Hi, all.
In another forum, I was reading about Tesla bifilar wound coils, and how they create a much stronger spark than a regular coil.
So I got to thinking, why not a *tri*filar wound coil? Wouldn't that provide an even stronger spark?
So, I mocked up a drawing (see attached). As you can see, it's a standard Tesla bifilar wound coil, with an additional winding on the outside of the standard bifilar coils. The additional winding would be of smaller wire, and would be approximately the same number of windings as both the other windings put together (so if winding 1 and winding 2 each had 100 loops, then winding 3 would have 200 loops).
Having very little in the way of electrical knowledge, I'm hoping some of you can answer my questions.
1) Would this provide a stronger spark over a regular coil?
2) Would this provide a stronger spark compared to a Tesla bifilar wound coil?
3) Would making a quasi-quadfilar wound coil be better, with the purple wire coiled inside *and* outside the two regular bifilar coils, then connected in parallel?
4) If I were going to build one for use on an engine, and built it to produce a spark strong enough, how would I isolate any back-EMF from the ECU?
5) Is there an algorithm in which one could plug in the wire size, wire length, number of loops, etc., and determine roughly how many ohms resistance the coil will have?
6) Is there an algorithm in which one could plug in those same parameters, along with the voltage that is pulsed into the first winding, to determine how much voltage one would get out of the third winding?
7) What would be best to use for the coil core? Air core? Regular iron core? Ferrous fluid core? Permanent magnet core?
8) How would one go about measuring high voltage? I want to aim for making about 75 to 100 kV. Is there such a beast that can measure that kind of voltage?
9) Is there coil winding equipment one can purchase or build, or does one do all this by hand?
Thanks, guys.
Thanks, guys.
