Splitting The Positive
    I realized my stingo was for some reason, not showing charging into an
    equal voltage 12 volt battery
    So now using 3 battery setup again, though this time, using the re-emf
    charger setup by rene.
    peace love light
    Sounds complicated, make a video if you can so others will understand
    too. I just picked up some chargers that are 97 percent efficient that
    are as close to 100 as you are going to get.
    The main thing is that you get completely familiar with what your
    battery is capable of in terms of the amounts it can deliver and low
    plate resistance is good also. Sounds like some circuits do that.
    • Resumed Baseline Testing
      Last night I got tired and went to bed so I unhooked the battery at
      4:10am the battery voltage was 11.67v. Next day at 1:40pm I started it
      back up and the voltage had recovered to 11.75v and now it is 2:10pam
      and I just checked the voltage again 30 minutes later and the number is
      11.65v.
      So as can be seen the battery recovered over night and is now lower than
      last nights volts. 15 minutes later it is 11.64v. This is an important thing
      to point out to you.
      WATCHING THE VOLTAGE DROP AT SO MANY POINTS PER HALF HOUR
      OR PER HOUR. Right now I am watching the voltage go straight down
      as witnessed by the meters. The amps are holding steady at 485ma
      The reason I point to the declining voltage is because when i hook my
      rewound scooter motor up to it with 1 or 2 boost converters to balance
      out the system the voltage drops so slightly my cheap meter can't read it.
      My more expensive meter shows voltage declines like this.
      Normally the voltage is read 12.20v and if it goes down it will look like
      this 12.19v on the cheapo, however another meter might read like
      this.
      And this is how small of an increment that the mod mtr drops 12.195v
      I had to wait so long for my cheapO meter to drop that I went looking
      for my meter that shows the extra digit.
      So if you tune your scooter motor timing and boost it to balance the
      3 batteries instead of a .19v-.18v per 30 minutes your reading may
      look like this .195---.194---.193 and so on down the line which is
      a 10 fold reduction in battery usage.
      Explain it? Not me. That is all i know about the mod mtr. But I do see
      the meters and know my batteries capability.
      My mine always goes back to the BIG MACHINE John Bedini called it.
      His large coils were connected in series and he was getting assisted
      rotor action for whatever the reason. Same here, for some unbeknown
      reason assisted rotor energy is entering from somewhere.
      It's almost time for a video at 3:00pm that marks a 24hr period for this
      batteries decline. It's a 16ah deep cycle the highest quality money can
      buy.
      • 24 hrs of battery measurements
        Thanks to John Bedini I found Aaron and his site.
        https://youtu.be/_5KiF0HctCA
        • Battery voltage
          As of 8:00 O'clock putting me at the 29 hr mark voltage is 11.30v
          and the amps are still right at 490ma. So a 30 point decline in 5 hrs.
          If the curve continues (I don't think so) it won't reach 10.50 to trip
          the alarm till tomorrow. Using our adjusted watt average of 6.35 w and
          multiplying by the 29 hour run this far :
          Let's lower that down to 6.30 watt average so then
          6.30 X 29 = 182 WATT/HOURS from the 16ah 12v battery. Luc was
          getting 70WATT/HOURS for a single new 5AH battery so using his
          number I will need more than 3X that or 210WATT/HOUR because
          this is a 16ah
          Looks like i may reach that figure sometime this morning and I go to
          bed around 3 am for the past 40 years. Luc's drain current was around
          150ma and mine is over 3 X that at 500ma which is right in line with
          the size of the battery. Looks like a C36 hr rate?
          So my maximum draw within the C20 rate I can run 800ma.
          I know that many of you think this is boring but we must see what our
          battery can hold before we can go for the extra and really be sure
          we are getting any.
          • Battery Voltage Dropping
            At 10:45pm the voltage dropped below 11v and is now reading 10.98v
            staying close by so I hear the ringing go. It stinks of an acid
            smell as it gives off it's last breath of energy. Got to go open the
            door. I'll be back soon. If is goes to 1:00am or 3:00am I'll chime in
            and show the figures.
            Deja Vu the last time i ran figures like this that takes hard work
            another site deleted them all and I have seen very few people on the
            web doing this boring job, with the exception of Luc.
            Can't wait to see the look on all the faces when i split the positive
            with this same inverter and send some back to the front end with
            a small boost converter that operates in the 97 percent efficient
            range.
