free energy can be multiplied with pulleys
  • free energy can be multiplied with pulleys
    I would like this to be truly free energy
    As in, free of any patent or copy write fees
    So, I only want this technology entered
    If it can still be freely used by all
    I do not want anybody to claim ownership
    Free Energy is such an obviously simplistic discovery,
    - as well as being extremely free + easy to produce,
    what is the only reason for us missing this basic idea,
    - we have been dumb to this free energy technology .
    This technology has been hidden for far too long,
    Please, go to this website
    Search free-energy + yolasite
    Or if this website allows URLs
    If this is so easy, where is your setup? Any pictures or videos? Any real measurements? No? Why? If it is so easy and certainly works?
      You've already started another thread on this within the last two weeks.
      Have you ever ridden a bike that has gears on it up a hill? Try it and you will discover the catastrophic error of your logic.
        Hi folks, The one thing about these posts, unless i have missed them previously, he never replies to peoples comments or questions.
        That_prophet, if i had direct evidence that what you say is true, i would certainly be replying to peoples questions and trying to help a little more, since it seems you want people to know about this based on the amount of threads and posts you have made about it.
        Also, he did say that he discovered this while using his electric scooter and that everytime he went down the hill in regeneration mode, the scooter was able to climb ever higher up the hill.
        And we have the wilson large diameter wheel generator that used a 4 foot diameter or something wood table and the tilley setup and the chas campbell setup and many others.
        So i see no reason to doubt his claims, unless i build one myself and even then, if i didn't properly build it, it probably will not work.
        As sort of an analogy, that_prophet does not need to prove to me that it's 30 degrees F. outside, if i really want to KNOW, i go outside and check for myself.
        peace love light
          I think that it sounds pretty obvious to me
          you power a large pulley to rotate only the once (minimal)
          and then you can get 2 or 4 mini-pulleys
          to rotate many times = 10s to 100s of times
          soooo,,,, INPUT = 1 rotation
          OUTPUT = 400 rotations
          (YOU MUST GAIN AC ELECTRICITY)
          Why do you need more proof = prototype
          this is extremely obvious that it should work
          400 to 1 rotation multiplication = major amounts of AC electricity
          That_prophet, if i had direct evidence that what you say is true, i would certainly be replying to peoples questions and ROTATIONtrying to help a little more, since it seems you want people to know about this based on the amount of threads and posts you have made about it.
          peace love light
            Every action has an equal and opposite reaction.
            By this law of physics, all mechanical devices have the potential to be overunity, but it is just that, Potential energy. Find a way to release that, while at the same time benefit from creating it, and you will have a free energy device. I don't think it can be done purely mechanically other than with a water wheel or windmill.
            It is the same problem electrically, by charging a pole we cause an opposite charge to arrange itself around the pole for free, yes we can get most of the energy back from that pole by discharging it, but as no work is done we don't harness the potential. There always has to be another factor working in a different plane for us to benefit but there is a possible solution here. When a current flows we create a magnetic field that can do work, and that field is at 90 degrees to the current flow. We charge a battery and use the flowing current to do magnetic work, we then discharge a battery and use the current to do more magnetic work. as long as our losses are less than 50 percent we benefit.
            The only problem I see with a purely mechanical device is there is no work done (as far as I know) in a second plane at 90 degrees to the force we exert. it has to be at least 90 degrees because then it has no negative influence on what we are doing. It could be at 180 degrees, but not less than 90 and not more than 270.
              Hi folks, Hi that_prophet, thanks for the reply.
              I don't need proof from you, i would need to build it myself, to prove it for myself, though it would be nice if you did show your own working model, though not completely needed.
              Meaning, since it still looks like we have to build our own excess energy device, because some people in this world have problems with sharing, so if i get the resources in the future, i will build one.
              Meanwhile, i'm going to guess that the main pulley needs to be of a considerable mass, since most other similar devices required this also and some used pulsed input as well.
              I recall an experiment i read about, where they rotated a certain mass flywheel up to speed and it took a certain power input to do so.
              And if they kept it spinning for a bit and then stopped the flywheel, then as long as they spun up the flywheel within a minute or so, it took far less power to bring it up to the same speed.
              Though if they waited too long with the flywheel at rest, then it took the usual input power to bring the flywheel up to speed.
              This experiment highly suggests, that the space the flywheel is in, is caused to rotate, similar to running in circles in a pool of water and it continues to rotate for some time, trying to take us with it.
              So, the bigger and heavier the flywheel, the more the space (water) that the flywheel is within, will be agitated to move along with the mass or flywheel, adding excess energy.
              Almost like a tesla turbine, though in this case, the medium used to help propel the disks (flywheel), is invisible to the eyes.
              peace love light
                I think you can generate large voltages with this system, however when you start to load your generator you will be brought back to earth as currents will start flowing and torques will have to be overcome.
                Unless there is some influx of energy from permanent magnets, the ether or any other source, you will be stuck with the simple formula Power= torque X r.p.m.
                The schematics shown on the website are quite similar to the the WITSS system apart from the fact that there are no capacitors to make resonant circuits.
                I recall that there are some videos on Utube showing contraptions with many pulley's but proper measurements are not shown.
                Best of luck
                Ben
                p.s. I found the video. check https://www.youtube.com/watch?v=8QD2Whs_LxA
                    This is now confirmed to be a spam bot.
                      Hi if you are not an spam bot perhaps what you need are a coupe houndred hours of hard work and you will discover that when youll load your generators they will stop the whole thing in a couple of seconds
                        I agree! It seems really like a spam!!
