Originally posted by zilano
Interesting. It is possible that one could observe that the theory would be such that the effect is enhanced by material and diameter, among other factors, including but not limited to frequency, voltage, the type and number of separated, insulated ferrite rings, and the length and diameter of the slotted copper tube.Originally posted by zilano View PostHi woopy!
try inserting iron nail, alluminium wire, and understand its effects. the more thicker u insert has an effect.
rgds
zzzzRegards,
VIDBID
From Post #4590:
Originally posted by zilano View PostWell Mr. Dragon has already showed u all the practicality of 3 plate cap. avramenko u all know. I have specified the coil structure and preocedure to charge cap using avramenko in don device. i have also specified the method with ferrite rings to convert hf to usable dc. making dc is easy and best coz u can attach invertor to it.
remember charges move from ground towards hv/hf put ur circuit between ground and plate of capacitor to hf/hv. where as in don case one can use avramenko/3plate cap. try to understand 3 plate cap. do some experiment. and when u know how it works everything will become clear to u. once u know how circuit working it become so easy u can juggle any in anyway u want. either its moray, don, kapanadze they will all be very clear to u.
make a small device. start on small scale andwhen u understand how energy travels in circuit u can go for the bigger.experiments can even be done using 1.5 volt to 12 volts. try to catch energy from ground. and feed back this energy to input . if u able to do it by understanding well then no problem will come in ur way. u can ask more questions regarding 3 plate cap either with Mr. Dragon or me. or even Mr. Woopy. first understand principle where this energy coming from?
ask questions and get answers.
rgds
zzzz
It would seem that Woopi's and Capindres' experiments with ferrite rings produced some sort of result.Originally posted by zilano View Posti have also specified the method with ferrite rings to convert hf to usable dc.Regards,
VIDBID
Well I couldn't get a MOT to work. So far the ignition coil is the only thing I can get to oscillate. I really do think all these low powered circuits are more in the
exciter catagory.
For those discussing Back emf.
Transformers Part 1 - Beginners' Guide to Electronics
I realize there are differences in how an resonant and/or air cored transformer operates as3. How a Transformer Works
At no load, an ideal transformer draws virtually no current from the mains, since it is simply a large inductance. The whole principle of operation is based on induced magnetic flux, which not only creates a voltage (and current) in the secondary, but the primary as well! It is this characteristic that allows any inductor to function as expected, and the voltage generated in the primary is called a "back EMF" (electromotive force). The magnitude of this voltage is such that it almost equals (and is effectively in the same phase as) the applied EMF.
compared to a cored transformer, many of us are using cores though in HF
devices.
If the primary cannot or does not reflect what is drawn from the secondaryWhen you apply a load to the output (secondary) winding, a current is drawn by the load, and this is reflected through the transformer to the primary. As a result, the primary must now draw more current from the mains. Somewhat intriguingly perhaps, the more current that is drawn from the secondary, the original 90 degree phase shift becomes less and less as the transformer approaches full power. The power factor of an unloaded transformer is very low, meaning that although there are volts and amps, there is relatively little power. The power factor improves as loading increases, and at full load will be close to unity (the ideal).
the flux in the transformer will fall without replenishment from primary current
flow and the effective output will be reduced. Because the flux is maximum at
idle If a phase shift is maintained so that the primary does not reflect what is
drawn from the secondary the primary cannot maintain the flux at near
maximum. The effect of this is a reduced output a fixed output with the
primary input always at maximum or a transformer with almost no input and
very little output as well. Any free energy will not come from the transformer
itself. Not as far as I can tell.
If you have a transformer that has 10 watts input and drawing 1 watt does
nothing to the input, it means very little except that if you try to take 50 watts
from the output you will only get 10 at most. So far I see no example of any
different happening, without transmutation or similar, meters tell lies and
trying to determine output by lights is an exercise in self foolery.
Of course people can do as they please, I do.
It's easy to spread idea's for things that look interesting, but not so easy to
prove claims or even demonstrate conclusively 1 watt more output power
than input. To run regular devices we require real energy delivered by real
power, which is measurable by regular equipment.
Idea's are a dime a dozen.
Oh and I have never ever seen Tesla refer to any so called "cold" electricity.
The cold electricity is a catch phrase, I think it was coined by EV Gray. Not
certain though. I don't even recall Don mentioning it.
