The thought crossed my mind too
Gray Tube Replication
Rotating magnetic fields
Well, if anyone likes a little humor, I found this link discussing rotating magnet fields. Reading completely through at least page 12 is must!
VRIL Counter-Rotating FieldsLast edited by martin; 10-12-2009, 05:51 PM.
polarity
Hallo
@Nat in Comparsion of devices U wrote - plate P on the first picture is negatively charged. But what I know ground is negative and air have positive polarity. In some dokument Tesla wrote that air is positive too...Where is the true ?
It is interesting idea that vakuum tube 28 is for collecting radiant energy.
I spekulate about tubes 34 around high voltage anode that it is spiral wounded too.
@Martin why U think that vrill is joke ? It consist from 3 bifilar coil...Read Teslas patent No. 381970 from 1888, see Chapter9.pdf on Free-Energy Devices, zero-point energy, and water as fuel Here is described that 3 coils on toroidal core can produce aditional energy. It is free energy device.
Teslas patent no 512.340 Coil for electromagnets speaks about bifilar wounded coil. I think that pancake coil bifilar wounded with end of the first winding connected to the start secondary winding when such coil is in resonancy, electromotoric force disappears, so due to low resistance we can get something interesting. I read that it can be power source. Not if it is wounded on tube with constant diameter. This appear only in the coils with constantly growing diameter. So pancake coil or cone shaped coil.
We need to get vortex nothing more.
I think that in Greys tube is important polarity of the metals. Silver is positive and copper negative.(carbon maybe negative dunno)
What do U think folks ?
Antena
Ok, I NEVER said the vrill was a joke or the theory of how it works.Originally posted by antena View PostHallo
Antena
There's an individual on that post that seems to be a little off in left field.
Did you even goto the site because, seriously,.... just take a look and at least read page 7.Last edited by martin; 10-12-2009, 08:00 PM.
i'm back from holidays.....and had time to think about grays circuit.
I reverse engineered grays circuit into something simple that i could understand from the point of view of natures creation of lightning. Not sure if it is 100 complete. But happy to share the information. Basically confirms what i thought which was that the grids are negatively charged and it appears that the vacuum tube is mandatory if you want to replicate nature.
The drawing shows the sun emitting a unidirectional dc pulse hitting the upper atmosphere which provides resistance which then generates the high voltage. The rest is self explanatory
The carbon resistor is the primary and the grids are the secondary.
cheers
NatLast edited by nat1971a; 05-15-2010, 12:55 AM.
Quite some time ago i bought 2x svetlana sv811-10 power triodes from the USA. It was quite expensive and i remember thinking i was crazy at the time for spending the money. These are the ones gary mcgratten had listed in his documents on the gray tube. They are half wave rectified vacuum tubes which also matches up with the specifications for the ones Tesla used in the car (half wave). From what i gather half wave reduces current. I know nothing about vacuum tubes and they have been basically sitting in the garage until recently. I will hopefully have a go at putting them into the circuit.
I also bought a russian thyratron from ebay for about $3 quite some time ago....dont know what the part number is....i might try that out too.
I believe that charge receiving grids are negatively charged like a capacitor.
I made two square sheets of aluminum..placed them close together separated by some dielectric....e.g glad wrap....(what you wrap food in) then connect to a large battery bank....one plate is negative the other is positive...then use the negative plate as the charge receiving grids.....this is my understanding from what is in the jj thomson document the Tesla refers too
hmm well i got my $3 thyratron working briefly just as grays shows in the circuit...unfortunately my dodgey built system is becoming unreliable otherwise i would have posted a video.....and with nothing connected to the grid in the thyratron
YouTube - Update 33 - Edwin gray's circuit diode versus thyratron
me tinkering with grays circuit diode versus thyratron......
volt meter readings are from the charge receiving grids.
I am using a carbon resistor (buss bar) on the so called LV anode 1.....more tinkering required................
Edwin grays circuit with so called safety overshoot that fires all the time with occasional pops
YouTube - Update 34 - Edwin Gray's circuit with so called safety overshoot firing
"So called safety overshoot device" ...hmmOriginally posted by nat1971a View PostEdwin grays circuit with so called safety overshoot that fires all the time with occasional pops
Do you remember some paper shown here about electric generator which Gray planned to sell ?
It was stated that from start device needed quite a lot of time to run properly something around 30 seconds. Later device run on its own. Do you know why ? Think.
Maybe you see a spark of energy from time to time ?
Imagine you can recreate it many times per second! I think it would possibly be dangerous ? or not ?
