Resonance Effects For Everyone To Share
  • #91
    a video for jetijs
    YouTube - MIT Physics Demo -- Resonant RLC Circuit
    this is a RLC demonstration done by MIT that i believe shows what you are describing in your last post
    • #92
      That is a great demo
      • #93
        Originally posted by mrbreau View Post
        That sure sounds like Steven Marks setup to me. But then, I don't know much. As for the conical coils, you can get them from the older CRTs. I'll go take a picture of one and add it in here.
        Warren
        Thanks Warren, but the idea I have is very different. Only a single wire, full loop 360degree. Cone 45 to 60 degree and exactly 3 layers mono direction - similar kind of winding to Tesla pancake. First layer is not too bad. but then second and third keep on slipping off. Now I am taking long time - wind little and epoxy them, then wind little and epoxy ...... Can only do slow winding by hand too. Guess it is good for excercise!
        • #94
          @gotoluc; The wagon is rolling now!
          Yes we await your results and hold all thumbs.
          Meters and measurements are always a concern, by those I had over unity.
          Yet the ultimate test of OU is to get all external power off and recycle what you create i.e. I eventually used only one battery (12v Li 4.7Ahrs) lit 1x CFL and cycled all the other energy back to it - It took 56 hours to go from 12.39 to 12.14. Not bad - BUT not OU.
          BUT in the mean time; I go on with this circuit of yours. There are a lot of things here that are similar to what we found on Imhothep and my circuit. I am very curious as to why/what. This means we can compare the results from the two circuits which is great to get better understanding.
          At least we have a binocular now, not just an ancient spyglass!
          • #95
            Cody "jou Doring" - and THAT is a compliment! I have been playing with a similar set-up last weekend to see how one coil will affect resonance inside another. Here is a photo. What I like of this MIT is the different switches for their ? caps? Very interesting indeed.
            I have done a bit more in that one by also using coils as the internal core. Also did same with two Caduceus coils, one sliding into the other.
            Will fix up nice presentable for video series! Coils are captuning me more and more!
            • #96
              @ Gotoluc. I have been following your progress mate, you are doing great
              I am still getting parts together for the H bridge flip flop, I am having trouble locating the mosfet drivers. Does groundloop recommend any other suitable parts?
              I was hoping to configure the tl494 chip that Erfinder got me onto to perform a similar function, it has flip flop capabilities and would be ideal for me because I am already familiar with it and it is easily obtained. Maybe Groundloop would be kind enough to look at it sometime. As it is, I dont have access to a signal generator, which is the only thing holding me back.
              I was hoping I could use a PWM chip (tl494 or even simple 555) in place of your (AC?) signal generator? If this is suitable, its frequencies would simply need to be broad enough I guess to allow for sweeping.
              Let me know if you have any advice.
              • #97
                I was working on an idea of harmonics. I created a program to calculate the best resonant frequencies to create harmonics for wave length from 1-1000000m. Here is what I've got RapidShare: Easy Filehosting.
                Little sample of what is inside:
                "Harmonics" "Wave_Length" "Frequency"
                240.00 720720.00 415.96
                240.00 831600.00 360.50
                240.00 942480.00 318.08
                240.00 982800.00 305.03
                The point is that at wave length of 720720m (415.96Hz) it will resonate 240 of other waves. Is it the sectret that Moray discovered???
                Mike
                • #98
                  @ mylure
                  That's cool. As my computer recently died (i use my phone now) could someone let me know the frequency between 100 hz and 20khz for my 555 timer pulse generator that makes a harmonic resonance that gotoluc is using?? Off the top of my head, 312mhz?? It really would help all of us without signal generators... Maybe...... My multimeter can read frequencies up to 20mhz
                  • #99
                    Hi everyone,
                    Good news
                    Test 9: YouTube - RESONANCE EFFECTS FOR EVERYONE TO SHARE test 9
                    Luc
                    • Originally posted by mlurye View Post
                      Great Work mlurye fantastic
                      One more step to freedom luc
                        Luc, I playes around with the signal generator some more and found out that the effect in my video was just an ordinary transformer action, because it works just as well or even slightly better without any caps at all, just using the signal generator. That explains why the field was bigger when a higher capacity was used and why the effect increased when I used a core material. Just ordinary magnetic transformer action. Still, it would not light up the CFL at any frequency, only at certain frequencies and resonance still plays a big role here. But with your latest circuit that is able to light up CFLs without wires, you got something better there
                        Edit: Played around some more. I found a core from an microwave fan, just like you had in your video. I removed the core and put a cap in series. Then I put a rectifier across the coil and the rectifier was connected to a 1000V 1uF cap. I just wanted to see how high I can charge that cap. Sweeping through frequencies I could find various sweetspots, but there was always one that made the cap charge to higher voltage. The best I could get was 230V on the cap without any ground connected. I used a 1500pF cap, but I also experimented by changinn capacities by connecting those 1500pF caps in series and parallel configurations. I found out that there is also a sweetspot in capacity that gives the best results, so in order to get maximum out of the setup, you need to be able to adjust the frequency and also the capacity.
