BiTT OverUnity Transformer Bi-Toroid Thane H. Bill A.
I'm trying to tell you, it's already here
A split-flux transformer has a primary or input coil, at least two secondary or output coils, spaced apart and arranged in 3D, a magnetic core running through the primary and secondary coils, a source of electricity connected to the primary coil which when turned on creates a magnetic field in the core, and electrical wires connected to the secondary coils, each of which provides additive electricity into an output circuit.
This is the one I like best by Bill Alek. He input a few volts of perfect sine wave AC at 3000hz and got
30X COP recovery, then just disappeared. Also you will notice that one of the two secondary windings is just a little bigger than the other even at higher frequencies. At the lower frequencies (60hz) Thanes BiTT showed a much more pronounce sort of loop sided ratio having one secondary much much larger. Any design works. This was posted by SAV
Here is a recent entry https://www.reddit.com/r/Physics_AWT...ment_timestamp
US9620280B2 patent: Split-flux transformer of Wiliam Alek from AuroraTek Inc. is variant (improvement) of Thane C Heins Bi-Toroid BiTT transformer, which should exhibit an overunity effect.
See (replication, (overunity forum) from demo video. Note the bifilar output coil arrangement similar to Infinity SAV device / but this site proposes another wiring and negative resistance load for to have transformer working. You'll need a super high permeability for the core (like Metglas, Nanocrystaline or Permalloy cores with permeability > 5000most power at the output. Premagnetization of cores by permanent magnet helps (the oscillations of magnetic field should run along inflex point of hysteresis circle). Resistance is also important and you must keep a small resistance in wires for to keep ohmic loses low.
