Hi Ren,
My understanding on the TL494 is that its duty cycle can be controlled by changing the DC level on its pin 3 wrt to the negative ground.
Here is link on a motor speed control with TL494, perhaps you have seen it but it does change the DC level at pin 3 with the 1kOhm potmeter (R6 in the link schematic).
PWM Control Speed Motor 12V By TL494 :: Electronic control circuit page 01
Of course it should control in the same way with your 10kOhm pot too. How do you mean your bread boarded circuit for duty cycle is not working well?
Maybe the duty cycle changes only 50% by adjusting the pin 3 voltage level?
The data sheet includes a hint on push-pull or single ended operation, see page 2: http://focus.ti.com/lit/ds/symlink/tl494.pdf
If you connect pin 13 to ground, the TL494 works in single ended or parallel mode (you can connect the uncomitted output collectors and emitters in parallel to increase current capability within device dissipation limit of course) and if pin 13 is tied to +5V, then comes the push-pull mode, probably with 50-100% duty on one of the output collectors/emitters and 0-50% on the other output. I think this is your problem, I am not really familiar with this IC, prefer using the CMOS version of the 555 family (LMC555C or TLC555C).
rgds, Gyula
rgds, Gyula
That cleared up a few things for me. I have looked at the PDF before, but unfortunately got a little lost!
it flip flops but is making a negative pulse when it flips, so I think it would need a PNP mosfet on that side, would I not? the mosfet's I want to control are both NPN.
