Skycollection's "Zero Lenz Drag" output coil.
  • Skycollection's "Zero Lenz Drag" output coil.
    Jorge demonstrates incontrovertible proof of "Lenz Free Output" in his latest video:
    Hi allen, thanks for sharing.
    I didn't see him move the coil away from the magnet rotor, if he did that, we could see if the rotor increased in speed.
    The reason i say this, i have made tests with normal air coil setups and placed it in the orientation he shows.
    It generates less and causes less lenz effect.
    And when the coil is faced at the rotor magnet, the lenz effect increases and so does output.
    That is why it would be good if he completely removed the pancake generator coil, while the rotor is at speed, then place the coil into the test positions.
    peace love light
      Zero Lenz Drag Coil.
      @SkyWatcher,
      Good points. More thorough testing is definitly a must. I informed Jorge of the new thread. Maybe he will comment on your suggestion.
        Is correct, if i remove the pancake coil the rotor will increase a little more, in perpendicular position the percentage of the Eddy currents is very low, the pancake coil "induces" the current very easy and the light of led bulb is very bright...!
          Lenz free output
          @Jorge,
          Thank you. Nevertheless, the equal and opposite reaction that results from the interaction of the coil and magnet is nullified by the orthagonal alignment of the relative magnetic poles. The output coil generates the opposite pole that would normally slow the rotor, but it points in the wrong direction to effect it!
          We have observed the presence of I/O anomaly in the past. The question remains: Is the ratio of drag to output linear or anomalistic between the two output coil positions?
          A lux meter would help determine the exact luminosity of the bulb. A simple comparison between the rotor R.P.M. and the bulb light intensity between the two output coil positions should solve the puzzle.
            Originally posted by Allen Burgess View Post
            @Jorge,
              @Jorge,
              La intensidad de la bombilla necesita medirse en ambas posiciones de la bobina y compararla con la velocidad del rotor.
                      components
                      @Jorge,
                      Relief might be translated as ayuda en Espanol, or help in English. One coil position may help relieve "Lenz Drag" more then the other.
                      Send me your mailing address by personal message and I will shop for the two measuring instruments online and have them sent to you as a gift.
                        @Jorge,
                        Thanks Allan, please write me to: skycollection@hotmail.com
                        and i will tell you all the information and i really apreciate your help.
                        saludos desde mexico.
                          I have other experiment related with the LENZ LAW, the Zero Force Zero Lenz Drag, i hope it serves for your audience....!
                          • #14
                            Zero Lenz Drag
                            Thanks Jorge for another outstanding video. Your platform demonstrates the zero Lenz Drag effect better then any other on the internet.
                            Imagine three magnet spinners with a dozen coils, one power three outputs in the center and four on each end for 1 power and 11 outputs total! I believe this setup has a strong chance of going over unity.
                            • #15
                              https://www.youtube.com/watch?v=_RVJ52Idfno&t=6s
                              Thanks for the delayed lenz motor. Something like the zero force motor.
