SkyWatcher, you should see a fairly large increase using a quartz infrared element. Also, you can try the 100 watt halogen bulbs - fairly inexpensive - these perform quite well. They have a wider frequency range and I've found them not quite as efficient as the quartz but still produce lots of heat. These are generally used in shop lamps and have a glass cover to filter out the UV - inside your test rig the UV shouldn't be a problem - never look directly at the light ( any UV producing bulb ).
The oscillating dish's sound interesting, I don't think I've seen that....
Here is a quartz type bulb... Amazon.com: Sylvania 58887 100-Watt 120-Volt Tungsten Halogen Double-Ended T3 Quartz Lamp with Clear Finish: Home Improvement