            BRB
            • Final Battery Baseline
              Excuse me did i say 36hrs? No it wasn't it only ran 34 hrs at around
              a 6.2watt average multiplied by 34 hrs or
              6.2 X 34 = 210 watt/hours
              The 24 hr mark was 3:00 pm and at 1:00 am I disconnected.
              The battery is dead so I connected it up to the 3 battery function.
              More video coming
              https://youtu.be/bHDifuYTtNQ
              • It takes a while to upload and process video, I'm going to bed.
                It is going up now. I am camped out for the night.
                The Split Positive to Inverter video start time out is 1:45am and it is
                now just about 5:00 am now and after a little over 3 hours the
                battery differential has dropped from 14.8v beginning to 13.12v now.
                The two run batteries are at 12.38v and 12.34v each having a
                12.60v sitting
                The amps have dropped to 550ma and the charge battery has risen
                from a 10.50v after resting 45 minutes is now 11.61v.
                Looks like i will leave it run 8 more hrs till I get up so my battery
                keeps going higher, then i'll start thinking about when to connect
                the boost circuit at around 12.2v ? I think?
                • https://youtu.be/tY46iaY0-5w
                  I let the circuit run over night so I could get some charge back into
                  my battery and the inverter is taking the controlled amount of current
                  that it is designed for just as it did in the first test and at 8:30am I
                  got up to use the restroom and here is what I saw.
                  The differential was 12.58v, batteries 1 & 2 were 12.24v & 12.22v
                  and battery 3 was only up to 11.91v so I went back to bed.
                  I had to get up at 11:30am today and checked my batteries. They
                  all read the same reading. Battery 1 &2 were 12.13v & 12.12v while
                  the differential voltage was 12.11v with the charging battery charging
                  away the reading was 12.13v the amp draw was the same at 500ma.
                  At the beginning of testing straight off the battery the amp draw
                  was always a little bit higher at 550ma and after the experiment or
                  run got going the amp draw pretty much stays the same at 500ma
                  in both setups.
                  I could give a rats rear end, i am a regular guy with a garden light running
                  a pulse between positives that is using new split positive hook up that
                  is suppose to increase my time for the light.
                  I just don't know, so I am trying it. I stopped the run because all
                  batteries are equal. Time to connect the booster. I need 68 hrs to
                  break even on my time in the garden lighting.
                  • The experiment is stopped and this is a copy of battery voltages
                    with an average current draw of 500ma going to the inverter.
                    It appears that this device is becoming over compcated, this is a simple
                    device . To answer the question about the 12 volt battery it is charged at 15 volts anything below that the battery is not charged. You must bring the battery
                    to the end of the charge curve. You need the reserve energy to get the correct
                    Amp Hrs. In the demnstration I gave with the three battery system the balancing of the voltage is important weither we use 3 volts or 24 volts that is
                    not important, it's the differnce potential energy to charge the third battery
                    You must chose the load very carefully for this process to work. The load must run and charge the third battery.
                    John
                    John,
                    I understand what you are saying, and I understand the original intent of the 3 battery system. It was to rotate the three batteries and all three would remain charged. If the load was right.
                    What I stumbled upon quite by accident was that if you have the right "bad" battery in the third position, something happens, almost as if a gate is opened, and you can run the setup WITHOUT rotating the batteries...battery three increases in voltage, and sometimes even the primaries (batteries one and two) increase in voltage, and the motor runs loads while a load is also across battery three. In over eight years of experimenting with this setup, I have seen that happen several times. The first time it happened, it lasted for several weeks and I thought I was going to be rich. I have seen it last for days. I have seen it last for hours. Then suddenly it stops happening and the primaries begin to discharge. On two occasions when it was "working" I disconnected all the connections on the batteries and discovered that battery 3 had flipped polarity. It is possible that this is what has happened EVERY time it has been "working".
                    Several other folks have replicated this setup WITHOUT rotating the batteries and seen the same thing, although from the reports I have gotten the best anyone has had was a run of a couple days before it quit working. What we HOPED to find was a consistent method of getting a battery in the third position to achieve whatever state it needs to be in for this "gate" to open. We have not been able to do that yet.
                    As I said, I think it is about getting battery 3 to flip its magnetic polarity, not its electrical polarity, although I believe it flips its electrical polarity at the same time. But just because it flips its electrical polarity doesn't mean it has flipped its magnetic polarity.
