hi all, i was playing around with the circuit shown here, http://www.energeticforum.com/renewa...html#post27204, minus the condenser across the ignition coil. for the bulbs i was using one standard flouro tube 2 feet long and a different kind of flouro out of a scanner, a small little thing an eight of an inch in diameter and maybe 9 inches long. anways, long story short, it lights the 2 foot but its dim. the scanner flouro runs as brightly as if it was driven by its original 12V inverter. i can't get this brightness with 2 normal flouro tubes.
Imhotep's Radiant Oscillator Video
Remember Tesla was a bachelor for a reason...
Just to remind you of an interesting thing: Scalar wave technology by Meyl.
And here is the EXPERIMENT KIT: XT-Commerce - Demonstrations-Sets
For you who have some money left over and are afraid of shortening your expected lifespan with the HV/HF/Spark gaps you can turn to the signal generator instead, it works in the MHz range with a sinusoid wave and still gives an OU of up to 10 according to Meyl. There are 6 experiments described in the lab book:
1) Energy transfer
2) Feedback(receiver to transmitter)
3) Proof of free energy
4) Superluminal velocity
5) Ineffective Fraday cage
6) Refutation of near field interpretation
I am not sure if this kind of kit will ever give the kw range effects but it will improve understanding of scalar waves I believe.
Nat, how is it going? I just reread a book yesterday, did you try to add 2 permanent magnets(N and S on each side) over the spark gap? Put a conical/helical/metallic object next to the magneticaly quenched spark gap and see what happens..... Watch out.... Should get an electrostatic charge of the metallic object.
Wireless energy transmission
I found this video showing someone else doing similar research. We are not alone. Makes me wonder about how many other people in high places know about this stuff and are keeping the technology surpressed.Originally posted by nat1971a View Post
YouTube - solar powered tesla coil
Lidmotor
thought i would mention that it works best at night...so you probably want to start testing at night first....to see the results...then experiment from there......obviously needs a lot more testing etc......and was at 36volts
@lidmotor ...thanks for the info.
@bodkins.....cant wait for your replication
did you notice the difference in the sound of the circuit?Last edited by nat1971a; 11-08-2008, 07:25 AM.
damn....it pays to have a messy work bench.......
i tidied up today thinking i was on the home trail....and what do you know....the effect was very diminished...
i carefully reassembled the bench exactly the way it was after rewatching my videos i took.....and what do you know.......it was somehow sparking back via an ac fan that wasnt connected to anything to some wires leading back to a battery bank that wasnt connected to anything via the receiver circuit.....
so in summary the spark back to a battery is necessary for the aether gas effect to fully realise....grays circuit must be followed folks.
Yeah and how about the imminent ice age: TerracyclesOriginally posted by Lidmotor View PostI found this video showing someone else doing similar research. We are not alone. Makes me wonder about how many other people in high places know about this stuff and are keeping the technology surpressed.
Lidmotor
Good job!
So can you post the final wiring diagram ow will you need a few more days to experiment?
About the battery it is really interesting what you say since I read that Gray and his engineers were arguing about the last capacitor to the charging battery, whether it was needed or not. And what is a battery really, anyone has something to share about what a battery really is? Dielectric constant, magnetic field etc? Something makes it attractive to the cold current, we need to figure out exactly what it is.
Originally posted by nat1971a View Postdamn....it pays to have a messy work bench.......
Sound like the frequency has gone really high which is a good thing!!!!Originally posted by nat1971a View Postthought i would mention that it works best at night...so you probably want to start testing at night first....to see the results...then experiment from there......obviously needs a lot more testing etc......and was at 36volts
I only have one ignition coil so Braden sending me two of his. my spheres are smaller but should fine. How many turns on the toilet roll coils and are they the same.
Well Done Nat
the toilet rolls are similar....i wouldnt say identical.....as i slapped them together pretty fast and messy....
inner layer is aluminum foil
next outer layer is toilet roll
next outer layer is aluminum foil
then outer layer is electrical tape
on the receiver circuit.....there was only 3 or 4 turns of the wire (leading from the ignition coil) wrapped around the conversion tube which then leads to the sphere....
the thing that makes the difference is the sparking back to the battery bank that was outside....
