Aromaz Radiant Energy Joint Research Group
  • Annunaki
    There are those that say their planet nibiru is coming back..
    // what is the correct way to measure amp draw in a circuit with a digital multimeter?
    • E-Mail
      Originally posted by stephenafreter;
      ....... the completion of the new SEG prototype and the work out in Thailand.
      I send an e-mail off this morning: Copy below.
      drtm@aol.com
      JPDunn1@charter.net
      John Searl Thailand
      My name is Corrie Lamprecht and I am also working in the search
      for alternative energy and motion. I have watched video's and
      documents of John Searls work.
      I believe you are presently doing experiments in Thailand.
      Would it be possible for me to visit this location?
      Do you have contact phone number for me?
      If there are valid reasons, I can obtain more than enough funds to
      produce proto types.
      I hope to hear from you soon,
      Corrie Lamprecht
        is it possible to have a non magnetized coil core become permanently magnetized using the coil as a pulsing electromagnet?
        YES; though flux life and strength will depend on composition (elements) of the core.
          In series with circuit where you want to measure.
          Some remain at normal Red/Black connecters for less than xx amp (i.e. 10Amp)
          and above to remove red terminal to +xx Amp if higher than that amps (i.e. 10 Amp).
          A different kind of meter to be used for AC Amp - RMS.
          • Contacting John Searl
            Good step Aromaz , you seem in a good position (geographic and financial ) to an eventual help to Searl's development
            Hope all this will have a good issue for our mankind !
            God bless you Corrie,
            MDG
            • Amp readings
              I thought so, but when I put my meter in series with purple flasher circuit, after neon and before mechanical switch which goes to battery negative, electricity stops flowing; switch stops sparking, neon doesn't light up... but the meter shows microamps.
              I put the meter in parallel in same place, and it shows the same microamps. But neon lights up.. (a purple shade of orange - still working on getting the purple flash with an automated switch). If I barely touch the contacts of the switch to the rotating cog, amp draw goes into negative microamps, and neon still lighting up (barely) - still the odd shade of orange.
              Ps, neon only lighting on one leg, so don't need RMS?
              at work now but can do video on request.
              Ps same thing happens with analog microamp meter gauge; when in series, no neon light, when in parallel, neon light. Although I didn't look at it to see if in parallel was showing amp draw.
              • @Inquorate;
                ? Tried to put meter wrong way?
                Red to +
                Black to -
                then
                Red to -
                Black to +
                Also play with your settings on multimenter
                Micro-amp to full amp?
                • Not the wrong way
                  if I make the switch constantly 'on', the bulb I have as a resistor lights up, and current goes over an amp.
                  If I touch the bendy razor strip contacts to the spinning metal cog hard, the bulb also comes on, and neon off. I assume this is because it is also mostly 'on'.
                  If I touch the contacts with less pressure so the teeth of the cog are intermittently contacting the razor strips, 'off/on', the 12v bulb stays unlit and the neon comes on... Around 50 to 200 microamps. (uA)
                  If I touch with barely any pressure, I'm dealing with 10 to 12 microamps sometimes 50..
                  And when I can make contact really lightly, the meter starts showing -11, -14 uA etc...... And the neon is dim, but still lit on the same leg as before.
                  So..
                  Anyway, that's when I found that the core was magnetised.
                  Oh and I get silvery blue, and white green sparks on motor - cog switch, depending on pressure of razor strips.
                  I am thinking that a better mechanical switch can be made of instead of a cog, using wires like the ones coming from an edge trimmer; several coming off a wheel, which strike a surface.
                  It could be in a vacuated container, and magnetically quenched.
                  • Tried putting meter the wrong way
                    I just realised what you meant, yeah I'd done that. And tried another meter. And used different settings; 2000uA, 200uA, 200mA, 2A. Of course, only the uA settings showed accurately, though the mA and A occasionally showed 0A. I was doing pressure of razor strips by hand, intend to get it set up better soon. Nb; the strips take a fair bit of pounding too.
                      Yes if the core retains magnetism. This is how a magnet is made (kinda) To test your core material place a strong magnet on it over night and remove in the morning. Try to pick up some metal filings or paper clips with the core.
                      Oh and BTW, Ill show you a simple commutator tomorrow when you come by.
                      • Purple flasher update
                        I went to ren's place yesterday, and he turned on a bicycle wheel bedini. With a neon over the amp draw meter, he got super white / fluro purple flashes in the neon, constantly.
                        So I'm going to build a bedini to research the effect some more.
                        I also found a spectrum analyser / Oscilloscope / signal generator for pc sound card and have been lent a laptop.
                        Download Virtins Sound Card MultiInstrument v2.1 at YourFreeFiles.com today!
                        If you want to try it for free, I have a crack; pm me. But remember to pay for it if you like it...
                        So, hopefully lots of interesting stuff coming up soon. And different mechanical switch ideas as well; Commutators as well. Thanks ren
                          You mean, it light up white where it supposed to light up red?
                          • neon
                            Fluro white, hint of purple, where it should have been orange.
                              Wow, I guess it really do make a difference when build properly. Is that on low voltage part? I can only do it with my oscillator on HV part only and have to be on continuous sparky connection.
                              For software scope, Joit post this link
                              Oscilloscope for the Soundcard
                              and gabriolaman use this between the real device and sound card:
                              Buffer Hardware for xoscope
                              • Here is my version of water move by HV.
                                YouTube - High voltage can move water, using radiant oscillator
                                Water move to the direction of the cable . Anyone has theory of why the water move?
                                I wonder why I can't replicate the homopolar effect even when I can do this effect.....
