A Real Life Free Energy Generator - A Table Top Fusion Reactor
  • A Real Life Free Energy Generator - A Table Top Fusion Reactor
    Robert Murray Smith has begun a new project and put a call out to those looking to help replicate and bring this about.
    Thought it would be of interest to this group.
    Will post updates from time to time here.
    IndianaBoys
    Published on Dec 4, 2013
    This is a project I am sure I will never be able to do on my own. What I think is needed is a team of people to bring it to reality so - if you are interested, I would love your help. Annoyingly i realised i got the polarity wrong - electrons are attracted to the positive repulsed by the negative - i was tired when i made this - please don't point it out to me - i know!!!
    Polywell Nuclear Fusion
    Theoretical background information Robert posted to help better understand.
    He is looking for the end product to be the size that would fit on a table top, sized to run a house and open source for all. This is grass roots and a variety of skills are welcomed to join in and help.
    Polywell Nuclear Fusion Home
    Beam Fusion
    Beam Fusion Org
    IndianaBoys
      Open Source Nuclear Fusion
      Geek Group Farnsworth-Hirsch-Meeks Fusor
      Should Google Go Nuclear? Clean, cheap, nuclear power (no, really)
      LIFE: Laser Initial Fusion Energy System
        perhaps the Needs?
        Sir
        Thank you for sharing this very interesting effort!
        Perhaps if the Needs or requierements for replication were listed in some fashion?
        Equipment ?
        Circuits built for what needs /to what tolerance ?
        Any thing you can share would be Nice!
        I know too many people in a group can make it noisy and slow.
        perhaps some highlights and bench mark goals towards this replication ?
        thank you
        Chet
        PS
        working inside a light bulb /glass vacuum tube is a very cool and simple idea!!
        BE that change !!
          Sir
          Equipment ?
          thank you
          Chet
          PS
          Hi Ramset,
          You can send Robert an e-mail to robertmurraysmith64@gmail.com so he can send you the invite.
          IndianaBoys
            A nuclear engineer Prof George Miley took a good look at this "fusor" several years ago. Basically, the Farnsworth Fusor going back decades. Its a good idea, based on true hot fusion... but getting those deuterons (or d-t) to fuse is not so easy. Mostly they just collide elastically ("bounce off").
            Miley said that the device would make a decent source of neutrons; but NOT net energy. I suggest you check with Prof Miley or his published papers on the fusor; or if you have improvements, he would be a good one to talk to. He's very approachable.
              Muon,
              Thanks for the info. Will forward it to Robert to check into.
              IndianaBoys
                Hiya Guys - I just registered so i could join in in this thread. I know the fusor is incapable of breakeven fusion and I believe this is due to the grid 'sucking energy' out of the system - that's a bit of a short hand way of describing what actually happens - anyway - the thrust of development for IEC has been getting rid of the grids or making them invisible - I think that's what Bussard was up to when he designed the polywell. Beam fusion is mostly about getting rid of the grids altogether and using electrostatic optics - I was thinking that flight time might be used to achieve the same effect - I have to admit I have no idea if this will work - but the idea intrigued me and I thought it might well be worth investigating - so - with the help of a lot of others - that's what we are doing. If you want to have a look at the basic idea it's in the link to the video - rather than repeat it here and I would greatly appreciate your input
                  The Testatika Solved? - The Farnsworth Multipactor as an Electron Cascade Devic
                  The Testatika Solved? - The Farnsworth Multipactor as an Electron Cascade Device
                  The Testatika Solved? - The Farnsworth Multipactor as an Electron Cascade Device - YouTube
                  Robert Murray-Smith
                  Published on Dec 8, 2013
                  This is just an exploration of a few ideas I had a bout the farnsworth multipactor from reading the patents 2071515 and 2071516 and how the relate to the Methernitha Testatika (Thestatika) as a possible solution to the 'hidden' electron cascade component that is the key to this machine but has never been revealed. I am taking a functional view here - that is - if what is needed to complete the machine is a cascade device and the Methernitha guys won't reveal it then what else will perform that function. I also think it would do the same job for any electrostatic generator like a wimshurt generator or a kelvin water drop generator.
                    TTF03 - Making A Fusor Begining To End - 60 minutes
                    Robert Murray Smith has started the building process and created a real good step by step video for those wanting to join in and build this device.
                    TTF = Table Top Fusion
                    Thanks to those joining in on this build,
                    IndianaBoys
                    TTF03 - Making A Fusor Beginning To End - 60 minutes
                    Published on Dec 22, 2013
                    TTF03 - Making A Fusor Beggining To End - YouTube
                    The first three minutes of this video give details of the made fusor the rest of the video is a step by step demonstration of how i went about making the fusor which I understand might be quite tedious for a lot of people but might be quite helpful for a lot of others - so, sorry for the length - but I hope it helps.
                    TTF01 - Removing The Ceramic Core Of A Spark Plug - make a non resistor spark plug
                    TTF01 - Removing The Ceramic Core Of A Spark Plug - make a non resistor spark plug - YouTube
                    Published on Dec 20, 2013
                    This is about removing the ceramic core of a spark plug for use as a high voltage feed through for a fusor but it can equally be used to convert a resistor spark plug to a non resistor spark plug for HHO experimentation and water fuel experiments.
                    TTF02 - Building The Fusor - Design and Materials
                    TTF02 - Building The Fusor - Design and Materials - YouTube
                    Basically this is a simple fusor design and a list of the materials i will use to build a fusor
                    Cutting glass bottles into rings easily with thermal stress
