fixing the problem with melting reed switches...
I have found that using a relay with the reed switch works fairly well.
I have been trying KT services setup with a reed switch and it has a VIOLET light arcing across inside. It seems with my setup, when I use razor blades they work well for a while then the carbon builds up on them and they are useless. I was reading someone from overunity commented about building a custom relay that uses graphite for one of the poles, but I have no clue how one would do that. He said the back spike is bigger if you do that on your relay.
Not sure why my solid state relay is not working for me in KTservices schematic...
Konehead says the military has reed switches that can do 100 amps.... hard to find thou.
... Simple yet not widely known.