                    So at least what I have been working on is not the same as the original intent of the circuit you were demonstrating, because I was NOT rotating the batteries. I realize that may just confuse folks, but I wanted to be sure that the difference between the two experiments is clear, even though the circuit is exactly the same.
                    • Got it running and balanced out for my first try.
                      Starting at 2:00am and counting. My differential is 12.55v
                      It's 4:00am and my diff. is 12.75v the 2 runs are 12.18v and the
                      charge battery is 11.70v at 2:00am the charge batt was 11.85v
                      so it looks like divergence or a greater potential difference
                      https://youtu.be/a48H03Y9LmE
                      • I got up at 1:30pm the fuse had popped again so I checked the
                        voltages. A1 &B2 were 11.86 and 11.84 the charge went way up
                        due to no power being sent back to the front end at 12.12 all
                        these voltages while the circuit runs.
                        I tried the booster again with 2 separate battery banks and is works
                        normal, it seems non isolated converters will not work with this
                        inverter. Learning the hard way.
                        back and forth unstable, finally I ran it again with a 70,000uf cap
                        across the boosters source battery or C3 to see if that might help
                        and I was able to adjust it way better, then it just popped.
                        Looks like I'll have to rotate the batteries sometime down the road
                        unless my other 2 converters come in time in the mail.
                        Maybe a blocking cap could allow the use of a non- isolated booster?
                        After running the little booster to charge up the front end it popped
                        after 20 minute but while my battery C3 was under a load and being
                        charged the voltages were 11.76v again the run batteries were 12.02v
                        and 12.04v during operation at this time.
                        The only other time I have used a boost converter was an isolated one
                        and I had not trouble with stability.
                        The inverter does not like my 900 watt common ground booster so
                        it looks like for switchmode inverter circuitry the isolation is a must
                        It is 6:30pm the run batteries are 11.74v and 11.76v the charge is
                        11.81v and the diff is 11.51v More video soon.
                        • It doesn't look good. Going south well before time.
                          All of my goofing around burning power and using a joule thief at
                          poor efficiencies and burning out one booster, I fear has doomed
                          my run. But I hope everyone is getting the idea on how to hook
                          one of these up if they get the right circuits. The right tuning
                          might make for a better test.
                          Thus far i have little control.
                          Can't give up tho it is to much fun.
                          I had a digital booster that gave me perfect control but these same
                          tests go south all about the same, however i have never documented
                          the exact data points.
                          It is 8:30pm
                          The differential is maintaining right at 11.44v while the other readings
                          decrease. A1 & B2 are 11.52 and 11.54 the charger has raised B2 two
                          data points at the expense of 550ma at 11.71v on the charge battery.
                          https://youtu.be/tZuF7yZ9Vvs
                          It's 9:30pm run batteries 11.48v & 11.51v boost circuit raising B2 three
                          data points. Diff is 11.39v and the charge battery 11.66v
                          It is 12:30am Sat morning
                          A1 & B2 11.28v & 11.35V with a diff of 11.18v and the charging C3 11.51v
                          It's almost 2:00am and I just swapped out the mickey mouse joule thief
                          one one of my smallest 4 channel SSSG bedini oscillators that gives me
                          more Horse power up to 20 watts. I is running at a full amp on the input
                          off the 11.45v Charge C3 battery then boosting to (IN GENMODE) to 23v
                          maybe 400ma is my guess after the translation has always been that
                          amount.
                          This drives the Charge (C3) battery down and pushes up the run side
                          to achieve a greater differential. My diff. was down to 11.04v and I did
                          not like that. I am starting to become aware more of the objective.
                          Keep the run side up high and the charge side down at a low resistance
                          to charge. Keep the run side maybe up to 25 or 26 volts by using the
                          booster that drives the charge battery down to a low potential.
                          For the moment 9 watts going back to the front end in hopes of catching
                          up. I should have been doing this all along but this is how you learn.
                          Next time around should be better.
                          it's now 4:30am the run batteries 11.04 & 11.20v with the diff at 11.16v
                          charge batteries 11.12v. The SSSG osc is barely keeping the nose of
                          this ship up, hopefully it will still keep from crashing over night.
                          At 7:30am this morning I was up checking the setup.
                          Batteries A1 & B2 were 8.5v & 9.4v the diff was 11.51v and charge 6.85v
                          • Experimental failure
                            SEE THE GRAPH UPDATE BELOW
                            With all the burnouts and bad tuning i learned what not to do.
