Computer controlled ethonol pump at your house!
See my experiments here...
You do not have to prove something for it to be true. However, you do have to prove something for others to believe it true.Tags: None
Reply to Mart
Hi Mart,
That's one big bread machine! Expensive, too. Actually, it is not much more than a portable still (distiller) with a pump and nozzle attached. I have an electric distiller that I use at my cottage, and as a matter of fact it is running right now. I bought that at Sears a few years ago. It was about $50 then, and it is a one gallon capacity. Of course I'm making drinking water from lake water, but the same unit could easily be used to distill alcohol. Perhaps I'll make some and try it out in my lawnmower. If that works well enough, I might try running my 50 hp Johnson outboard on it.
Notice they say the product is "not fit for human consumption."
Rickoff
RE: Still
I did some more looking at it it makes 70 Gal a week, which is horrible for some thing that takes 4 days to make anything. The main thing I liked about it is set it and forget it. If the process was automated, I believe this would be much more viable option. The biggest problem I have read is getting the water out of the alcohol, I understand it takes alot of energy to get it to a pure state, I have read that there are things you can add to speed up the process. But 10,000 is too much for 70 gal a week production, considering how much electricity it would use. But to know a company will be shipping this fall is awesome news.Originally posted by rickoff View PostHi Mart,
RickoffSee my experiments here...
Here is a website that may be of interest to you. FREE MOONSHINE RECIPES For moonshine--er--uh--ethanol. Good Luck. Stealth
This is totally hands-on manual method, you build it, you make it,
which mean you choose the size of batches ..
Welcome to Alcohol Can Be a Gas! | Permaculture & Alcohol Can Be A GasRemember to be kind to your mind ...
still
i built a valved reflux still which produces ethanol 95% pure with one distillation
energy required to run it is quite high but if you use lower than atmosphear pressure this can be reduced
Home Distiller • View forum - Column Distillation and Design
have a look at this site for some info
Those are some good websites. There is so much info on making ethanol, it should be a cinch for anyone that wants to learn to make their own. Although most vehicles don't run well on pure ethanol, by mixing with gasoline they will run very well. Another thing is that ethanol doesn't get the fuel mileage that gasoline gets. Good Luck. Stealth
