    the following is a video posted in 2006 show the concept of serial ETBC,
    input 3W charging 100UF TO 300V in about 3 second and discharging this to 40W/220V light bulb, i don't claim this is an over unity device but at least it's very important... until now only two people replicate this design... , Dwane and another person i know , in my opinion it's a learning process .. people on these energetic forums are doing a fantastic job since they have the willing to share what they find ... others already has something that work but they are quiet .. they only interact with big idea to get more but everything remain proprietary .. the problem is still human not scientific ...
    like fighting in a cave of gold who has the proprietary while the process is natural .. the nature still amaze us to teach us but unfortunately stupidity is still around !
    Hi Med.3012,
    couple of things. One, when I work out a suitable power supply for the ETBC, i shall have another go at it!
    The other "thing", is the notion of proprietary information. If someone has come up with a FE solution, the likelihood is that if it is any good, it will be suffocated in some way. Supressed, and etc. It sets a precedent too for the notion of greed - that is a direct benefit from other peoples forum contributions/ input. However, the biggest issue is the parochial notions of the Energy producers of their unique place in society as an Energy Supplier, therefore, they are the good guys. Regardless of what they charge for the supply of power or, as is quickly becoming a global concern, the method of power generation.
    One would think that, as an example, that if Don Smith's devices were replicated and subsequently distributed throughout the world, then this would be cause for celebration! Climate Changers would be celebrating and consumers would be celebrating. The only ones not celebrating would be the small disproportionate number of energy suppliers to the populations that would financially suffer. And, literally loose their power!!
    It is also possible, that a scenario could develop where communities would interact with their power supplies to either aggregate their energy and or be able to supply other member power if and when maintenance would be necessary. And so it would go, etc, etc ad infinitum. But, how would this revolution occur? Simple. plain straight out consumerism -"I want one too!!". Once this concept is realised all that need to happen if for the manufacture and supply and sale of the units which would be enabled for reverse engineering.
    No secrets! Sure some people would make some money. Not every person is able to construct items. Think of all the new trades and small enterpises that would develop. It would be a cascade of innovation the likes of which would surpass anything that has preceded our current progress. The key result would not be a redifining of the economic power of energy supply, but, a redefined socio economic outcome where evryone benefits!
    Too idealistic? Too altruistic? Well if I work it out, everyone will know!
    Dwane
      Try to use different bulb Med, it will make you happier then pulsing the discharge. Single filament LED will stay lit with DC only.
      Please understand I am not trying to slight you, and have the utmost respect for your work.
      My point is that it is still the exciter you are focused on. I don't believe it makes sense that there is some configuration that will work so well it will power a house.
      What I see in several examples is D.S went straight from his NST to his HV diode bridge, so this effort is the wrong direction from my point of view.
      The cap has to be filled, and then discharged... or does it? Well that is the strange landscape that the AEG starts to tread. From the summaries, the cap is seen as the power source, but it maintains it's charge because you are only feeding one side. This is what we don't understand, how a capacitor can maintain it's charge but also produce energy.
      • Originally posted by ilandtan View Post
        Hi Ilandtan,
        Isn't that highlighted in the link you have provided?.. I have been giving this a thought and try to look things at a different angle.. avoid the math and just focus on the logic.. I remember that I have read that website before.. but re-reading it again made a lot of sense.
        the cap is maintaining it's charge because of the Inductive discharge.
        since you are feeding one side of it at the same moment of the inductive discharge charging the same side, you are getting an increase in voltage.. this what we call resonance.. its not really producing energy it's just that the initial energy you put there before is not totally gone yet... so its stacking..
        I agree with you that very few explored the magnetic aspect.. I haven't realized that until you pointed it out.
          Hi ilandtan, here is the classic item where it appears the NST directly drives the device.
          Dwane
          • Originally posted by Dwane View Post
            Dwane
            But in your example Dwane, he is again going through a coil structure .... then it's the old wrestling with achieving resonance. Focus will be the struggle with that.
            My point of view is to understand the transformation... not get stuck in that resonance rabbit hole. If resonance was the key, it doesn't seem apparent in some of his work.
            Look At these Devices:
            NST > Diodes > Capacitor
            These devices show no resonant coil exciter, its just NST to diodes. The fist image is again incomplete. The second image is important because it shows the second module...output coil, and how to get there.
