of the same receiving inductances draw from each other, they shouldn't.. Just like many tuning forks in sympathetic resonance to one struck by hand. Great work as always!
    I think you are right.I tried different inductors and the lights are brighter when the same tigger coils are used for transmitting and recieving..
    I also added a 2nd identical recieving circuit and the leds lit up bright on that too.jonny
    @Cosmicfarmer.Great video and fantastic light show.WOW.You are very creative both with a camera and electronics.Loved it .
    That is a fair number of leds you are lighting and you show the benefit of getting the balance right.One thing i would try though is adding a croc lead with a small metal mass attached to the negative leg of the last led in the string.This should get the 100 led board stable and may make them brighter if thats possible.Jonny
    @ mutten.Hi. So glad you are trying this and good idea with the homemade trigger coil and sgate.I may try that too as it seems far easier than joulethief torroid winding which is a pain.See If you can get one from a camera or a 4kv from electronics shop.Jonny
    @Lidmotor.
    I tried your latest experiment using the second trigger coil on the wireless circuit and I got the same results. I noticed that the arrangement of the pans effected things and the base pan (like you showed) is basically the tuning element of the circuit. Proximity of the base pan to the output pan effects the amp draw. I tried using just round 6" pieces of aluminum foil instead of the pans and got it to work also. Surface area has something to do with this with feedback method I think. The large turkey pans work the best for me so far. More energy output happens for less energy input.
    I havn't tried the cell phone charger yet but I ran all my experiment yesterday on 5 volts to see what happened. The circut runs fine on that.
    Thats good news.Thanks for confirmation. The pan positions are important and the base pan amp adjustment makes it tunable which is important in finding the best frequency for light and input power.The alu tuning strips is a good idea and i bet we see some great ideas on this. I too have a greater output with the alu trays but can't fit them all on my worktop so i use the small pots which makes it easy to mess and change things but they still give a good output.
    It is great that others are adding their ideas to this and i am amazed by their creativity.
    I got some new croc leads for xmas so there is a santa. Regards jonny.
    @Amigo.Hi.Welcome and thanks for sharing your experiment and findings with us. I do not have a scope so would you say the waveform is similar to what you would see with a SEC 15 OR is it different again?and what is your input in mA?
    Your use of a wire wrap on the hv coil is an interesting trigger method.
    With regards to transistors.I am still on my first.I think this is very much like Dr Stifflers SEC 15 with tuning being important as i have found that you can run this circuit on 140mA and the transistor gets hot and then tune it down to say 60mA and the lights are brighter and the transistor is not hot so it is easy to overdrive the transistor for no performance gain.
    That "funny" stuff on the positive and negative rails is pretty useful for wireless as it is nearly as strong as the main output so by adding a couple of extra trays you can have a very large field but it would be great if we could figure out a way of utilising it for charging.Happy experimenting.Jonny.
    • #77
      @ Jonny - good to hear that a second identical receiving circuit doesn't detract from the first
      I was thinking about the space requirements of all the trays, and pictured a plastic cd stacker. Or I suppose someone might make a balsa wood tower. One transmitter and several receivers.
      It would be interesting to see if we could provide a light tower that self charges with this circuit.
      • #78
        Simple Field Strength Meter
        Not sure if this will help with the ways you are simulating L&C with the Al masses, but if you want to see the effect on the field, here is a cheap and very effective way of doing it. It can also be used to study your field geometry and energy levels and lobes if present.
        YouTube - DIY Coherence Field Strength Meter
        • #79
          Running on a one AA cell phone charger
          @ Jonny
          I tried my one AA cell phone charger out and it ran the oscillator just fine. Mine has a blue indicator led at the end that lets you know that it is on and it gets brighter when the pan oscillator starts up. The 'back wash' of energy effects the cell phone charger.
          I finally got Dr. Stifflers towers to work on this last night and eliminated the pans. I used the tower with the leds on it at the output and the other tower is the base receiver. Tuning is done by moving the towers nearer or further from each other just like with the pans. I still have to jump start it.
          @Amigo
          I tried the wire wrap around the trigger coil idea and that worked but the amp draw was too high so I didn't go any further with that. Maybe a pot stuck in there would help.
          @ Mutten
          I'm glad to see you working with this. Without your help way way back, I would not have been able to make my first SEC. You walked me through the steps and and I got there.
          Lidmotor
          • #80
            Field strength meter
            @ dr Stiffler - Thanks for that, I'd not thought to chart or plot the field with a strength meter
            - interesting to note that the field effect is polarized, and thus converted by the np of the diode better when it is facing the right direction. I'm still trying to work out why that makes the field stronger beyond that point
            @ all - I bet we'd have some success directing the field with a metal slinky mounted on a board
            • #81
              I took a photo of the spectrum of my circuit - sorry the angle is a bit off. I held the camera a bit high and not dead on, and used macro as I was close to the screen.
              This is 5MHz per division, see lots of harmonics, that main peak is around 17-18 MHz, before it was 20 but I might have changed my feedback wire a bit.
