Originally posted by BroMikey
Gerard Morin Energy
I've just a question. When you connect the load in the output of the washer water drain pump generator... there is a magnetic "brake" in the motor as in an ordinary generator or it can be considered a lenzless generator?"A knot cannot be undone, without knowing the way it was made" Aristotle
Drain pump motor is similar to a Gramme dynamo
Well, after looking in the internet for a while I've found that the drain pump motor is basically a Gramme dynamo modification. It has been known for years that a gramme ring armature generator is a kind of a lenzless generator. The drain pump motor only is a variation of the Gramme, but it's very similar."A knot cannot be undone, without knowing the way it was made" Aristotle
I don't know what amount of torque has the generator, but... someone has thought about using a Newman motor to move the generator?
The newman motor consumes very little energy and it could replace the DC motor. Maybe a good option?
Newman motor + Gerard Morin???"A knot cannot be undone, without knowing the way it was made" Aristotle
Hi
Yes right, but I don't really know how to explain it, just
connect it up and try it.
It sounds like you are much
better at the technical terms.
Maybe it is some sort of magnet coupling that causes
some to do better than others with it. One guy says he
can get more out than he puts in using a slayer exciter
and what looks like a Tesla tower all fed by Gerard's
motor/genny.
I like listening to people like you who can explain and
connect terms with effects.
Say on, my man, say on.
I don't really like the DC motor as the movement source. If you've seen the video "electric motor secrets" from P. Lindemann you'll know what I'm refering to.Originally posted by BroMikey View PostHi
motor/genny.
Maybe a Newman or Rotoverter motors as the movement source would be a better choice than a conventional DC motor. Right?"A knot cannot be undone, without knowing the way it was made" Aristotle
The main thing I want to know if there is any change in watt consumption of the DC motor when a load is connected in the output of the water pump generator.
Someone knows anything about this?"A knot cannot be undone, without knowing the way it was made" Aristotle
Thanks, I'm watching it.Originally posted by citftaHi Magnethos,
Here is a link to some testing and discussion about the pump motor. There is also a video there showing the testing.
Carroll"A knot cannot be undone, without knowing the way it was made" Aristotle
You are absolutely right. Wanting to get away from a dc brush motor,.
Going into an electric 3 phase, aircraft electric RC motor.
The torque on the pump is much less, just enough to get it spinning. Less noise, has benefits all over.
You are right about the generator, if resembles the past.. we have known for a long time that spinning a magnet inside of a coil will do interesting things, but what and how we can harness, that is where I am at now.
Hi Gerard,Originally posted by Gerard_Morin View PostYou are absolutely right. Wanting to get away from a dc brush motor,.
About replacing the DC motor with other option, I've been thinking in these motors:
1. Newman motor
The newman motor consumes very little power, in the range of milliamps. But it has low torque. The next video is a stronger version that consumes 1 amp and has a 8,000 revolutions per minute.
https://www.youtube.com/watch?v=Rw156mdrFU8
2. Kundel motor
A modification of a 'speaker motor'. It's based on a magnetic effect where magnets are moved in a longitudinal axis (back and forward) and that longitudinal movement is translated to rotational movement by a magnetic effect. Trying to stop (adding resistance) in the rotor, doesn't affects the power consumption. High speed can be possible.
https://www.youtube.com/watch?v=wC50BPyx6AA
3. Rotoverter
I know very little, but it's based on changing the wire winding configuration and using high frequency electricity. It seems to run cold.
In this video, the author claims to run the motor on 180 milliamps @ 120 vac with no load.
Maybe it could be engineered to use the Kundel effect (load on the rotor doesn't affects the power consumption) and maybe it can be run on 120Vac 180milliamps.
https://www.youtube.com/watch?v=RzO_lzgfoKM
4. Magnetic piston motor
The title says all. It's like a car's motor using coils to energize the pistons.
https://www.youtube.com/watch?v=5qwq5Rejq4E"A knot cannot be undone, without knowing the way it was made" Aristotle
Experimenter Matt getting more out taking all the cake
https://www.youtube.com/watch?v=Omj8aJa91Rs
https://www.youtube.com/watch?v=AmLWHLZ1Zh0Last edited by BroMikey; 06-01-2015, 07:18 AM.
Replica HV output. Some people can only get 20 volts.
https://www.youtube.com/watch?v=znsxcsQw6qQ
https://www.youtube.com/watch?v=Hxi4nOouXNs
Hey Ortho-Man I see you are standing tall today.
I guess free energy is a mistake
is that what you
think.
Gerard said he was going to be back with the new
better build so let's keep it alive who knows.
What did you think of Matt's video I posted?
Did you see his TV chassis?
Can't smell you brother. I told you I hit the ignore button but if you want to play bump the thread with no attempt to show real measurable results for the next few years, I'm ok with that.
I'd be better if Hitby and Gerard would come back and tell us all something was real about this "simple energy multiplication" technology. But that ain't gonna happen is it? (Rhetorical Question that I already have the answer to)
Failing that, you could simply admit that you were duped. Yeah, that would work too.
I guess if ya wanna look at it like that because I haven't poweredOriginally posted by OrthoParameter View PostCan't smell you brother. I told you I hit the ignore button but if you want to play bump the thread with no attempt to show real measurable results for the next few years, I'm ok with that.
my home yet, you are right about all of these cute/cool projects
I hope everyone you mentions gets back with the data so you an I
can build a unit to run some lights. Did you see the Matt Drummond
replication of Gerard Morin pump motor?
He is doing pretty good. I am not the only one here. I started
the thread, that's all. I understand that radiant can be produced
with the Gerard Morin pump motor/Gen.
The big experiment never really got off the ground because
we didn't get the same components as Gerard used.
So unless we do it the way he did it, the test is incomplete.
However a few of the guys were nice enough to buy HITBY
a McCulloch Genset so he could get closer. But I don't think
its over till you know what
No hard feelins homie?
So whats your project looking like? Or is that top secret?
Smells like a stinker to me? Are you messing up?
Anyway let us all know about your weakness with free
energy so we can polk a little fun too. Or are your
shoulder to narrow?
Spit it out like a real man, show us how much extra you got.
I am ashamed to say that I am not getting much extra. I could
but don't have enough time some days and I feel old lately.
The pole pig experiment is great using the factory done
transformers don't you think?Last edited by BroMikey; 06-16-2015, 06:44 AM.
