That last motor looks good! Looks like shaft is long enough to actually USE it for something.
I put two coils in the machine and started it up. Very unpleasant grinding sound. Apparently the cores are sticking out far enough to rub on the rotor magnets. Some grinding needs to be done and I can't hold the coils with one hand to do it. Going to have to build some kind of jig to hold coils. Plus, core is made out of many tiny wires glued together with high temp epoxy. Grinding may do a number on them. Would be best to put a sleeve of pipe the right length on the end of the core, and grind off anything that sticks out past it. That would hold the wires in place and keep them from getting ruined. Got a call in to see what we can do. Maybe spacers/shims a few 1,000ths thick with a 3/4 diameter hole is the way to go. Slip a few on the end of the core before I put it in and rotate rotor by hand to see if problem is solved. Epoxy each one so magnet doesn't remove it if they are magnetic.
I did a whole video on how I filed each core to make sure it fit in the hole (diameter) but didn't think to check for length. I didn't make the coils. I just wound them. My partners made them. Core was supposed to stick out of coil 1/4". I KNOW they used a 1/4" spacer!!!!
This is a complicated box, don't do anything rash. Those cores need a machinist to make it flush all of the way across. In other words a very sharp tool not a dull grinder. Get them all Machined. Remember you had the box re-done and that could have changed things. I saw the ends of the cores and they look rounded
if it pins the needle on start up, it is toast.
