Joseph Henry's 1842 and 1843 Out of Doors Electrical Transmission Experiments.
  • #16
    You have probably seen demos like the attached video on YouTube, but in case you haven't, this is a similar situation,using far LESS voltage than you would get with a lightning strike. but showing how magnetism can be induced WITHOUT direct contact by the wires.
    Magnetic nuts - YouTube
    • #17
      Linked induction.
      This video by Skycollection is the next step of linked inductance running off 12 volts of supercaps: He's multiplying the number of bulbs simply by raising the voltage! This is an Overunity progression. Would it be possible to use the Earth as additional coils?
      • #18
        Inductive coupling effect
        https://www.youtube.com/watch?v=mZgqoJ_DCTs
        I am skycollection, from Mexico, my principal problem is that i have no experience
        in electronics, i studied ECONOMY but my hobby is the TESLA PANCAKE COILS
        and the other problem is that i have no economic resoucers to buy technology
        instruments to measure the panckake coils. I based my experiments like a blind man, anyway i hope someone can make a replication of the multifilar pancake coils. Saludos...!
        • #19
          Well..welcome to the club! I have also so limited, probably even more then you. Your method of winding pancake coils is brillant ! I really like to replicate it .
          • #20
            Hydrostor.
            This is the highest state of the art in "Electrical Grid" conservation; Stores "Off Peak" energy in balloon batteries:
            Canada Plans to Store Energy in Giant Underwater Balloons | Digital Trends
            Tesla:
            "When there is no receiver there is no energy consumption anywhere. When the receiver is put on, it draws power. That is the exact opposite of the Hertz-wave system. In that case, if you have a plant of 1,000 horsepower (750 kW), it is radiating all the time whether the energy is received or not".
            • #21
              I am planning to build a new "multifilar pancake coil" soon, but with different ohms resistance, i have only one coil pentafilar, septefilar, quadrifilar, etc, but i need more results and more tests, the pancake coils are amazing...!
              the next multifilar pancake coil will be "inside of a permanent magnet" with ferrite magnets and with this, is possible to get more output voltage...!
              saludos
              Jorge
              • #22
                Multi-filar pancake coil
                The multifilar PANCAKE COIL consist of a group of six pancake coils, every group have four pancake coils connected in “series”. In total i have 24 pancake coils inside of the PVC PIPE and all the groups are insulated from each other, only one of the six groups is connected to the circuit and the other five groups, they are not connected, only with the bulb of leds, they are “like pickup coils”
                When i pulse the circuit, one of the groups “induces” the voltage to the rest of the groups and the leds turn on with great intensity...!
                • #23
                  Multifilar pancake coil is not easy to build...!
                  • #24
                    core
                    Hi Jorge,
                    I looked at your pdf , I am curious to what the core is ?
                    To be clear you have 4 coils per group correct? 6 groups?
                    Are they 4 bi-filar windings connected in series to make one group or are they 4 single wound coils in series to make one group?
                    I'll wind some to give it a try.
                    Thanks artv
                    • #25
                      Multifilar pancake coils
                      One group consist is four "single pancake coils" connected in "series", the other groups are the same, all the groups are isolated from each other and only one group is connected to the circuit, one group "induces" the voltage to the rest of the other groups with very high intensity...!
                      In my multifilar pancake coil it was not necessary to use "bifilar" pancake coils, i used "single wire" and the result is the same...!
                      Saludos from mexico...jorge
                      • #26
                        Ha, i forget to say that the core is "ferrite" i am using ferrite core down and on top (two ferrite plates) and two ferrite ring magnets
                        is with the objetive to make experimentation..!
                        • #27
                          Excess Base-Load Capacity.
                          Where does "Excess Base-Load Capacity" go when adjacent reservoirs of different heights are unavailable?
                          "In many places, pumped storage hydroelectricity is used to even out the daily generating load, by pumping water to a high storage reservoir during off-peak hours and weekends, using the excess base-load capacity from coal or nuclear sources. During peak hours, this water can be used for hydroelectric generation, often as a high value rapid-response reserve to cover transient peaks in demand. Pumped storage recovers about 70% to 85% of the energy consumed, and is currently the most cost effective form of mass power storage. The chief problem with pumped storage is that it usually requires two nearby reservoirs at considerably different heights, and often requires considerable capital expenditure".
                          "Power for Tesla's entire Wardenclyffe power transmission system was to be provided by a coal fired 200 kilowatt Westinghouse alternating current industrial generator".
                          "In 1917, the 187-foot tower was destroyed by dynamite explosion as ordered by the U.S. government".
                          • #28
                            China shutdown.
                            Beijing (AFP) - Beijing ordered hundreds of factories to shut and allowed children to skip school as choking smog reached over 25 times safe levels on Tuesday, casting a cloud over China's participation in Paris climate talks.
                            • #29
                              That's all sad, I know that from experience because in Poland we have 80% of houses heated by dirty coal dust and in many towns smog is almost like in China.
                              The main big problem is that the solution is not in hands of goverments - they had like 180 years to evolve society into a peaceful world with free energy everywhere.
                              • #30
                                Thanks Jorge,
                                When you tried the bi-filar windings , did you try all possible connections?
                                artv