Here!Originally posted by vidbid View PostInteresting. It is possible that one could observe that the theory would be such that the effect is enhanced by material and diameter, among other factors, including but not limited to frequency, voltage, the type and number of separated, insulated ferrite rings, and the length and diameter of the slotted copper tube.
Трансформатор Зацаринина - разоблачение - YouTube
Russian inventor Zazarinin invents such secret transormer and now the secret is opened!
Possibly Kapanadze use the same - transormator Zazarinina and inside - just one wire - to harvest energy!
how simple!
Similiar princips of Zazarinin transformer
The same prinzip have used russian researcher Tiger - he used youke from TV (ferrite ring spleated to two part - he used the same!!!!! No ****!
here is video of tiger's device!!!!
Unknown Cold Current from Tiger's experiments - YouTube
If there is no gain in energy it is just a novelty. What are the in/outOriginally posted by Ganzha View PostHere!
how simple!
measurements and why is there none ? I also got a waveform from a copper
tube inside a coil and I can light stuff from a core of a transformer as well.
Is the energy input by the function generator ?
But- Is it useful ? Is it free energy ? Most of us don't speak anything but
English so we don't know what his claims are. Can you elaborate ?
@GanzhaOriginally posted by Ganzha View PostHere!
how simple!
Thanks for offering that input.
Yes, that is a very good video. I have seen it before. At first, when watching the video, a viewer would think that the blue cylinder is a coil; however, at the end of the video, the demonstrator does a reveal and shows the viewer that the blue cylinder is really made up of several ferrite rings and a slotted copper tube.
The written description beneath the video calls it a трансформатора Зацаринина or a Zatsarinina Transformer, though it doesn't appear to be a transformer in the traditional sense of the word, as most transformers usually have primary and secondary coils.Regards,
VIDBID
No! it isnt! This is device to harvest cold electricity, before harvesing - we should produce extra power! Zazarini's transformator is just a part to get load!Originally posted by Farmhand View PostIf there is no gain in energy it is just a novelty. What are the in/out
I mean - in Tiger device he is wrong in getting output - he use simple zilindrical coil (solenoid) that is in outer layer or ferrite tube, but he need put a wire or nail inside ferrite tube - that is a SOLUTION!!!!!Last edited by Ganzha; 05-06-2012, 01:34 AM.
I wonder what Delamorto is possibly not showing us in his video but possibly showing in his schematic. Reference Post #4383. Question: Is his tube that his Tesla coil is wound on comprised of insulated ferrite rings?Originally posted by Ganzha View PostNo! it isnt! This is device to harvest cold electricity, before harvesing - we should produce extra power! Zazarini's transformator is just a part to get load!
It's possible that experimentation will reveal the answer.Regards,
VIDBID
how to produce Extra Power - so called cold electricity?
I think when we use HV devices we are getting extra power during the process, some extra power getting outside direct into our HV devices but this energy is not usual electricity, so we dont know about that and thinking that impossible, even when could mesure that in Neon transormers output more that input!
If we got Zazarinin transormer we can start new experiment more effective - to know that we could get or even "extract" cold electricity by this strange "transformator"! I mean we got new knowledge that should or may help to build successful replication and even to invent our own!Last edited by Ganzha; 05-06-2012, 01:52 AM.
@Garsony
Thanks for offering your input
Conversion is the $64,000 question.
We need a process that works.
How do we come up with a process?
We have to have a theory.
Who comes up with a theory?
Do we have a theory that we can test.
Can we come up with an experiment to test the theory?
Experimentation is crucial to understanding.
Can we use experiments to develop new theories?
Can we enhance our understanding with theories and experimentation?
And so forth, and so on.Regards,
VIDBID
From one side Woopy said when he used only one ferrite ring (in his last video) he didnt get success, from other side Tiger talked me that he use ferrite dust to make his ferrite pipe ( he just use glu and catron tube and then fulfill it by ferrite dust) but ferrit's dust was from different types of devices - from tV youkes, rings and whatewerOriginally posted by vidbid View PostI wonder what Delamorto is possibly not showing us in his video but possibly showing in his schematic. Reference Post #4383. Question: Is his tube that his Tesla coil is wound on comprised of insulated ferrite rings?
This question is opened, i need to try use insulated ferrites to make ferrite pipe and then comprise them by glue or whatewer
