Well this is weird.
I'm getting 100 volts on the scope when I touch the top terminal of the reverse direction Tesla coil which is acting as a receiver, 300v when I earth it. I can light fluorescents between the top and earth, although just resting the wire on the topload is sufficient, but when I put my hands near the crocodile cable going to the fluorescent it gets a lot brighter, and input current goes down from 60mA to 50mA. If I actually grab the cable [edit] (the insulation, not any metal) then I seem to turn from something that adds energy TO the system to something that drains energy FROM it, the light gets dimmer and the current draw goes up. In fact it goes completely crazy when I move my hands around the top of the receiver coil.
Similar effect with an AV plug. I rest a straight piece of wire instead of the coil or loop of wire on the top of the receiver, this causes the input to go up to 100mA, but the LED comes on and the fluorescent gets slightly brighter. Touch one of the diode ends, and suddenly the LED gets a lot brighter, so does the fluorescent, and input drops back down to 50mA
I'm getting 100 volts on the scope when I touch the top terminal of the reverse direction Tesla coil which is acting as a receiver, 300v when I earth it. I can light fluorescents between the top and earth, although just resting the wire on the topload is sufficient, but when I put my hands near the crocodile cable going to the fluorescent it gets a lot brighter, and input current goes down from 60mA to 50mA. If I actually grab the cable [edit] (the insulation, not any metal) then I seem to turn from something that adds energy TO the system to something that drains energy FROM it, the light gets dimmer and the current draw goes up. In fact it goes completely crazy when I move my hands around the top of the receiver coil.Similar effect with an AV plug. I rest a straight piece of wire instead of the coil or loop of wire on the top of the receiver, this causes the input to go up to 100mA, but the LED comes on and the fluorescent gets slightly brighter. Touch one of the diode ends, and suddenly the LED gets a lot brighter, so does the fluorescent, and input drops back down to 50mA
.I will try it on my Bedini exciter next and let you know how it goes.Cheers and thanks.Jonny.
There's some amazing information in Eric Dollard's and Peter Lindemann's old videos. Thanks for reposting.
