Radiant circuit progress, series resonance, parallel discharge
I made a mistake and worked on the C4 L2 resonance.
But it turns out, L2 is series resonant with C5
C4 is charged by L1's back emf, when the mosfet turns off.
When the mosfet turns on again, C4 disruptive discharges parallel over L2 and C5.
This is a radiant energy event.
The floating ground (source of mosfet, it is NOT a earth ground), is connected to the separate powersupply (battery)
for the pulse generator driving the gate of the mosfet.
This is needed due to the high side switching with a N-mosfet
The mosfet needs to be low Rds, and capable of high current and high voltage.
Like the IRFP460A.
Switching on and off needs to be very fast.
L2 and L3 can step up or step down the voltage/current.
L2 is tuned for maximum current in L3, without having L3 tuned (no parallel C6 cap over L3)
For max current, L2 needs to have many turns, L3 few turns (but thicker wire).
Best results would need equal mass L2 and L3
C4 needs to have low ESR to be able to charge and discharge very fast. C4 also needs to have enough capacitance to violently discharge in to L2/C5 but needs to be small enough, to be able to get charged from L1 back emf in 1 cycle.
Best would be to parallel connect several capacitors.
Once L2 is tuned for max current in L3,
L3 is tuned to resonate, giving maximum voltage and current (in phase producing usable power in L3)
Parts are ordered and in the email, When I get decent results, I will make a video again, and explain it in more detail.
Like the IRFP460A.
