Ok, first I will say next...
If we make a start from frequencies, then obviously we ne ed to keep in mind the gradients. Gradients are the frequency difference. When we move from high frequency to low. Well, imagine that we have such a gradient in space. We are flying meter by meter deep into space, and the frequencies around us are getting lower and lower. The frequency of what is in space, for example, if we move in the air, the frequency of oscillation of air molecules. This difference in frequency will determine the difference in air pressure. And we will get an airflow, which will catch us and carry forward. This is how frequencies can work. Now if we don't have a frequency gradient, what should we do? We have to create it artificially. The famous Grebennikovs platform did exactly this. You probably haven't heard all the variations of how it works. In general, everyone is talking about the superior wings of bugs and the like. When the topic was not dirty yet, everything seemed to be working without bugs. Everything worked on the interference of light. Sounds crazy I know, but the light was the substance that changed the frequency of something else. We still do not know what is this else was. The method was connected with sequential interference. What does this mean? You must have three sources of ultraviolet light. I don't know why there are three of them, but this is the minimum. After one source of light comes the diffraction grating. Light passes through this grating and diffracts. After the first diffraction grating there is a second one with smaller cells. After the second diffraction grating there is a third with smaller cells than in the second and so on. The more diffraction gratings, the more efficient the device. The minimum is three diffraction gratings. Diffracted Light after all this diffraction gratings mirrored with an ordinary mirror and went back in the opposit direction and mirrored again then it reached the first source with an ordinary mirror also. This is a rather superficial description of the device. There naturally were some other secrets that we will never know. Naturally, no one has reproduced this. But the general idea was to make the light condense in one direction and decondense in other direction. In this process, the light was in contact with something, as I said, we do not know what it was. And in this something a gradient created. So the idea of making an artificial gradient on a diffraction gratings is close to that the crystal lattice of stones could do.
So they know nothing. And You see it is not the most effective way to convert sound into light...
Additional electrons injected into the disk are not part of the crystal lattice. And they can be freely moved. Moved as surface layer. I hope it is clear now that we need not kacher, we need an Tesla transformer with a rectifier at the end. A rectifier is needed to pass only a stream of electrons to the disk, and in the case of a reverse AC wave no electron should climb back from the disk to the tesla transformer. The more injected electrons on a disk, the better it will all work. In practice, I have never dealt with Tesla transformers and I don’t know if a standard high-voltage diode will work here. But in the times then Tesla buil all his machines (approximately 18xx-1917) there were no diodes. And all the rectifiers of that time, and perhaps today rectifiers to, can't stand hundreds of thousands of volts. I started browsing the site
). I don’t know what may change in the crystal structure of aluminum with temperature. From my point of view, a diamagnetic is ideal. Nothing happens to it at any reasonable temperatures. Of course I can be wrong and do not know something significant. But with a ferromagnet, and that's for sure, such as steel is full of surprises. One of them is the permanent magnet holder. The crystal structure behaves in a completely incomprehensible unknown to us way.