                            I knew I didn't have the right stuff but had to give this a try for
                            me and others who think it was worth a shot. As can be seen my
                            run burnt power right and left and didn't even get close to 68hrs.
                            But what surprised me was that I could run batteries down so low and
                            still have 11.51v hitting the inverter. I should have known but I just
                            didn't think about it til it happened.
                            So that would mean, say I was living in a camper (been there) all by
                            my self and the sun had not come up for several days to charge my
                            3 dead 110ah batteries that choked the inverter at 10.5v day before
                            yesterday and I wanted to charge my laptop.
                            Just hook those 3 batteries up in split positive formation and you might
                            get another day out of them. Of course you might slaughter your
                            batteries unless you changed over to ALUM.
                            Anyway that is not the experiment. I was never told by Dave or Desa or
                            anyone else to make this test, I was told not to do it this way. Got
                            try it anyway.
                            A special thx to everyone who has come before me to show test results
                            you guys are awesome, even if you do talk to much.
                            It is 8:30pm
                            amount.
                            • NEW TEST RUNNING
                              4:30am this setup on Sunday morning, good night.
                              Run batteries 12.55v and 12.53v charge battery is charging 10.63v
                              and the diff is dead on 14.50v and I had to take some out of the run
                              batteries to get the diff below 15v. The inverter would not start up
                              and run on 15v so 14.5 is holding for the longest time .
                              The current is exactly the same every time I run this small inverter
                              at 550ma and the little joule thief is my only boost pump and is running
                              at 500ma.
                              It is a balanced system for the moment and seems to be hanging in
                              one spot forever. Let's hope so. The dead batteries tied together in
                              parallel are making for a much much lower resistance to the on coming
                              charge and after sitting on these meters for days I can tell a there is a
                              huge change.
                              • Here is pretty much what DESA said he was doing, tho I can't find
                                his posts anymore. Seems like with 2 boosters the losses would double.
                                DESA did not use an inverter,he used the mod mtr
                                DESA WROTE: Gift that keeps giving.
                                I run the setup today for close to one hour. I had no need to run it longer because answer was there plain and simple. My total loss after batteries rested was .2 v on series and I was higher than start on batterie 3. In attachment you can see all that you need to do math, plain and simple. I attached the DC generator that in open voltage runs at 235vdc. As loaded it run 110 vac CFL 20w lighting to full potential at 142vdc. In this test I attempted to replace resistive load with another Matt's modified motor it was unloade and shaft power don't forget is now free for taking also. It run at battery 3 voltage of 15.1 VDC at 1.6 A. Recirculating power was 2.2A and potential difference was 3.3 v, Sufficient to hold all in balance. To my surprise variable resistor had been reduced but it has more place to give to be eliminated compleatly. As I loade second modified motor the first one increases in speed accordingly. Looking at this all together I could easily see the two motors running in same direction on same shaft with the radial flux generator in between. Second motor running with additional boost converter feeding battery 2. Load of the generator would eliminate variable resistor and any drop in speed of motor one would be self regulating boosted by motor 2. Naw please all of you with know how let me know what you think.
                                As it is set now if I only recuperate CFL 20W this is in the money. Please let me know if my measurments or asumptions is wrong.
                                David.-image-jpg
                                When I had my original setup running, I was new enough to this stuff that I didn't know how to test it. My friend, who is an electrical engineer, told me the only acceptable test he would believe is if I put a kilowatt meter on the inverter hooked up to battery three and ran loads on battery three to measure how much actual power came out of the system, and could show more power coming out than was present in the two primary batteries, but this was impossible to do. The reason is, when you have a load hooked up and are running it, the kilowatt meter is continuously counting how many watts of power are being consumed, but the instant the power to the inverter is cut off for even a split second, that reading instantly goes blank, so you have to be watching the meter at that EXACT second. After running for two full days and losing several readings because I was trying to figure out how MUCH of a load I could put on the inverter without drawing the battery so far down that the inverter kicked off, I gave up on this. I kept drawing too much and the inverter would kick off and I would lose my reading. I was incredibly frustrated....mostly because I was running up against a deadline of writing a big check if this thing was real. Now they have meters that hold the last reading in memory. I didn't have one of those.
