Imhotep's Radiant Oscillator Video
  • Comment
    • Magnetic monopolar current?
      You guys know how I reckon that there are two particles in aetheric medium, as predicted by mendeleve's equations, etc...... See my blog... And also how I reckon one is mostly positive in charge, one mostly neutral, or slightly negative... well, check out this site, read all the way to the end...
      Felix Ehrenhaft: Magnetic Current --- 9 articles
      Ok, now I'm really going to sleep. Gotta be awake in 4 hours.. Eep.
      • Can the first post be updated in realtime with milestones linking to significant posts. It would help the people that are new a lot to get involved. This thread has gotten huge and skimming through it page by page for circuit drawings is unproductive.
        • re cycling
          @Inquorate,
          thanks for the helpful advice. i always seem to end up with old computer monitors and scanners, which i pilfer the step motors from. anyway that was a very helpful post of yours for people in situations similar to mine.
          another thought i had, the orange juice containers here are made from waxy cardboard with foil inside, probably perfect for those t/roll tubes you guys are making.
          • Hi everyone,
            I just uploaded a new video to which uses and demonstrates a circuit that was designed by Overunity user: Groundloop.
            Groundloop came up with this circuit design after I asked him to replicate a 12vdc DPDT relay for me but using solid state components. Since I had some IRF640 MOSFET's on hand and some 4013 I asked him to use these components in the circuit if he could. Being a brilliant electronics man that he is ... in no time did he come up with the circuit below to which is now public domain Also please note that I asked Groundloop to make the schematic illustrative (not standard EE), so I and most anyone with basic electronics skill could understand and build it.
            A big thank you to Groundloop for all his help.
            Here is the new video: YouTube - RESONANCE EFFECTS FOR EVERYONE TO SHARE test 3
            What the circuit is doing in the video is using a DC input (12vdc Battery) and reversing (flip flop) its polarity on the output (coil) at the desired frequency I chose using my signal generator to trigger the logic side of the circuit. Please note that none of the power of the signal generator enters the circuit. Also, in this video the power for the logic (switching) is coming from the same battery since it works on 12vdc. However the circuit can take an input of up to 200vdc on the switching side but the logic side needs to be 12vdc at all time, so that is the reason for the separate input feeds.
            Luc
              Hi everyone,
              Luc
              Ive been playing around with this sort of circuit too Luc. The tl494 I have been using can also be configured to activate two separate PWM channels. The window motor I built using the full sequential circuit runs on a similar principle, where the DC input is "flip-flopped" or rather the drive coil is driven in a style that is similar to AC power
              Id love to chat more about this, as it could be utilized on a transformer with a center tapped primary for some interesting results I think. Check out this one that uses the tl494 I found. High Voltage Labs - HVLabs.com
              Its for a plasmasonic speaker, but could be utilised for other purposes. Also check out "push-pull" configurations, that are similar again Im working on one that requires no signal gen, cause all I got is DC.
              Maybe we should start a new thread for this one Luc, perhaps Ground loop could join and advise us too
              • Originally posted by ren View Post
                Hi ren,
                It's good that you thought of the plasma tweeter at this time since Corrie was hearing the beautiful soft whisper wind sounds plasma can make
                I also believe this simple flip flop DC circuit has many applications as this was not what I had in mind to do with it when I had the idea. We can continue if you wish at the OU topic I started RESONANCE EFFECTS FOR EVERYONE TO SHARE, so no need to go off topic here. Also Groundloop should be by there soon.
                I'm now setting up my variac through FWBR and cap bank (filter) so to test higher input voltages. I'll post the results soon.
                Thanks for sharing.
                Luc
                • I thought i should expand on the concept of quarter wave length a little
                  i should also mention that 1/4 wave length resonates with the neutral points (nodes)....remember aether is described as being a neutral particle or object or whatever...
