Aromaz Radiant Energy Joint Research Group
  • #46
    YouTube - Aromaz2012's Channel - Video 029 - Transistor Basics
    Video #030 are still being trimmed form 58 minutes to 10 minutes!
    • #47
      Originally posted by jibbguy View Post
      Although i may be a "forum ghost" currently when it comes to doing the actual "wet work" needed for Free Energy experimentation (hopefully this will change in 2009 ); i would offer my services in any other way i could to help in this great endeavor. This could include doing web research, fact checking, helping to design Test Plans, or simply recording it for posterity
      @jibbguy: Thank you for the kind words and the very welcome offer.
      I hope we will see you soon as an co-experimenter too!
      • #48
        Mu !!
        Originally posted by Electrotek View Post
        Here's another one:
        Radiant Energy has an affinity with water. Water can carry this energy into a substance. Then, when the water evaporates, the energy remains as interstitial energy. This is why dirt clods.
        This came from The Cosmic Forces of Mu (Lemuria), by James Churchward. This civilization predated Atlantis by several thousand years.
        It is very interesting to see the info leaking about Radiant! I will work on it after my visitors left, so please keep on theorize here - for now!
        Ahh, now there is a very interesting subject on its own. Off line here, but still an item we can consider elsewhere. Where was Mu? Who build these big megaliths all over the world, the biggest destruction ever seen on earth - Paciffic ocean...... OK. STOP!
        • #49
          Originally posted by Inquorate View Post
          Mu was in australia. I've often thought atlantis used tesla technology and gave anti-gravity to egyptians.
          @ Electrotek have you read 'the biggest secret' by david icke? I sent bodkins a copy as pdf. My computer is dead but he may email it to you?
          You'd be surprised how far our history goes..
          I stand to be corrected; BUT: Australia was a peripheral (suburb) of Mu, Mu was in fact where there is a big hole in the earth - between Philippines and Hawaii, South of Japan, north of Papua. Yes, I do also believe they were in fact responsible for lost antigravity knowledge, not only use by Egyptians STOP!
          • #50
            new tech
            For those interested,
            Some of this research reminds me of Moray.
            Hopefully this its not to far off topic.
            Nano-Antennas for Solar, Lighting, and Climate Control | EcoGeek - Clean Technology
            -Gary
            • #51
              Conventional current vs electron current vs aetheric current
              @ Aromaz, here's something to think about; conventional current notation is backward, yes? So electron flow is actually opposite to notation, and we have seen in our experiments how we are able to pump up electrons from an earth wire, by creating a vacuum of electrons with a 'positive' source..
              Here's the pickle; electrons move thru a wire at the rate of an inch every hour, or thereabouts..
              So what is really happening in a spark gap?
              And our meters measure the sideways oscillations of electrons in a wire.
              What is making them swing side to side?
              • #52
                @Inquorate: I haven't read David Icke's book, but I'm aware of how far back the past goes. I know of one advanced technology artifact (an artificial opening into the surface of the universe) which is 200,000 years old. It looks like a ball of light, and has 23 equations which describe its behaviour.
                @Aromaz: I'm awaiting your next thread. As I've heard it, Hawaii itself is a remnant of Mu. The Aztecs had a very important symbal called "Sacred Fire".
                @gmeat: Thanks for the nanoantenna article. When it comes to ancient symbols, these bifilar spirals are about as old as we can get. I always thought they had something to do with power.
                @Inquorate: Confusion about electron movement is due to the way we've been misled about the EM waves. The electric potential flips back and forth as the density of the ether contracts and expands, relative to the ambient. However, the magnetic force points straight forwards with the positive, but tips to the side with the negative. That's why electrons spiral to the side as they move forwards, at around a few mm per second.
                Electric current can flow from negative to positive, with electron drift, or from positive to negative, in an ion solution such as a copper plating bath. And Tesla said that currents can flow both directions in the same wire, and at different frequencies. There is a lot which was once known that we have to rediscover.
                • #53
                  My relay surprised me by being a stronger source of it than the coil, or at least in the direction I 'looked' in...
                  Maybe because it is the collapse point? so radiant enegy leaked more there?
                  It would be great if we can find out people who can see aura and make them look at our device. If the aura they see is the same as radiant energy we create, they should be able to measure, and give hint about how to amplify it.
                  • #54
                    @ Sucahyo
                    Maybe...... I'll do more testing on that circuit soon, now that I can measure the 'gas' leaks :-)
                    • #55
                      Relay more radiant than coil
                      Had a thought; the relay in imhotep's video wired same as mine made 400volt spikes. I don't have Oscilloscope but from memory my meter showed 20 volts ac and almost nothing dc. It was using 0.01 amps.
                      400 volt spikes? / 0.01 amps = 40,000
                      The coil - just guessing, will do a voltage divider circuit from coil and measure it later - makes say 10,000 volts, and used 0.6amps
                      10000 volts? / 0.6 amps = 16,666
                      So, since we know radiant energy is caused by pure voltage surge before current catches up, the relay would create a purer radiant stream......
                      Hence why the detector shows a stronger emission.
                      I'll check the frequency the coil and the relay are running on too.
                      Addendum - coil has a metal tube casing which would absorb radiant and make an electron barrier for the radiant, so it might come out of the top thru the dielectric??
                      I'll test that too, and see what happens when coil casing is grounded.
                      • #56
                        can make computer fan turn
                        I think there is amp in the circuit. Since when on open loop condition there is amp in collapse point and voltage at positive source.
                        When you attach another coil, the back EMF should be powerfull. In my case it is able to charge two battery and a normal computer fan. In this video I serie battery, HHO cell and computer fan:
                        YouTube - charging battery, powering HHO cell and powering fan using Imhotep radiant oscillator
                        See all of it in picture, the meter showing 0.10 Amp. The fan is 0.14 Amp and the battery is charging .
                        I think my unit is still COP < 1. Although the energy flow do work in unconventional way. powering something indirectly where the coil become power source........
                        • #57
                          A chicken coup
                          Yes, you read that right. I'm building one (for obvious reasons) and realised I can use it as a faraday cage as well. So I'll be able to see if my detector is picking up EM waves or just radiant.
                          Here's a link that describes faraday cages quite well
                          Faraday cage@Everything2.com
                          • #58
                            A Faraday cage is an excellent idea!
                            I've noticed that fluorescent starters are now using a neon which is completely silvered on the inside. This compensates for the fact that the can is now made of plastic.
                            This is part of our National Treasure. There's all kinds of Alt Science components disguised as every day items, or parts thereof. A good example is the ceiling fan, at least the older, artistic ones. And have you ever seen a cotton candy machine?
                            • #59
                              Ok, I'll bite..
                              decorative ceiling fan?
                              • #60
                                The older ceiling fan blades had decorative inlays which produce ions, with an applied biphasic field. The motor turns at just the right speed to spin these ions outwards, for aerodynamic effects.