                                I then moved to a process where I would charge a 33 amp hour battery in parallel with battery three. I would charge it up until the volt meter showed between 13 and 14 volts (I checked it occasionally to see where the power level was, and anytime it was over 13 volts I would disconnect it and use it). I would then run two auto headlights off the battery until they went out, then connect it to the setup again and recharge it. I did this continuously for seven straight days, because THAT'S all the time I had before I was to meet with the patent attorney in California to discuss the possibility of a patent. I don't know how many times I ran that battery down and recharged it during that seven day period, but I was in that room day and night. I slept on a cot next to the thing and would wake up every couple hours to check it. Since I was going to have to write a check for $5,000.00 to the attorney, I wanted to be damn sure the thing was doing what I THOUGHT it was doing. I was using three 18 amp hour AGM batteries on that setup. Only TWO of them held a charge. so that's only 36 amp hours of power. And I was charging a 33 amp hour battery to full charge. Yet those two auto headlights ran over and over and over again for all seven days before I took the setup apart to take it to California. How many times would YOU have to recharge that 33 amp hour battery off the setup before you were convinced? I know I was doing it several times a day.
                                As to the attorney, I can give you his name and number if you are interested. I KNOW he will remember me because he told me I was the first person EVER to bring a working "free energy" system into his office to demonstrate it for him. We only ran it for a few minutes because the motor is so loud, but we DID run it. And I did write the man a non-refundable check for $5,000.00. When the thing quit working I was pretty sick to my stomach over that check I had written. By that time, I was back in Arizona. I wrote him a letter of explanation and requested that he refund any unused portion of the fee. He didn't have to, but the guy sent me back (I think it was) $3,000.00 (might have been $2,000.00) even though he had already begun the process of searching for conflicting patents.
                                So if you want to call and check out whether at least THAT part of my story is true, you can. I don't remember his name, but my wife knows him (as she is in intellectual property law) and she will remember. In fact, she sent me his info a couple weeks ago and I can probably search my e-mail and find it. One way or another, I will get it to you if you are interested. I would certainly recommend the guy after the way he worked with me, that's for sure.
                                I have had the system working since then too. On several occasions now. I haven't let it run for long periods of time, and I guess the best thing I could do is the next time it is up and running, record two solid hours of video with my big video camera of it running loads so everyone can see it run for two hours continuously until the tape runs out; run devices requiring several hundred watts of power usage during that time, and still charging the primaries.
                                I texted my wife earlier as to the attorney's name, and she just responded on my phone. It is:
                                Amir Raubvogel
                                voice:
                                fax:
                                amir@raubvogel.com
                                Currently:
                                Co-chair of Patent Group at Palo Alto Area Bar Association (PAABA)
                                Patent Attorney at Raubvogel Law Office
                                Past:
                                Patent Attorney at Fenwick & West LLP
                                Software Engineer at Digital Pictures, Inc.
                                Education:
                                Yale Law School
                                University of Toronto
                                This thing is for real. We just need, as Matt said, some folks to get off their butts and help us figure it out....or you can do nothing....
                                Once upon a time, there was a little red hen who lived on a farm . She was friends with a lazy dog , a sleepy cat , and a noisy yellow duck .
                                One day the little red hen found some seeds on the ground. The little red hen had an idea. She would plant the seeds .
                                The little red hen asked her friends, "Who will help me plant the seeds ?"
                                "Not I," barked the lazy dog .
                                "Not I," purred the sleepy cat .
                                "Not I," quacked the noisy yellow duck .
                                "Then I will," said the little red hen . So the little red hen planted the seeds all by herself.
                                When the seeds had grown, the little red hen asked her friends, "Who will help me cut the wheat ?"
                                "Then I will," said the little red hen . So the little red hen cut the wheat all by herself.
                                When all the wheat was cut, the little red hen asked her friends, "Who will help me take the wheat to the mill to be ground into flour ?"
                                "Then I will," said the little red hen . So the little red hen brought the wheat to the mill all by herself, ground the wheat into flour , and carried the heavy sack of flour back to the farm .
                                The tired little red hen asked her friends, "Who will help me bake the bread ?"
                                "Then I will," said the little red hen . So the little red hen baked the bread all by herself.
                                When the bread was finished, the tired little red hen asked her friends, "Who will help me eat the bread ?"
                                "I will," barked the lazy dog .
                                "I will," purred the sleepy cat .
                                "I will," quacked the noisy yellow duck .
                                "No!" said the little red hen . "I will." And the little red hen ate the bread ALL BY HERSELF.
                                Get the picture?
                                Dave....Ye old Teller of Fables