                  For those who do not know what a neutral point i shall explain a little...neutral point is the void, the bloch wall, the neutral centre (keely), the 5th dimension (shauberger), the aether (tesla), zero point energy....it is known by many names in my book (@allcanadian may remember this from our dealings with ERFINDER)
                  as i mentioned earlier hertz in his book of 1893 electric waves mentions quarter wave length as being 1.8metres if i remember correctly
                  Then in the research i did on Tesla pierce arrow (if i remember correctly)...i came across two interesting pieces of info. two different pieces of information. One article mentioned the height of the antenna on the pierce arrow as being 1.8 metres high and the other being 3metres high.
                  So the height of the wok could be very important. A little experimentation should confirm 3 metres or 1.8metres very quickly. Now if i remember right aromaz mentioned the height as being 3 metres
                  In Telsa's wireless article of 1919 (i think) he quite clearly shows us pictures of his antenna with nodal points drawn in. But dont expect him to give all the info away.
                  • Hi everyone,
                    I have uploaded a new video demonstrating the effects of a higher input voltage at the coil.
                    I had to cut the video at the 10 minute mark, so I could not show the temperature reading taken off the bulbs surface. It was 130 degrease Fahrenheit
                    Video: YouTube - RESONANCE EFFECTS FOR EVERYONE TO SHARE test 4
                    Luc
                    • Flyback Transformer CFL Driver
                      I found a flyback transformer and tried it out today. It makes a pretty good CFL driver once you figure out how to wire it up.
                      YouTube - Flyback Transformer CFL Driver
                      Lidmotor
                      • Flyback ignition coil
                        I read up about flyback transformers a while back, they have a one or two turn wire around same core as primary winding, and one wire from this leads to transistor to switch it when the primary loads up..
                        I also found a post somewhere that said a couple of turns around the outside of an ignition coil is sufficient to provide pulse to base of transistor, and can then use flyback transformer circuit on to drive ignition coil. However, that was about the time Aromaz started with the self switching 2n2222's, so I didn't try it.
                        @all - if we're going to keep records of changes in frequency over time with Aromaz circuit, to maybe get a heads up on a pattern in aether frequency changes, perhaps we could all use greenwich mean time, and that'll make correlation easier. After about a month or so, with us being in different time zones and sometimes in same time zones, we can see if fluctuations are worldwide or local etc...... Bet it would look good on a graph. Can we all donate an hour every couple of days on same setup, checking every 10 minutes? With amp draw in, and maybe we can all use same circuit to dump from a cap, same voltage and farad rating.. See how quick it charges up / how many times a minute - at the frequency system is running at... Maybe I'll draw up a data collection form. any ideas on cap dump circuit that everyone can duplicate easily?
                        Big ask, I know, but the information may just prove invaluable in working out aetheric frequency. Moray claimed to know it.
                        • Replacing earth by water
                          Hi everybody,
                          Congratulations for your new advances in free electricity !
                          I think we are much closer to master it after Aromaz discoveries
                          I was wondering if a glass of water with a carbon rod inside could work as ground/earth to increase the energy; like guys discovered in the Dr Stiffler thread a few months back ...
                          I wish I was in situation to put my hands on !!!
                          Good luck !
                          MDG
                          • @Inquorate good idea easy cap charging can be done with a scr and a neon.
                            @stephenafreter with try this
                            All@check is out
                            Kirlian photography - Wikipedia, the free encyclopedia
                            Aerospace Engineering Online: Studying aircraft lightning strikes
                            • Originally posted by Bodkins View Post
                              All@check is out
                              Yes, that's the force coming from your body when you touch a TUBE which
                              changes the flow of energy around the tube, allowing energy into the tube where your finger is touching.
                              You are not the SOURCE of the energy lighting the tube, you are changing the flow of energy around your finger, allowing it to enter the tube around where you are touching it.
                              just
                              Randy
                              • Hi Vortex
                                I have always seen it as that. In my old video i say "people say thats my captiacnce but i think its somethin else!" Im a big fan of Sir William crookes!!!!
                                Im on the same page as you Vortex ( the same)
