New observations
Hi friends,
I came up with a new design for the small torque rotor, as I did some experiments today. See the attached photos. The configuration that all north poles were pointing outward is not so efficient in utilizing the repulsive force of the magnets, although it works. This new design will increase the output torque much more, as it uses the repulsive force much more.
As it is evident from the photos attached the repulsive force of the magnet is more than two times the tangential force of it in the configuration I have used the magnets, (about 45 degrees in relation to each other). As we load the second rotor, The repulsive force of the magnets will come into play which would add to the overall torque. This new design, will work in attraction mode, rotating in the clockwise direction and repulsion mode on the anti-clockwise direction. I have bought bearings and I'll keep you informed as I build it!
Elias
Hi friends,
Elias
So I think that it is obvious, that the problem in the too big diameter of the small rotor. I also agree to Peter, that the major magnetic force should be on the bigger wheel and not like in my setup, where the smaller wheel has the double stacked magnets. I just can't try out the other way, because I do not have enough magnets. Next I would like to try out a four magnet smaller wheel with a diameter as small as needed to get the space between magnets exactly like the space between magnets on the larger wheel, that would be about 8cm diameter.