            I have proven you don't need resonance coils to run REAL wattage loads
            [VIDEO]https://www.youtube.com/watch?v=GZXptSTUoZE[/VIDEO]
              Hello !
              no problem at all , i think we have to listen to each other ...the exciter is important but the key remain in the geometry itself , this is why i am still working around the ETBC as a special coil capacitor , the latest model describe it as a compacted Tesla wireless transmitter / receiver is the most important model until now , :
              the following transformation allow the ETBC to work as transmitter and receiver both at the same time :
              because we are able to send / receive it's easy to take power without disturbing the oscillation mechanism , in other words you can replicate power with radio frequency speed , you disturb the ambient and you take copy of the available power while the electrons change the spin direction ...
              the problem is we still see only one direction : the cap is seen as the power source, but it maintains it's charge because you are only feeding one side
              the ETBC offer both directions ... this is explained in my thread ..
              another important thread related to this is evostars thread :http://www.energeticforum.com/renewa...e-coil-11.html
              the ETBC is an extension of the famous Tesla bifilar pancake coil , in one side it produce a deflected magnetic field ( right angle component ..) , it has a capacitive geometry , it's an open coil , the electron spin ... , much higher frequency ( Dielectric waves may involve casimir effect ) , lorentz force is there .
              we want something that work in practice but we have to see all the possibility , failure after failure may lead to great success ..
                Hello !
                I believe we do have to listen, and be honest. If you saw me going down a road that appeared to you that it was a dead end, would you tell me? I would want you to tell me if I was wasting time, since neither of us I assume are immortal.
                Regardless of the geometry, I can replicate your results without the ETBC, with a different exciter configuration. My whole point is that the exciter is trivial. With 400+ pages of forum on this thread alone supporting me.
                • Originally posted by ricards View Post
                  Hi Ilandtan,
                  Ricards, I am trying to understand your statement "the cap is maintaining it's charge because of the Inductive discharge". Can you please explain that in detail. I can't pretend to understand. And I really want to understand. A resonant exciter will definitely do a better job at at producing output with minimal loses from energy used in the input.
                  I think what you're saying is that you simply are using less of the bucket of stored charge in the capacitor; as long as you can replenish the cap again you have a viable power source that is the cap.
                  How I harnessed this magnetic portion is simple. I took a slayer coil, which is self resonant(so no worries about coil length and ratios..i.e., math) And stuck a ferrite core, which acts like a concentrator of... MAGNETIC, not electrical. Wrap a harvesting coil, and boom you can harness that power. It maybe close to over-unity, but I wont make claims for it.
                    I believe it's a collective work and collective success or failure .. i am doing my best to show my point of view , practical investigation will tell .. 400+ pages can be compacted in a simple drawing if we find the correct solution ..
                    we have at least 6 related device to the ETBC all work in different ways ..
                    ETBC ( closed CD ), ETBC ( opened CD ), S-ETBC, M-ETBC , ETM , D-ETBC ..
                    the D-ETBC show the complexity of such geometry but with the help of Tesla we could find a solution !
                    regards
                      [QUOTE]
                      Hi ilandtan,
                      I have tried to assess, with my non xray vision, what might be at the centre of the coil I posted of DS, I suspect HV diodes. This unit also acts as a receiver, as Don demonstrated when he "shocked" himself.
                      The issue of resonance in DS's devices, is to my mind, an efficiency process. I have calculated, looking at the antenna on this device that it must be running over 500Mhz: although I do not know the impact of the Metglass core on the frequency attenuation. However, my xray vision is unable to exactly determine the antenna length for a really accurate calculation!!
                      The outcome of the resonance in a DS device, to my opinion, is exactly similar to that of your Hairpin example. The fact that DS has such a high operating frequency enables a greater volume of energy capture. At his frequencies and voltage level just a couple of milliamps per cycle will produce an enormous power output.
                      I stand to be corrected. Thanks for showing us your video demonstration.
                      Dwane
                        Or you could ground the one end of a coil, wrap around a ferrite core the other end to an antenna / topload, make a secondary from that core (less turns), get it close to the slayer exciter.. I did try an experiment like that I remember, but inefficient though my slayer exciter consumes 2 amps at 12v.. and barely lighting a bulb from it.. maybe Its my crappy transformer or the crappy exciter, or both that made it inefficient... but I haven't tried having multiple receivers.. I guess thats a thing to do for me.
                        "The cap is maintaining it's charge..." think of the sequence of a resonant circuit that dies slowly...
                        Cap Discharging = Coil Has Magnetic Field
                        Coil Has Magnetic Field no more current, It will collapse..
                        Magnetic field Collapse (Inductive Discharge) = Cap Charges (other side)
                        Inductive Discharge Charging the Other Side of the cap..
                        Then..
                        Cap Discharges (opposite direction) = Coil Has magnetic field (opposite polarity)
                        Coil has magnetic field no more current, It will collapse..
                        Magnetic Field Collapse (Inductive Discharge) = Cap Charges..
                        now If you charge the cap again at the same side in this part of the cycle..
                        where the Initial Energy you put it has not died yet,.. your power source will spend less energy to charge the cap at the same voltage..
                        but you know what, sometimes I wonder why there is a inductive discharge when the current is stopped at 0 current part of the cycle... maybe the magnetic field build-up and collapse is slower than the electric discharges... baah much speculations..
                        anyway.. the Coil Length is Important to demonstrate Longitudinal waves along the length of the wire.. I've manage to do this with 12v as it is easy to pulse 12v at khz or mhz unlike a high voltage where power source is the problem.. and controlled frequency of kilovolt range is hard...
