improved circuit
This circuit seems to be fairly fool proof. It even survives hooking battery up backwards. Works from 3V to 9V battery or cell phone charger (will light neon with 1.5V battery). It has a lot of output power and will light a tube wirelessly (not as impressive as slayer007 does it though). I have built this several times and it always worked. It also works with a lot of different coils. The circuit can be used to blink 7 watt 110 volt filament bulb using a cell phone charger. Based on slayer007 and k1zm designs.
assy drawing: http://www.overunity.com/index.php?a...0;attach=43008
assy photo: http://www.overunity.com/index.php?a...0;attach=43009
wireless tube photo: http://www.overunity.com/index.php?a...0;attach=43011
blinking 7W 110V bulb video: YouTube - 7W 110V bulb
EDIT: This circuit is not so fool proof after all. The TIP31C will overheat if power supply can supply enough current. A resistor of a few ohms should be put in series with power supply when not being powered by cell phone charger (which can not supply high current).
The fool proof two transistor circuit I posted turns out to not be so fool proof after all. The TIP31C will overheat if the power supply is able to supply high current. A resistor of a few ohms had to be placed in series with the power supply to prevent overheating. The resistor is not required with the cell phone charger since it will not supply sufficient current to overheat the TIP31C.
I finally decided to push the edge of the envelope and ran it on the light of a table light with a solar panel and then one small button cell.
