Hi Med
Here is an additional entry from an experimenter who has
been able to replicate Don S. device once. The repeat
replication is turning out to be his latest.
I will buy one from you Marc
That's one.
Here is Marc
Marc Belanger 7 hours ago
Hey Mikey,
I too started with Don's original pdf, however, I do not totally agree
with a few things, one of them being the calculations because
he continuously changes his tune in many of the articles , q&a
interviews and post pdf files which are now obtained by reading
the previously posted zilano papers. Zilano supposedly has
successfully recreated Don's devices and say he did so incompletely,
not sharing in it's entirety the tru calculations, however, he
always refers back to Don's calculations written in his pdf.
The part I have a problem with is the wavelength calculations as a
divider of 247. He changes his tune by telling his audience to just
wind ten turns. If w do what he says, it brings us to the mhz
frequencies, whioch he clearly warns us to stay away from,
however, he does tell us this is where the exponential increases
in amperage are.
He says one thing, then reverts to another, always countering his
original story.. I think this is because the spark gap will take
the low frequency and revert it's output to the Mhz output.
Here is why
I say this. I created a tank circuit by buying a Barker & Williamson
RF coil, the model 3033 which is 70 uH, 10 inches long, 60 turns
and 3 " in diameter. The NST I use is a solid state NST that is
10kV max and 5kV rms. It offers a ground input, and, I use this
to attempt the output Don has by grounding the terminal to a
Non electric connected ground rod which has no direct connection
to the electric grid's neutral and ground. In fact, my ground rod
has 6 ohms difference to this ground I am using. I connected
the spark gap to this terminal, and feed one side of my L1 coil
to it. Then, I take the 2 outputs of the NST (the high voltage wires)
and, I connected the diodes (HF HV Diodes good for
20kV and 200 MHZ).These are identical to Don Smith's diodes.
I first test the NST to get the ourput frequency needed to tune
the coil. I connect the hv leads of the coil together through a
spark gap. I get 34khz with my hv scope probe. I also connect
the coil the way it needed to be wired to test the coil's running
frequency and I see the frequency changes when I introduce
the spark gap and the diode as Don did.
I then ensure the B&W coil is the primary, not the secondary,
reason why is because of the capacitor size needed to make
the primary resonant at 5kV in the 30 -35 khz range. According
to Don's schematics and the size of his primary, this can not
be the frequency, so, I dug a bit further by calculating the coil
inductance by diameter and length, amount of turns, etc.
by using Daycounter Engineering's coil designer calculator
which is free to use online. I come up with a specific
inductance, and, I compare the sizing of the B&W coil to
ensure accuracy., then, correct the differences to find
an accurate calculation per size, gauge and materials used
for the air core. Anyway. I check his sizes and calculate
this to find his frequency is in the MHZ, not khz, this is
because of the spark gap and pulsation of the energy into
ground, not the coil. The coil merely draws in aetheric
energy to assist with the mirroring of cold electricity forced
into the ground, which is called Tesla's Phase Conjugate
Phenomenon that Eric Dollard has proven to be true and
effective. This allows for many mirrors of the energy driven
into the ground to come back to the system through the
ground in an abundance of waves of energy that we can
induce by building these coils, and, use the ground as a
return to pick back up as many duplicates of the energy
as we want, from the ground as a neutral. The energy
comes back exponentially all depending on the frequency
generated in the initial stages of the system. When we
place a diode to cut off the negative swing of the wave,
we only have a positive swing upward and it is good to
produce an infinite amount of mirrored energy, meaning
that if the flux of the coil broadcasted far enough, we could
stick an inductor resonant to the drive frequency and pick
up the mirrored energy, store it into a capacitor and draw
the massive amperage out of the cap, combine it with the
voltage tapped from the coil and have a very substantial
output as Don had.
There is a lot involved to duplicate this, and, I actually got
the output correctly on my first try making exactly the system
Don built, however, my attempts to make it larger and more
powerful failed miserably because I wanted to light up more
than 6 bulbs, I wanted to run several hundred bulbs!
I did not know that all I really had to do was build more coils to
set next to the original coil, tuning them to pick this energy up,
and, when I took the system apart, the coils I have been
trying to reproduce failed to be the same. Since I took the
original apart., I have never read the inductance of it and
when I try to rebuild it, it isn't the same. I went as far as
buying the $150 Barker Coil and it still was not exact, so, I
have been trying this over and over to get back what I lost
unsuccessfully. I am retrying this all and will now do so
using Don's frequencies I have obtained by calculation now
because I didn't think of it earlier, however, I have only
gotten to the point where I finished just the primary coil.
Tonight I am going to complete the secondary provided
I have the correct capacitor, and if I do not, I will have
to order it from Allied...
I took (3) .1uF 10 kV caps and tie them in parallel with each
other, then, connect them in parallel to the B&W coil to
resonate at my NST frequency, which is 34khz. I tested this
with my function generator at 34khz and it is in perfect
resonance. Once step up, it runs down, one step down,
it goes down, so, I am right there, as my calculations
worked perfectly.
Now that I have this coil completed, I found that the weight
of number 6 awg solid copper is exactly 4 times the weight
of # 12 awg. This means that Tesla took a larger conductor
like a #6 and wound his secondary to maintain the wavelength
needed to create a mutual coupling in resonance between
the coils. This would mean that if my coil is 580 inches long,
that the output or l2 coil will need to be 145 inches long. I
can now do this by weight because if my primary and
secondary weigh the identical weight, I know they are
4 times different length due to the weights per foot listed
on Southwire's website!
This is how I am going to do this, however, my frequency
while operating now that it is wired with the spark gap is
in the MHZ, not the khz as I thought it was. I need to
ensure all coils resonate at the same frequency to
function correctly.
If I have as many windings as possible at 4 times, I have
to ensure the spacing between the wires is the same
percentage as the distance between the coils. This will
allows for a correct transformation between the primary
and secondary. So, 4 times the spacing will be the distance
between the coils diametrically. This is the key to
receiving an output I found originally and it i the missing
data we need.
I also need to ensure the output voltage corresponds to
the length of the secondary to get the correct output so
I could tune the output frequency or change it to DC, then
dump it into a cap bank and invert it for ac use at 120v.
I will eventually get it right, then, I am going to make an
ebook and sell copies of them cheap so all could
build this.
Marc
That's one.Here is Marc
Hey Mikey,
in amperage are.
Here is why
output as Don had.
worked perfectly.
function correctly.
data we need.
build this.
Marc
