Actually I have an idea.
The problem is I tried to get the attention of the guys to help but you know they are busy on other things. I asked you or peters advice on the item I am working on and nothing came of it. Since then I have tried to get the forms cut by an engineer and I still haven't recieved an answer but I think he is really busy. He does water cutting of materials. Ok since you seem to be responding to this thread so much you look at it and tell me what you think...
I was thinking to implement this would be to bring back the old Radial design for the engine. The Neo's I am gonna start with 42's then go up to 52's. I havent had the time to test this design out yet so the validity of this design hasn't been proven. Since my lamination guy hasn't responded yet getting a prototype will take some time.
It is based off the Leedskalnin style perpetual holder which I found out came from a book in 1842 treatise by Daniel Davis jr. Titled Davis's Manual of Magnetism. Which was donated to the university of california in 1890's.
Now back to the design the radial motor design would have 4-6 of each unit in a circular arrangement. Let me see if my scanner will work and I'll try to scan in my drawing of the ideal arrangement.
Ok the scanner worked:
In actuality it comes from Beardens diatribe on what happened to the nasa space boots. If you look at the picture of mine and the one on the webpage you can see that it is exactly what he pictured not including the one side hinge in his picture but the other lamination the "I" is at an angle like i see this working. This is made from manipulating the magnet fields to circulate the way you want with little input compared to the output of the magnets field. It should work and work well by looking at it but until I get a working prototype I will have no idea if it does work.
Since magnetic fields are easier to manipulate with this aparatus you don't have to figure out how to circumvent them like you would with gravity.
Just so you know I never really disagreed with your concept it was the example you gave that I disagreed with. Comparring gravity to electronics is not so easy since electronics has a direct opposite +, -. But gravity has no other component to oppose itself, at least from what we know today.
that is not the correct way by the simple means that wattage changes as you change the frequency. Since the circuit is resonating it is bypassing the lamp and manifesting in the end circuit. Total energy used should be metered before the power supply. In between the wall and power supply to be exact. B
an experiment showing a circuit bypassing the first lamp and manifesting in the second has been shown.That way you know all the variables like losses due to the power supply and cicuit after it. The results of resonance is still power transfered but almost effertlessly. In some cases there has been a unique signature of gain. But I think that is because they are resonating on the target frequency of this Aether/Radiant energy causing a rebounding of the surrounding energy much like a wave in a pond works. When the pebble hits the surface deformation of the surface follows the thrown object down so far then rebounds backup hard. Since magnetics works thru most materials but with different results like resistors act on voltage. It conducts in a wide range of conditions. Iron being the best "channel" being super high conductivity to magnetic fields lower resistance to the fields. The analagy of the pond can further be akin to watching a drum be beat by a drumstick in slow motion. When we strike the surface it rebounds but with resistance (the drum skin). Water being the best example of superconductivity of reaction to the drum being the most or of variable resistance. When the Aether is pinged with a certain resonance it can have powerful effects but the initial ping has to be of great force that the results can be seen and manifest proof. From reading Tesla's notes I can only wonder the kind of breezes and heatpockets and lighting effects he was seeing. But then again he was using such high power levels that it could have been the field reacting to his brains own frequency. Remember the experiments that he did with the exploding wires. The shock was soo powerful that he even tried to shield himself from the effects. Which was a peculiar stinging on his chest and arms and legs. Is what he saw from the effect of putting yourself in to such a high field of energy and thinking the effects were manifesting for real. Or were they real. No one really knows for sure because not one person could duplicate it to a larger extent because the government would be all over them. For the simple fact that they now know powerlines do for in a fact cause injuries the the people living near them. How many are related to the lines who knows but it has been shown to be not so good.
So the ROOWTIW of the tree system is 50.00.
