May 18, 2010 Test Results
I performed a 5-test series on the new rotor magnet layout to see how close the results would be. In theory they should be identical, but of course there will be slight variations, mostly due to the axle bearings. I do believe that all of the human factors have been successfully removed, and the tests do show conclusively that all variations are in a range of less than 1/10th of a second, with most variations being only 2 to 3 1/00ths. Note that the most important column is the Gap time, as this shows the individual elapsed time through each of the 6 rotor magnet group sections on the flywheel. It is understandable that the first section has the lowest Gap time, because there is no reverse attraction from any preceeding magnets to contend with - only the wood of the flywheel. It is also understandable that section 6 has the longest time Gap, because there are only two magnets out beyond the end of the test, which have less attraction influence than the magnets preceeding the end. I believe that if I extend this out with several more magnets, that section 6 will show a reduced Gap time. What is very interesting to note, is that in each test the 5th section has a lower Gap time than the 2nd section. You would expect the 5th to have a larger Gap time than the 2nd section if the rotor is slowing down. Very interesting. So perhaps the rotor is actually accelerating slightly, and in spite of the fact that there are 8 screw heads at the rotor edge striking the lever switches to activate them. While the drag of each activation strike is not substantial, the sum of the 8 strikes certainly has a detrimental effect to the performance. I may just do a nother test with all of the Snap time screws removed, leaving only the Start and Stop screws in place, just to see how much the overall elapsed time would improve. Note that the overall elapsed time of 5.74 seconds in TEST #1 showed a 23% gain in efficiency over the 7.49 seconds result of the previous magnet layout test, by shaving off 1.75 seconds. It would be almost impossible to achieve similar efficiency gains in future tests, but it sure would be nice!
