Here is update on my current quest for Lenz less transformer.
I managed to reverse current draw when load is atached. So now it is reverse from conventional transformers behavior..
Here is the resonant circuit I tested:
The scope showing INPUT amps and volts:
The scope showing OUTPUT amps and volts:
You can calculate the rest..
P.S> Now the next step is to try MOSFTET instead of NPN transistor and try add push-pull for full wave output. Also the current was measured over 1 Ohm resistor.
