Originally posted by level
agree with Meyls opinions and methods on some things.
The Faraday cage will not stop the transmission I don't think because the
energy is transferred via the wire which will pass through and into the
Faraday cage anyway.
What size mesh would be needed for 800 KHz as compared to the mesh size
for 5 -7 MHz ?
The higher the frequency the more difficult they are to match, I used variable
capacitors and tuning inductors on the transmitter primary and the receiver
output coil as well as tuning inductors at the base of the secondaries.
I used three coil transformers (with extra's) and close coupling primary to
secondary. I am able to run small motors, light LED's and small incandescent
bulbs from the receiver output coil as well as light fluro's in the hand at the
transmitter or receiver or wired into the connecting wire between the coils
240v incandescents will also glow there. More than one receiver can be used
and it need not be identical as long as the resonant frequency is compatible
but the energy is shared.
My transformers are 10 turn primary 150 turn secondaries and 250 turn extra
coils powered by a 12 volt battery and driven now by a PW and frequency
adjustable single mosfet circuit.
In my opinion if the Faraday cage still allows the transformer to receive or
send it is confirmation of Tesla's principal of ground currents using the
connecting wire to penetrate the cage, and nothing to do with "Scalar waves".
I'm still not convinced that the term "Scalar waves" is even valid or sensical.
For the cage not to interfere with the tuning of the coil it would need to be
big and some distance from the HV part or (the terminals) of the
transmitter/receiver to avoid loading the coils that way.
Just my opinion.
