Aromaz Radiant Energy Joint Research Group
  • @ sucahyo;
    You ALWAYS should keep time and knowledge in perspective. During the time
    both Tesla and Moray remarked on "radium merely retransmits energy that which it receives, that it converts the cosmic rays into electrical particles"
    they did not know or understand the concept of Radioactive/Nuclear Decay.
    BUT: Such radioactive decay is exactly, precisely and only the same as the
    general COSMIC RAYS. Radiation/nuclear decay = Cosmic Radiation; both ways. So their statements are in fact valid to the full extend; except the source of photons/electrons is the Radium neuclei itself and not from another external source.
    Further: Physics can in fact "quence radioactivity" and they can modify it. Only question remaining is WHY they do not do it? Radioactive radiation can generate electrical current directly; thus the same material used in an 'hot' reactor like Uranium 235 can be re-used once it is considered nuclear waste - Radium-235 -to generate more continues electricity.
    • I see, thanks . I never see it that way .
        I guess it depend on the type of wave. Longitudinal wave would be one to one infinite distance type. While transversal wave would be one to many finite distance type. OU happen at resonant longitudinal wave.
        A good illustration:
        Longitudinal and Transverse Wave Motion
        @sucahyo
        Sir did you PM me two documents (.doc) & (.ppt)? The PM had this name, but would not pass scanning security so I have no idea of the content. Because MS (.doc) and (.ppt) files are not allowed to be opened when not locally generated.
        If you did send info it must be plain text, embedded graphics or (.pdf).
        Thank and disregard if this question has no meaning to you.
          @sucahyo
          Please forgive me, it is a wrong send. Sorry for the confusion.
          • standing wave in CFL replicated
            Hello guys,
            after watching this... YouTube - 555 timer driving ignition coil with CFLs on 2ndary
            i put together a 555 pwm to drive my ignition coil with two CFL's in parallel and can see the standing light & dark bands, not only that but by carefully adjusting the pot i can slide them around the tube at will.
            Thoughts?
            David. D
            • Dark bands
              Perhaps you are changing the wavelength, and creating null points like in the double slit QM experiments?
              • Originally posted by rave154 View Post
                Congratulation. I think you succesfully replicate what Tesla did.
                Download the file in this link:
                  Hello guys,
                  Thoughts?
                  David. D
                  Yes, I also have seen the dark bands when I use a 6 volt source.
                  Some effects do not happen using a higher voltage source than 6 volts.
                  I had mentioned this in some of my posts. I don't remember how I described the observation.
                  I'm glad someone posted a video of this fact.
                  Everything is of valve in putting the pieces of the puzzle together.
                  • my reply
                    inq... that thought about the double slit experiment crossed my mind actually !.. i guess we wont be sure until we can use something other than a CFL/tube to "show" the wave.
                    Vortex.. i was using 12VDC to drive a standard ignition coil, via 555 & 2n3055.
                    Suchayo... OMG....that diagram is from Tesla???..........omg, that has given me goosebumps...seriously !
                    I should mention, i could also see and manipulate the dark/light bands with 2 cfl's in series as well.and also just one cfl....dont know how that changes anything?
                    I am now going to peruse through the "tesla on the dissipation of electricity" Doc.
                    Thanks all :-)
                    David. D
                    • @rave154, watch your video again.
                      @4:20 (minutes and seconds)
                      you say "you can basically see a standing wave" and then
                      you say and show that you had reduced the voltage to 6 volts.
                      • to clarify
                        to clarify things,
                        the guy in that video, is Not me...i came across it by accident, and duplicated the effect. :-)
                        • with the sg fan ignistion coil and a 40in tube i can get the standing wave too.I can make it run away or towards me when i tune it also if i touch the tube the wave will speedup at that point.
                          Im doing some experiment so i will video and post stuff.
                          • Comment
                            • interesting
                              I just put together a bedini circuit/motor to try and charge up a really crappy battery, im using EXACTLY the same breadboard circuit as my last bedini.....the only changes are im using a 2n3055 taken from my aromaz circuit and also have filled the core of the coil with magnetite..
                              as soon as i power up....without even hand spinning ther motor...the coil starts whining and ive immediately got high voltage across the neon?.......is it self oscillating?
                              i remember Aromaz trying as brand new 2n3055 in his circuit..and it didnt work.,only the ones that had got "conditioned" to self oscillate worked.....am i getting the same effect here because im using a 2n3055 from my aromaz circvuit that has somehow....changed it......because the bedini motor will NOT run...however the coil is generating high voltage from oscillations..
                              hmmm
                              • self-oscillating 2n3055
                                Rave,
                                It sounds like it is self-oscillating. Reduce the resistance at the base of the transistor and your motor should run.
                                I have never had a problem getting 2n3055's to self-oscillate by simply increasing resistance at the base in a Bedini circuit.
                                But with the piggybacked 2n2222 for example, that takes a little finer touch to get it to oscillate the Aromaz way but that is a different method and application.
