Healing properties of water
  • #31
    Originally posted by Spearmaster View Post
    @sucahyo - So what would you think about vinegar? .
    Vinegar would be consumed by electrolysis proses. Toxic or not, it is not a good electrolyte since it only have effect in a couple of hours. The existance of carbon would increase the efficiency of electrolysis process but it wouldn't last long.
    The recommended electrolyte are NaOH and KOH. Both corrode different kind of plastic. If NaOH is hard to find, I guess baking soda is ok as long as you throw the air produced some hour after refreshing the solution. It would give NaOH in the end.
    @hhoexclusive - I really also think that if you believe that the water works, then it does, and if you believe it doesn't.., well.., . Sort of like a Joe Cell with the 'Y' factor
    I really wish it is not the 'Y' factor. I think 'Y' factor will work no matter if you believe it or not, depend more on your 'luck'. Same property as emotional aether device.
    I think water with more oxygen should feel more refreshing to us. But from what I recall oxygen do not disolve good on water.
    • #32
      @sucahyo - I have had discussions with my brother who believes that oxygen is the active ingredient in the 'magic water' . He feels that it's necessary to take an anti-oxidant to keep from getting cell damage. For me, it's all the same since I take lots of anti-oxidants anyway.
      Carl
      • #33
        @Spearmaster, recently the hot topic in Indonesian news is the death of people visiting a healing boy. It get so popular that the visitor reach tenth of thousand and become a problem and kill some people because of stampede.
        Each visitor carry it's own water where the healing boy will submerge a stone. The water become energized and can heal people. I have high hope that the healing property of water that we are currently discussed is not the same as that. I hope the method we currently discussed is a result of normal natural occurence.
        about anti-oxidan, would ozone water improve our health too? If it is maybe it is a good idea to utilize our ozone generator (HV side of our radiant oscillator).
        • #34
          ozone
          @sucahyo - here's some info on using ozone to treat water. Now that I think of it, I remember that sometimes the newly finished water will have a slight ozone smell to it.
          Ozone Water Treatment, Ozonation, Ozonator Dirty bad tasting water, contaminated colored water, unfiltered water, bad smelling water
          Carl
          • #35
            Spinning Water Video
            Here's a link to an interesting video showing someone who "spins" water. Try it out - I'd suggest 100 spins, and see how you feel while spinning. Then check the taste. It seems to me very smooth, like ormus water. Here's the link:
            YouTube - A New Cure For Cancer & Everything Else
            Bob Smith
            • #36
              @Spearmaster, thanks for the link.
              I guess utilizing radiant oscillator for either electrolysis or ozonizer is a good idea. We use radiant oscillator as PWM to prevent electrolysis cell heating and the induction generated get amplified using car coil to make corona discharge.
              @Bob Smith, that is interesting video. From the video I conclude that moving elecrostatic (our hand is electrostatic) around a water improve water quality, right? What a coincidence, just few days ago I made a video of moving the water with HV. Aaron said it is electrostatic that move the water.
              YouTube - High voltage can move water #2 vertical shot
              If we use HV to move water I think we ozonized the water and adding electrostatic motion in it at once. Maybe I should try to drink the water that get moved by my radiant oscillator HV. I just wish my transistor can hold the very hot temperature for at least a minute or so........
              Maybe leaving a glass of water inside an open loop coil powered by radiant oscillator HV would increase the water quality more.....
              • #37
                Don't drink the water if....
                Don't drink the water, PLEASE !!!!
                Stainless steel can leach Hexavalent Chromium into the water through electrolysis. VERY HAZARDOUS MATERIAL, known to cause Cancer, birth defects and other health related issues Never drink water that was used from Stainless steel electrolysis with high currents. To ingest anything without at least checking to see if any research had been done is foolish. Lab test are finding many illnesses are being linked to metals that once were considered save.
                Much higher levels of aluminum are being found in lab test of patients then ever before that studies have linked to learning and memory problems. Why? How much more Aluminum is used now in food processing and storage. Have a bag of peanuts and trust the FDA will protect you. NOT !!!
                Please be careful.
                Rectified
                • #38
                  What about the water in the bubbler? Spearmaster drink the bubbler water.
                  About my idea, no part of the cable touch the water. Only induction and HV spark.
                  I notice that in my HV test, spark can form between HV cable and water surface, even without the opposing terminal. Would this water safe to be drink or not?
                  • #39
                    Hi Sucahyo
                    I Would not trust it without sending it off to a lab. Most all HHO cells people build produce water vapor to some degree, and other elements. Lab test have found other elements from the tubing as well. Never use anything other than distilled water and in a sterilized container to create anything for consumption and have it tested by a qualified lab. Life is to short to add expensive medical costs to your future. There are many other safer ways to improve once heath and diet.
                    Rectified
                    • #40
                      @Rectified, thanks. I think it would still be ok for plant.
                      About healing property of water, I read that we can improve it's quality by placing water on top of magnet north, pulsing DC, and HV corona. I guess there must be a best way of all of the electric/magnetic method using the ignored electricity knowledge .
                      • #41
                        When Making a free energy Electret
                        you are doing the same thing.
                        A stressfield charges the interaction with the Ether
                        • #42
                          Healing Properties of Alkaline Water
                          I have my own alkalyzer at home which has had positive effects on our family's health. Here's a link to directions for building one:
                          Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                          Kangen water is also another name for the product of this setup. Check out some of these youtube vids and their amazing claims about Kangen water:
                          YouTube - kangen water and colon health
                          Here's just one of many sites advertizing their products which ionize water to make this happen: Kangen Water
                          B
                          • #43
                            Edit: Double post.
                            • #44
                              Kangen Water
                              Hi Bob. My mate and i built one of them units way back when. It worked real well, unfortunatly we used the wrong metal which very quickly rusted.
                              • #45
                                Hi DM,
                                Yes, a decent alkalyzer probably needs at least 316 SS. I think mine has titanium plates in it - should last awhile. Did you see that water spinning video on Youtube I have linked further up the page? I think that's worth considering as well.
                                B