                        Great stuff
                        Yes Jetijs, you are getting it
                        That coil should work even better with a 550pf or so
                        We should all get a variable capacitor for experimenting: AIR VARIABLE CAPACITOR -3 sect.x 10~430pF HAM RADIO #1 - eBay (item 130276804974 end time Dec-19-08 20:49:16 PST)
                        This will help allot. I just bought the one above
                        Any 12 to 400 should be fine.
                        Luc
                        • Originally posted by ren View Post
                          Hi Ren,
                          You are free to experiment with other parts but Groundloop was insisting I get the IR2103 and nothing else.
                          you can get it here: IR2103 - eBay (item 220208395817 end time Dec-27-08 23:12:37 PST)
                          Make sure to pickup a variable capacitor also! something like this: AIR VARIABLE CAPACITOR -3 sect.x 10~430pF HAM RADIO #1 - eBay (item 130276804974 end time Dec-19-08 20:49:16 PST)
                          Luc
                          • Great work LUC
                            • Originally posted by stephenafreter View Post
                              Hi Luc,
                              I just learned on overunity.com that you were giving all your time on the free energy projects, so I think we could help you also financially, as we can, because if you take a new job we will have one less freedom fighter on duty!
                              Myself I'm not rich, because I just started a new business and spend also a lot of time for freedom fighting (I try to launch a new website to help educate people Tesla3.com Index - MDG 2009, but still have not enough time for this particular project ...).
                              So to make it short, I want to sponsor your work with 100 Euros monthly. I know it's very little, but I hope to have more to give soon
                              Paypal would be the easiest way for me to send you the money, and the cheapest way also; they charge only 1 Euro to send 100 Euros from Paypal account to Paypal account.
                              My only condition is that you keep my contact details secret, and I'll do the same for yours.
                              I see that you are a great experimenter and that you can do better than me.
                              I wasted already money by experimenting myself, without big results because of lack of time and knowledge, so I think it's better I give this money to you to do the research ) Like that I just have to watch and relax
                              Sincerely I think the responsability is on our shoulders to do that work, all together.
                              Myself I think I could be helpful to spray the knowledge through internet and in some slums and poor countries, and to NGOs. But that comes AFTER the apparatus is ready.
                              Everybody can do a part, depending on what he is good to, and as a group we can do A LOT ! We must organise ourselves !!
                              Hope this helps, waiting for you answer.
                              If you want private talk, no problemo, i'm at danielfreepower@yahoo.com
                              Sincerely yours,
                              MDG
                              Bonjour stephenafreter,
                              I have released video test 9 above and I am now convinced that we have the real thing
                              I now need to buy some supplies, new magnetic wire, variable capacitor, etc. on ebay and could use a one time financial assistance if your offer still stands
                              Here is my PayPal account which is also my email if anyone needs it: gotoluc@yahoo.com
                              Thank you for your help
                              We have allot of work ahead of us and I feel we are a great team already
                              Thank you all for sharing and your support.
                              Luc
                              • Congratulations Luc !
                                Your idea to use the batteries as power was great
                                We clearly see that the depleting rate is not negatively influenced by the connection of the coils ... it even seems to give power for 2 secondes, then slow down the draining of the batteries !! Yahoooo !
                                I hope people will join to sponsor your experiments to buy some material at least, to see if the effect can be multiplied, buy adding more coils, or different size coils, or bigger loads, etc ...
                                By the way, can you light tubes at close range from the running coils without disturbing the caps charging ?
                                I don't know the price of wire spool and parts you need, but i scare that 100 Euros is not enough
                                I'm sure I will be soon able to send you more, God willing, because if you can increase the effect you will need to get more material; we can not let this stand without investigating it more deeply !
                                Together we can make more work, and I invite everybody that can not put the hands on the work like me, to at least try to support the experimenters, like the great guys we have on this forum !!
                                Yahooooo !
                                Good luck everybody,
                                Congratulations Luc
                                MDG