              In this configuration my current draw is just under 50mA.
              This is for now, I'll take more photos tomorrow to show a different setup and different spectrum altogether...
              • #82
                Thanks Dr
                Watched this one and the
                'DIY Modifications for an 18-1 Board'
                Received 500 white led's yesterday
                I think I'll go mod one of my 18-1's and light a few of them (+_+)
                Mike Klimesh
                Live to experiment, Experiment to live (+_+)
                • #83
                  Freezer,
                  Would you be willing to post your schematic with the second transitior ?
                  Timm
                  • #84
                    @amigo, this is great! Question: How does the output bandwidth (in general) compare to an SEC?
                    • #85
                      250 transistors showed up at my door
                      Observations.
                      I tried wrapping enamel coated magnet wire around the transistor, and oscillations were extremely hard to start and very feeble, dying randomly if I moved it.
                      Then I used some multi strand radio shack hookup wire that must have about 30 individual wires, and wrapped the same number of times around trigger coil, but further away because of size limitations. Oscillations started up smoother and were stronger, but still feeble.
                      Then I wrapped the wire around the coil itself after I moved the coil physically to allow room for the wire, and found that oscillations were indeed stronger still and more stable.
                      Assumptions.
                      I assume that the stronger the signal your base wire feels from the coil, the stronger ON the transistor goes, with more amp draw and more stability. The less signal received by the wire, the less amp draw and more fickle oscillations.
                      A sweet spot of distance and wire type must now be figured out.
                      I think that some distance from the coil is needed to attenuate the signal so amp draw can drop, however too far away and oscillations are finicky. Maybe using multistrand wire one inch away with 5 or so wraps might be in the ballpark we are looking for.
                      Multistrand wire would be like 20+ parallel wraps adding force together where solid core has less surface area for magnetic field to intersect.
                      • #86
                        Here's an old photo of the spectrum of the so-called Cool White Spatial Gate circuit.
                        • #87
                          Ok, thanks Amigo. I see the sharp cutoff on the trigger coil circuit at 15-20mhz or so. I guess it remains to be seen if that loss of high frequency RF (beyond 25mhz) is critical.
                          • #88
                            Originally posted by jonnydavro View Post
                            I also think that the reciever part of the wireless setup is as important and tuneable as the transmitter and by adding a trigger transformer to the wireless circuit,led brightness and distance can be substantially increased.
                            Here is a vid to show you what i mean.Merry christmas.Regards jonny
                            YouTube - Simple SEC 3- Running on Low voltage and wireless circuit boost
                            @Jonny, all
                            Nice thread you started here, and lots of findings
                            I agree with the quote above. With the terms used here:
                            The definitions are here:
                            The video here:
                            YouTube - repeaters
                            and more description here:
                            IMHO you have made a SRPT, a passive SEC repeater not exactly like mine, but the same effect demonstrated, and you have seen the gain, a gain which does not load the transmitter with proper setup.
                            I'm sorry the video showing my setup is not as educative as the standard seen from e.g. you or Lidmotor, but I think what you and I have seen is the same, and it can be seen on the video. Later I got 7 CFL's on with 1.6W supply to a single transmitter, the rest was "un-powered".
                            From the Don L Smith thread:
                            page 3-47 and 3-48
                            The key feature of this device is the fact, that any number of receiver coils can be placed anywhere near the transmitter, and each will receive a full electrical pickup from the local environment, without altering the power needed to drive the Tesla coil transmitter.
                            That is also what I saw and described in the posts mentioned above, just with DrStifflers SECs instead of a Tesla coils..
                            What could be interesting is to ad a transistor to your receiver shown in your video (to make a SECRPT). I guess you will see the same as me - the SECRPT "refreshes" and extends the excited field. A small base "antenna" to the MPSA06 make it synchronous with the transmitter.
                            I have taken other tasks now, but I can't help lurking here, as I like the rest of you have spent many hours on this subject.
                            Let me quote myself once more:
                            I agree on the "mass repeaters" or the SECRPT are worth a study. In my last video the leftmost SECRPT wirelessly operated 2 CFLs, and later I got it up to 3 with a nice amount of light. The single powered SECTWR did not increase consumption by adding the SECRPT with CFLs.
                            I wonder if this is the secret in coming progress, as it may not be limited in voltage swing.
                            I also wonder if a set of repeaters with a certain shape and positioned in a certain relative pattern may bring more magic along with more electronics.
                            Maybe one or two insulating rods with "pans" mounted as pearls on a string, masses right size and right number of masses connected appropriately could make a device with nice output. Maybe by adding a simple phase skewing circuit to some of the transistor bases could aid in creating an amplifying geometry of masses.
                            So several similar SEC circuits (your way or mine) are the way to explore this further.
                            Eric
                            • #89
                              Actually I mentioned in my previous post about taking a photo of a different spectrum using this circuit. I haven't had a chance to do that yet but hopefully tomorrow morning I'll make some time and you will see what I mean about "different"...
                              • #90
                                That's great, can't wait to see it.
