Hi folks !
Nice to see this topic is getting back at the right track.
@JoeFR
Very good our friend.You have done an impressive work there.
I wish more goods to come at your research.
@Ghazanfar_Ali
Hi Ali &
here.
Thank you very much for sharing your research results with us all !
Well, I thought it is better to not complicate topics so I just started a new topic
dedicated to your work, here at energeticforum.here is the link:
Hope this helps to clever out things about your research,given the fact that this topic
here is for Don Smith devices. Althought they have many common points.
Anyway. Thank you and Best Regards from me.
Re: Kacher NST
Hi Xee, Farmhand, Kajunkreation, Thelast, Woopy, Editor, Peculian
Thanks for nice words
Farmhand
Is the transistor heating less with the different kicker coil and with the secondary loaded ?
I tried 1 turn feedback coil but it not works so good. The circuit consumes between 0.8 - 1Amps 20 - 24Wats so transistor on my big CPU heatsink is only slightly warm.
There is room for improvement I just give the start up point
Kajunkreation
Do you have anything to measure the voltage on the secondary?
I already burned one nice Osciloscope. I am waiting for HW probe then
I could measure the output voltage.
It looks very high, have you tried that with a collector circuit?
No not yet it will be nice if someone else could try it because I have some
other things to finish first.
JoeFR
Video
I am unable to watch this video. Is the link good?Originally posted by Ghazanfar_Ali View PostReplication of my earlier device "AliGen" by Duff
Input is 62.5 W approx and Output is 100W approx. (1.6 times the input).
AliGen-01.avi - YouTube
Edit: I got it to workRick
This is what I use.Originally posted by joefr View PostI already burned one nice Osciloscope. I am waiting for HW probe then
If you can not find a 10M resistor, you can use 1M and 10K. Or better yet, put ten 1M resistors in series to get 10M. Total length of the 10M resistor needs to be greater than length of spark your circuit can make. Also, you may need to go direct to 10M resistor rather than using terminal block so that there is no spark across the terminal block terminals.Last edited by xee2; 05-16-2012, 04:25 PM.
I'm sorry, I dont mean to be negative, but I'm not seeing 100 Watts of light.Originally posted by Ghazanfar_Ali View PostReplication of my earlier device "AliGen" by Duff
I made this little video a while back just to show it doesn't take much to light these bulbs.
120V 75W Bulb @ 20W - YouTubeRick
Thank you for comming here and bigOriginally posted by Ghazanfar_Ali View PostReplication of my earlier device "AliGen" by Duff
I am very much happy to see a thread here with your name bro.
Kind regards,
D.JLast edited by DilJalaay; 05-16-2012, 10:10 PM.
Each may contribute what one wants. You are free to contribute as much or as little as you desire, without regard to the content.
Whether what you present is welcomed depends on the message, who is giving it, and who receives it.
The work is as important as it is, though not all important.
The tempo and direction of this thread changes as often as it does and has.
Do the best you can.
Contribute your best, and we will all do well.Last edited by vidbid; 05-16-2012, 06:03 PM.Regards,
VIDBID
First let me pay my respect:Originally posted by Patrick Kelly View PostHi Ged,
Thank you for that post. I was aware of the 1800 comment but, unlike your post, it didn't convey anything useful to me. You have just opened up a whole new vista of investigation and I thank you for that.
In passing, there is no need for a single 10 kW device as many people don't need anything remotely as large as that, besides which, there is nothing to stop you having more than one lower power device in different locations in a house. One kW or two kW should be quite sufficient and it might well be cheaper to build a lower power unit, so it could well be a good strategy to start small and add extra units later on.
Just a thought,
Patrick
the PDF that got me started and I am still learning a great deal from.
Sir, I am presently researching how to build a simple solid state version.
And yes, 1kW would be good in multiples.
Behind the scenes I have gathered massive amount of evidence and information which I am applying in building such a device.
Don gave us good leads.Yes he did.Several times.The NST he said was a solid state device.He showed us over and over.
The secret is in the joules = 0.5 X C X V squared X F squared.I suspect that, if you knew how, you could modify and INVERTER.YES, an inverter to be an overunity device.HOW? The switching circuit that gives the 50 or 60 hz. must be changed to say 50 kHz or higher, then use metglas or ferrite core transformer with THICK windings a BIG CAP (and remember resonance) and a good ground to get your electrons rushing in to greet you.THEN you can use your dividers and bridges to correct.
I tell you this, I have been studying inverter schematics and to me its just pure Don.
I also looking at booster circuits,marx avalanche,charge pumps,dc to dc converters,power supply systems,electronic tranformers.
What got me started was when I found out that all I need to do was to pulse 12 volts at a certain frequency and a big cap to get good amounts of power.Super Caps anyone?
What I have said is just the tip of the iceberg.I will continue to experiment however and post my findings when necessary.I aspire to be featured with a working device in your pdf in the near future.
Thanks for the tremedous work by everyone on this and other forums as without their input I would not have been were I am now.
Best regards,
Ged
Hi Stoker I assure you if Don did not do his hard work for others and kept everything to himself even you would not know about this circuit.Originally posted by stoker_x1 View Post
Many people want nothing more than just a golden key. They rely on the hard work of others to hand then a finished product.
So thanks for others who share their knowledge egoless.