                        I could stack batteries to achieve high voltage or a ZVS rectified to charge a cap, but mosfets/transistor at kilovolt range is rare (and expensive).
                        I will try to do with just like 350v or so.. the highest voltage rating of mosfet I could source is 700v..
                        regarding coil geometry.. though I haven't had any experimentation with it..
                        but I think it is important..
                        Google.. "Strongest Electromagnet in the World"..
                        it is achieved by altering coil geometry..
                        let me just add..
                        "Eliminate the notion of 'Charge' in your head"
                        or rather
                        ".. 'Charge' is a state of matter.. not a thing (matter)"
                        In my experience it is much easier to understand electricity this way.
                        https://www.youtube.com/watch?v=eQGd_jYYfqQ
                        an interesting experiment by russ.
                        • D S Observation
                          Hi Guys,
                          It is easy to see how one can become slightly disoriented with the Don Smith use of the electrical system to explain his methodology.
                          I have been going over his observations and there are two stand out observations that I feel applies to the present discussion. 1) magnetic resonance; 2)Magnetic impulses produce electric field and Electric impulses produce magnetic fields. These concepts are applied to high frequency high voltage pulses, such that a continuous stream of orderly energy can be drawn continuously from any one of his resonant systems.
                          Sound too easy. For one, I am not sure that I understand the working concept of "magnetic resonance". Unless it is the single application of current to an inductor. From, I would assume a non electric source, of which I can only think of two sources. One being eddy currents, requiring a non air core and two, something such as Klopsteg's thermo-magnetic effect - massive current though a large inductor using heat. Impractical for the purposes here. If it is eddy currents, then DS talking high frequency air cores is throwing us off the scent! (Or leaving an out of left field clue!)
                          I leave it there. I am still reviewing The Don. I am also wondering if the Heaviside component is incorporated here somehow as well as coil shorting! I am also aware that there is much more technical expertise here than myself who has to read and reread information several times before it gets even close to scratching the surface.
                          Dwane
                            Hi Guys,
                            Dwane
                            HI !
                            there's some smart observation behind DS effect :
                            there's no electric component without an equivalent magnetic component, this is why there's an electromagnetic waves .. you disturb the electric and it invite an equivalent magnetic ( current ) for free !!!
                            the magnetic resonance waves is faster , faster than light , this mean he worked with radiant energy , radiant energy is the cause for earth to grow , these particles make the inner heart of earth to keep warm .. to harness this power we need radiant energy, it's easy to feel your hand getting warm when you touch a plasma globe , the plasma shake the molecules of your hand so you feel the warm ..
                            now to take the power from the earth or the air we need to shake it with radiant electricity..at this point as the electrons exist in doublet it's easy to separate them so you have volts X amps = power !
                            the symmetry is needed to divide each group according the charge they have , positive this way , negative the other way ... right angle component produce such phenomena since we have Lorentz force.
                            at this point the most amazing electrical instrument is the capacitor as Tesla stated !
                            regards
                              Ricards and Dwane,
                              From my experiments, If you take a ferrite core and place it in a slayer, you can harvest two different types of energy. I would say it is important such that you can see electrical and magnetic and actually harvest them at the same time, or independently. If you wind multiple pairs of coils.
                              1. HF-HV AC - If you take one wire from a winding and put a low wattage incandescent bulb in series to Earth ground it will illuminate. If you place a diode in series the bulb does not light to ground
                              2. Pulsing DC - If you take and put a 60 watt LED to the two leads of a winding it will pulse. If you add earth ground anywhere, it wont influence the response (however if you create a counterpoise with the battery, and Earth ground, this configuration may affect the pulse cycles as the proximity of the ferrite core to the slayer... you can actually place it on the top and create output
                              I know that Magnetic resonance is not understood, nor is it written about in power context. The Tricity patent gives a little bit of explanation, you might look that up. All you will find in google are the quantum energies relating to imaging, because they use huge coils in an MRI to excite magnetic responses to cells that they can detect, then plot them in 3D.
                              I believe for the most part, that magnetic travels along side of electrical resonance. What that means for us is if we create an electrical resonance in coils, it should be close to magnetic resonance (I read somewhere Tesla thought they had to be slightly faster than C ). However, their parallel nature for the most part is useful for designs because our coils are small. From what I can understand you can measure the hertzian with a scope, but you are not measuring the teslian wave which are scaler. D.S said you detect the scaler waves in the RF. This is supported by experiments where using Tesla Coil transmitters can penetrate a Faraday Cage and therefore not hertzian.
                                HI !
                                I would like to add to Med's insight, by saying electrical and magnetic components have equivalence, in presence but not in terms of quanta, just saying they appear together in the electrical context (but not in equal portions). Obviously if there was a hard relationship that wasn't breakable, we need to pack up and close down this thread.
                                My theory that I'm trying to prove now, is that you break that relationship by decoupling that relationship. That is done by resonance, and resonance means radiation of the scaler (Magnetic) component.
