Hello,
I'd like to post that concept to prevent any harmful to humanity patent process which will lag our advancement 17 years behind due to time of patent expiration.
Around 1879 Wesley A.Gary discovered something which I believe is very important to understanding of magnetic field.He found that magnet has not only a neutral line between poles but also a neutral line for induction process.
In other ways; when approaching soft iron plate to the magnet , it's first magnetized by induction and holds opposite magnetic poles to those of magnet itself , so attraction is done automatically.Then however there is a line when iron is demagnetized and after passing it re-magnetized again , but this time holds exactly the same poles as magnet.
That effect allow inventor Wesley Gary to build special magnetic toys,motors and generators which using slightly vibration generate movement or electricity by using SUM of POWER of small electromagnet and permanent magnets.
Apparently the same concept is used differently by other inventors like Ecklin, Flynn etc. Wesley A.Gary said that and iron plate placed in that line effectively cut magnetic field force above plate.
So, the concept is easy.We are joining a few powerful , specially shaped permanent magnets and find neutral line of such composite. Then by attaching electromagnet without core (or with special core) we slightly move that neutral line in one or other direction. The coil core constituted of soft iron, or a diamagnetic substance is changing magnetic polarity inducing electric current in windings.Magnetic flux change is mostly a change of permanent magnets field and thus is powerful. The vibrations of neutral line location must be probably done very frequently because the size of neutral line is not big, that's require high frequency quite high voltage current induced in tiny windings.The rest is normal process of step down current and frequency to required level.
I know at least one device except Weslay Gary ones which probably used such concept in the past. It was Roy Jerome Meyers Absorber.
Wesley A.Gary :
Wesley Gary's Magnetic Motor
Roy Jerome Meyers:
Roy J. Meyers: Absorber (Atmospheric Electrical Generator)
Roy Jerome Meyers device
Wesley A.Gary :
Roy Jerome Meyers:
