New Member Fluxliner asked if I could post this: Consider it done.
I agree with Fluxliner's assessment of the Woodward Effect. There's already a broken/jammed more like link, but maybe someone can find it, or I will later on.
However there is this at the same link: a 337 page PDF on a workshop covering Mach's Principle and Woodward Effect. I should read this and you should skim this~
Oh brother, already? Page not found on the links. Well thanks for the validation I guess>
Fluxliner:
Sorry to PM you unannounced like this but I'm new here. After months of lurking here I finally decided to create an account but I don't have permission to post in the thread yet so I thought I'd just PM you about this.
The thrust that is created by asymmetrical capacitors is what the Woodward effect is about..you talked about it in your thread already but their research has been awarded with a NASA Contract.
Here is a link: https://www.nasa.gov/directorates/sp...tellar_Mission
The problem they have is the heat management. But in the ARV they solved this problem by using mercury or Gallium as a coolant and sort of like a wire to conduct the electricity to the plates. They must've been using a Van de Graaff generator or a Tesla Coil to reach the necessary voltages.
Now I've been thinking that if someone could replace this: Page not found | Space Studies Institute
Go to slide 10.
and here:Page not found | Space Studies Institute
they describe how a MEGA Effect Thruster is built.
So if we can replace their design with the Magnesium-Zinc Alloy that is sheeted in molten Bismuth and Copper and finally layered in a Silicon Dioxide Crystal with the Mercury or Gallium(I'd prefer Gallium since it's less toxic but I'm not sure if it'll still work) as a Coolant and Voltage Generator. Using a Mercury vapor turbine (https://en.wikipedia.org/wiki/Mercury_vapour_turbine) in conjunction with a high voltage generator and a Magnet. Yes a magnet.
Here is why I believe the antennae section in the ARV to be a Magnet that is presumably powered by the X-Rays.
This guy replicated TT Browns Gravitator: https://www.youtube.com/watch?v=DP1q95f6TgA
It gets interesting in the comments. He says:
"Another interesting thing is that, when charged, the capacitor is strongly affected by magnets. I put a powerful electromagnet (modified MOT) near it and it was strongly attracted towards the MOT. I didn't even need to "pulse" the DC, just when I started the power it was immediately attracted with much greater force than usual. This is something new for me - a dielectric attracted by magnetic field."
So here it is. There is no need for a pulsing the DC when the capacitors are in the presence of an Magnet. This solves a lot of problems for the MEGA Effect Thruster. They've been struggling to increase the frequency.
Now if someone could replicate this and prove it to be real and even better maybe even send it to the Space Studies Institute, better yet send it directly to Dr Professor Heidi Fearn and James F. Woodward that would be great.
Now I haven't got the money nor the expertise to built such a device which is why I'm writing this so someone else may get this done.
PS:I know NASA is usually in bed with the Establishment but maybe this is a attempt at soft/ fake disclosure?
It gets even more interesting when you start reading Dr. Woodwards Books. He talks about “arbitrarily advanced aliens" that produce stargates in a very hypothetical way...
Here is a link to his paper: https://physics.fullerton.edu/~jimw/stargates.pdf
Maybe you can tell the others in the thread about my ideas, that would be nice.
Fluxliner:
Go to slide 10.
but the frequency range at which to drive it at would be the question and the electrical parameters needed to drive it are yet to be known..
