Originally posted by Guruji
Hi,Originally posted by Guruji View PostThanks Dragon I will try this and see what happens
Hope that it won't explode
Just kidding.
Apologies if I am way off beam here as I'm not sure what circuit you are using, but if the 247 kHz oscillator is feeding a capacitor which triggers a spark gap, then the 247 kHz will have very little bearing on the frequency fed on to the rest of the circuit. The feed frequency will depend on the voltage needed to trigger the spark combined with the size of capacitor which feeds that spark gap. The resulting frequency can be greater than 247 kHz or lower than it and it is most unlikely that it will be exactly the 247 kHz frequency. The larger the capacitor, the lower the resulting frequency. The greater the spark gap, the lower the frequency.
BingoOriginally posted by Patrick Kelly View PostHi,
One thing to observe is, drive your primary with your signal gen, but put your frequency down very low, and watch the secondary channel as it is fired by the square wave...
The ring-DOWN wave form (you may have to zoom in to 2uSeconds to see it, but the coil will be vibrating at its natural freq, just like a guitar string ringing...
It can be "struck" (square pulse / (sparkgap) harder or softer, but they need to be relative to eachother (in length and/or mass) to communicate and transmit.
But the secondary will ring at the inductance and capacitance you put on it (if its not too much anyway, too much capacitance will lower output too!)
(overdamping)
On Tesla coils for example, you may have a large inductance, (something in the milli Henrys), then in the pico farads for capacitance (being the topload sphere)
ultimately giving a ring somewhere in the high Khz to low Mhz.
My L2 has a nice natural ring and highest amplitude at 1.4 Mhz at 98 Micro Henrys, but my L1 likes to be tuned to 327Khz, using .005uf and adjustable inductance in both L1 and L2 simultaneously with the ferrite rod
All that being said, L1 is also 1/4 length and equal weight of total L2
The point to matching the driver freq to L1 is.... because you use less power and create maximim vibration at resonance when the LC turns into a resistor of infinte Ohmage, all of the power going to simply vibrate it
Almost like an echo trapped in a room, and echoing such that it resists anything in or out of the room...so long as it is maintained
And that is why so little current is used at resonance, cause its the freq, not the power input
...BUT, ultimately its the ring of L2, and L1 cap and spark
Just thought i would add that to Patrick's response
(sorry to preach to the choir so much)
Last edited by mr.clean; 04-04-2012, 04:20 AM.In the beginner's mind, there are many possibilities.
-Shunryu Suzuki
Frequency
Apologies if I am way off beam here as I'm not sure what circuit you are using, but if the 247 kHz oscillator is feeding a capacitor which triggers a spark gap, then the 247 kHz will have very little bearing on the frequency fed on to the rest of the circuit. The feed frequency will depend on the voltage needed to trigger the spark combined with the size of capacitor which feeds that spark gap. The resulting frequency can be greater than 247 kHz or lower than it and it is most unlikely that it will be exactly the 247 kHz frequency. The larger the capacitor, the lower the resulting frequency. The greater the spark gap, the lower the frequency.Thanks Patrick and Mr.Clean for response. Patrick I'm trying the self charge flyback circuit. So it seems it's not that easy to do a formula and put the right cap for resonance. One still have to search for exact resonance; maybe while watching amps out and adjusting variable capacitor is the best way.Originally posted by mr.clean View PostBingo
(overdamping)
Thanks.
Well, you need secondary coil to ring on its own natural frequency and primary is with capacitor for tunning into secondary's 1/4 resonant frequency.Originally posted by Guruji View PostThanks Patrick and Mr.Clean for response. Patrick I'm trying the self charge flyback circuit. So it seems it's not that easy to do a formula and put the right cap for resonance. One still have to search for exact resonance; maybe while watching amps out and adjusting variable capacitor is the best way.
Thanks.
Also another secret is: when you got 2 primary coils and one is running on 1/4 resonant frequency square waves then you apply full resonant frequency in another primary coil on peaks of 1/4 resonance square waves, this is a way for ringing ferrite core inside of coils. That creates very strong alternating magnetic fields. Just beware, this way is proved to be harmful for health due processes inside of ferrite core...
The one of these are our experiment results with ferrite yoke.
Oh crap sorry, thanks for mentioning, i worry about missing stuff
The driver is from RMCybernetics, the PWM ignition coil driver circuit
RMCybernetics - DIY Homemade Ignition Coil Driver
and the PWM/ signal gen here as well...
RMCybernetics - DIY Homemade Signal Generator with Pulse Width ModulationIn the beginner's mind, there are many possibilities.
-Shunryu Suzuki
OMG thats cool, do you have that in a video? love to see that !Originally posted by T-1000 View PostWell, you need secondary coil to ring on its own natural frequency and primary is with capacitor for tunning into secondary's 1/4 resonant frequency.
so you need 2 drivers, driving 2 L1's?In the beginner's mind, there are many possibilities.
-Shunryu Suzuki
Books
Hello All,
With due respect to Soundiceuk,
Listen.I have seen several free energy books in the past.Especially those by Moray B. King.
The common theme among these writers : NO WORKING DEVICES.Only references.NONE.Otherwise it would be on Ebay,I would have purchased a working version by now.Don sold many pdf's,(or so he claims) but I still can't locate one person who has a device I could go view and establish to my satisfaction that it works.So again experimentation remains my best option.On the other hand,I would like a copy,if it would help to left the fog,fortunately, this forum,Kelly's pdf and several other sites have priceless info...
If have erred in my assessment, provide the evidence.
My 2 cents
Ged
What you need to do is type donald l smith into google translate to Russian, then, search on google and youtube, the Russians, namely TheDynatron, HAS done it.Originally posted by Gedfire View PostHello All,
My 2 cents
Ged
Dynatron also has a working Kapanadze, and ALL the DIY info is there too, just its in Russian... no prob. Also we have a new member who IS Russian, beautiful.
Also my last vid on resonance, i think mine is very close to completeIn the beginner's mind, there are many possibilities.
-Shunryu Suzuki
Could you tell me where you found that picture? Very interesting and similar to a design I am working on.Originally posted by Gedfire View PostCongrats Soundiecuk! All the best for you and your family.
Folks, check out this info.I found it useful in broading my understanding of these devices.
The attachment speaks about Ionospheric Energy and frequency.
Ged
hey Tortuga0303, what u working on?Originally posted by Armagdn03 View PostCould you tell me where you found that picture? Very interesting and similar to a design I am working on.
-Shunryu Suzuki
Holy crap, he has already invented what I just apparently re-invented. LOL, wow.Originally posted by dragon View PostChapter 7 page 41, http://www.free-energy-info.co.uk/Chapter7.pdf
Stan Deyo's HEED ( harmonic energy exchange device ), from his patent
