Log Periodic Golden Ratio Coaxial Waveguide
  • #16
    New Wiring Diagrams 2
    • #17
      • #18
        Dimensions of Acrylic Cylinders
        LAMBDA = Length of Cylinder 0
        ALPHA = (1+sqrt(5))/2 THE GOLDEN RATIO
        T = Thickness of the metal foil wrapped around each acrylic cylinder.
        K = Spacing between the OD of one cylinder, and the ID of the one it fits inside.
        • #19
          • #20
            Waves and Vortices in Continuous Media
            Part 1: Waves and Vortices
            In a continuous medium, such as air, you can have waves. Sound waves are waves of air.
            Light is also a wave, but it is not a wave of air. Light is a wave of Ether.
            A vortex can form in air. A tornado is a vortex of air. A vortex can also form in Ether.
            This technology creates a vortex in the Ether.
            Part 2: What is a vortex?
            When a record spins around on a turntable, the outside edge spins faster than the middle.
            When air spins around in a tornado, the middle spins around faster than the outer edge.
            A tornado is a vortex. A record is not.
            A vortex may look like a spiral, but that is just an artefact created by the circular motion of the medium. The medium spins around in circles. It does not spiral towards the center.
            When you stir water in a bucket, it makes a vortex. The vortex makes a funnel shape. If you look at this funnel from the side, it has the form of a hyperbolic horn. The bottom point of this horn is infinitely far below the surface of the water.
            A vortex is like a fire, in that they can both draw energy from their environment into themselves, thus growing larger and more powerful, and then able to draw even *more* energy into themselves. etc.
            This process is called Growth, and is a characteristic of living things, such as trees.
            • #21
              Stainless Steel Foil Cylinder
              LAMBDA = Length of Cylinder zero. Can be anything.
              • #22
                Capacitively-Couples High Voltage Switching Device
                R1 = approx. 1 K
                R2 = approx. 1 MEG
                c1 = approx. .1 uF
                1.995 MHz is the experimental part of the General Class 160m HAM band.
                A square wave will work. You want pulses that are 1 u-sec or shorter.
                This is a simpler way to hook up your Triode, if you don't want to make a Half-Bridge.
                • #23
                  • #24
                    • #25
                      Ok
                      a metal toroid creates a barrier that energy will not pass through unless there is a conductive path.
                      in other words there has to be a current carrying wire, Ideally more than one.
                      watch this vid an iron toroid stops 300,000 volts, it creates a barrier
                      300Kv On A Television - YouTube
                      • #26
                        EXAMPLE: Acrylic Cylinder Dimensions
                        LAMBDA = 23.622 inch = 60cm
                        T = 0.002 inch
                        K = 0.003 inch
                        • #27
                          waveguide creates a spinning vortex straight dc no pulsing
                          • #28
                            Oh wow
                            Oh wow I like that coil. How is its geometry come by? Can you draw a picture of the shape of the vortex it creates? That is very beautiful! What is the core material that the red wires are wrapped around? This is very nice
                            Here is another picture of the WAM. It is made of steel foil.
                            • #29
                              The Shape of a Vortex
                              This is the shape of a vortex as it occurs in nature. I show you water vortex, because you can not see aether vortex.
                              A vortex may look like a spiral, but the medium is really spinning in many concentric circles!
                              • #30
                                Originally posted by GRON View Post
                                Right on. I believe that if you heterodyne two waves which are Golden Ratio to each other, you create many many sidebands, both higher and lower in frequency, all Golden Ratio to the next and previous in the sequence. Theoretically, you create a infinite number of sidebands.
                                If I am not mistaken, the Lakowski Multi-Wave Oscillator is a set of Split Ring Resonators which are all Golden Ratio to each other.
                                There are many structures, many ways to implement this principle.
                                Yes, they are. Log periodic antenna can create a virtual - non existing but functional, which will extend 1.5 times beyond the physical one.
                                Using two antennas you can obtain an infinite number of harmonics up to GHz range and this isn't theory anymore . I'm currently working on MWO - George Lakhowsky MWO which has bipolar spark gap driven Tesla Coil.
                                For your driver I would use double Mosfet driver, such as TC4426 and use separate DC source for IC and power part.
                                You're heading in very interesting direction. Good reading
                                Vtech
                                Last edited by blackchisel97; 07-18-2013, 09:40 PM. Reason: wrong value of extended field
                                General D.Eisenhower
                                http://www.nvtronics.org
