Has anyone tried a bifilar yet!
Hi Everybody,
Has anyone tried a bifilar on the trigger side of the circuit yet?.I have a bifilar coil with #23 awg and # 20 awg about 400' in length with a magnetite core and when I run my SSG with this coil it produces multiple pulses with each magnet passing by and can get about 8 to 10 pulses depending on which guage wire I use.Well,I figured I'd give this core a shot at the Imhotep/Lidmotor/Bodkins/Theremart/Whoever else I failed to mention
running the CFL's.The bottom of my trigger coil comes through a 5k pot then my coil then a 25ohm pot then a base resistance of 47 ohms.When I tried to get it to self oscillate hooking the coil up normally using the #23 or #20 guage wire it didn't work,But if I hook it up to the #23 at one end and # 20 at the other end Bingo it starts right up and will work with either combination of wire guage as long as it's two different guages of wire (I'm not sure why it works but it does).I can replicate Bodkins affect of charging up a cap(560Uf 200v) hooked up to an earth ground and it directly relates to base resistance,Another words if I have the amps set at around 70 milliamps The cap will stop charging up at around 60-70 volts,And if set higher to around 200 milliamps or above the cap goes to max rating of 200 volts.I have also come accross the strange affect that I can charge a dead battery but cant charge a good battery
.The latest thing I'm working on is to see why and if I can extact something off my coil that I'm getting a reading of 199+ volts on the meters AC scale connected accross the coil while running at 490 milliamps.Thx to all for the input.
-Gary
Hi Everybody,
.The latest thing I'm working on is to see why and if I can extact something off my coil that I'm getting a reading of 199+ volts on the meters AC scale connected accross the coil while running at 490 milliamps.Thx to all for the input.-Gary
What a great idea Gary! bulb - to coil -
with the sinkcap setup.
Sleep bodkins
